    [Plugin] Select Lines by Length (Updated March 9th, 2009)
    20 Posts 11 Posters 34.9k Views 11 Watching
    • Chris FullmerC Offline
      True, it wouldn't be that much more code to make it so it allowed for multiple starting lines being selected. Just a single line was the request, but if multiple lines is desired, I could expand it.
        Tricky โ˜€
        Maybe that be possible to choose something like this
        13 <= length < 20 ?
          Dee256
          Thanks, Chris! It's stuff save my worktime! Thanks Thanks Thanks!!! ๐Ÿ˜
            sigue2000
            That's a great script Chris!
            Thank you.
            It should save me a lot of clicks in the future.
            What?
              It's a pity that works not for a line "grouped" or a line "component"! ๐Ÿ˜‰
                If I want all lines of a selection? (not the faces ! )
                Can you add something for that? โ˜€
                  404 Not Found
                  (www.sketchucation.com)
                    Thx I had another one by Matt666
                    Selection manager
                    I will try yours also! โ˜€
                    Yours seems more cozy! ๐Ÿ˜Ž
                    Even it's a toy! ๐Ÿ˜‰ ๐Ÿ˜„
                    Adopted! ๐Ÿ˜Ž
                    But if Chris can make something like ">length wished" that will be terrific! ๐Ÿ’š
                    Like >0
                    or
                    0 & < 12
                      I might not get to it right away, but adding a selection length range would be easy enoug to do. Thanks for the suggestion.
                        Cool! โ˜€
                        • simon le bonS Offline
                          simon le bon
                          Heyhey! Chris,
                          Clever idea, wonderfull tool. Many thanks, just continue this way, cause we need such tools ๐Ÿ‘ ๐Ÿ˜› ๐Ÿ˜„ ๐Ÿ˜„ simon
                          • EarthMoverE Offline
                            EarthMover
                            Chris,
                            Would it be possible to also have a script that would select faces all of the same surface area?
                            Content Creator at Skapeup
                              Yeah, thats a good idea. I'll see if I can get that implemented. I have 2 others also in progress right now. Hopefully I'll get a chance to finish some of these up today. Thanks for the suggestion,
                                publied
                                chris,
                                another very interesting plugin from you! nice job. thank you so much.
                                /paolo
                                hire me@ http://www.publied.it !
                                • bagateloB Offline
                                  bagatelo
                                  Very good plugin. Is possible to make plugin work only in selection?
                                    I suppose I could. The idea would be to select geometry first, then run the plugin and then when you click, lines only get added if you have cliked on something that is selected? Is that what you mean?
                                    • bagateloB Offline
                                      bagatelo
                                      Yes!!!
