    [Plugin] Select Lines by Length (Updated March 9th, 2009)
    20 Posts 11 Posters 34.6k Views 11 Watching
      It's a pity that works not for a line "grouped" or a line "component"! ๐Ÿ˜‰
        If I want all lines of a selection? (not the faces ! )
        Can you add something for that? โ˜€
          301 Moved Permanently
          (www.sketchucation.com)
            Thx I had another one by Matt666
            Selection manager
            I will try yours also! โ˜€
            Yours seems more cozy! ๐Ÿ˜Ž
            Even it's a toy! ๐Ÿ˜‰ ๐Ÿ˜„
            Adopted! ๐Ÿ˜Ž
            But if Chris can make something like ">length wished" that will be terrific! ๐Ÿ’š
            Like >0
            or
            0 & < 12
            • Chris FullmerC Offline
              I might not get to it right away, but adding a selection length range would be easy enoug to do. Thanks for the suggestion.
                Cool! โ˜€
                • simon le bonS Offline
                  simon le bon
                  Heyhey! Chris,
                  Clever idea, wonderfull tool. Many thanks, just continue this way, cause we need such tools ๐Ÿ‘ ๐Ÿ˜› ๐Ÿ˜„ ๐Ÿ˜„ simon
                  • EarthMoverE Offline
                    EarthMover
                    Chris,
                    Would it be possible to also have a script that would select faces all of the same surface area?
                    Content Creator at Skapeup
                      Yeah, thats a good idea. I'll see if I can get that implemented. I have 2 others also in progress right now. Hopefully I'll get a chance to finish some of these up today. Thanks for the suggestion,
                        publied
                        chris,
                        another very interesting plugin from you! nice job. thank you so much.
                        /paolo
                        hire me@ http://www.publied.it !
                        • bagateloB Offline
                          bagatelo
                          Very good plugin. Is possible to make plugin work only in selection?
                            I suppose I could. The idea would be to select geometry first, then run the plugin and then when you click, lines only get added if you have cliked on something that is selected? Is that what you mean?
                            • bagateloB Offline
                              bagatelo
                              Yes!!!
