    [Plugin] Extrude Edges by Loft
    70 Posts 33 Posters 75.6k Views 33 Watching
    • N
      notareal
      Nice work. Thanks!
      • erikBE
        erikB
        Yet another, but very helpfull, extension of the (extrude) set.
        Thanks very much TIG 👍
        erikB
          rv1974
          @tig said:
          @rv1974 said:
          Super! Thank you TIG so much!
          Though it skips segments in the very first try.
          Without the skp to try I'm unsure what's up...
          Are the curves continuous - it would help it they had the same number of segments [although that IS meant to be coped with].
          Can you post [or PM me] a skp displaying this glitch ?
          loft.skp
            I've tested your skp and I agree that the tool has a glitch - for some reason it's missing out a part of the mesh in the latter/earlier stages - the two versions I first illustrate below are by picking the curves in their reverse order - different bits get missed out...
            The original has curves with varying edge counts...
            In the 'copy' I edited the curves so each has 12 edges [or 24 for the S one] - to make them readily sub-dividable - now it works fine - so it must be a bug in the re-division of the edges to try and get them to match each other - also used in EEbyRails incidentally
            I'll debug and get back to you...
            In the meanwhile please use curves with more closely related edge counts - they will work... any number SHOULD work...
              I see that the problem is that the 6-segment zigzag is being divided into pieces of four to match the 24-segment S-curve BUT at one point it's becoming 1 piece short [3] and at another one too many [5] so that the 'apportionment' of the edges goes wrong and it fails - so at least I have the effect... but now to find the cause 😒
              • mitcorbM
                mitcorb
                And what logically follows in the ExtrudeTools collection?
                It was inevitable. Thank you, TIG
                • mitcorbM
                  mitcorb
                  TIG:
                  What would it take to make the resultant mesh into a Bezier mesh? Or am I talking about another tool?
                  In other words after generating the mesh, you could modify it by Bezier control points that would allow you to pull and stretch the mesh like a rubber sheet, and even unfold some unwanted contortions.
                    Thomthom is working on a Vertex-Editor. which I think would become the basis of this editing tool ?
                    • P
                      Panga
                      Thanks a lot TIG for this one !!
                        There's an update of EEbyLoft - see the notes here: http://forums.sketchucation.com/viewtopic.php?p=231016#p231016
                        Get the tool in the zipped set from here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                        • EarthMoverE
                          EarthMover
                          UNREAL!!!!!! You are the man TIG!!!! 👍 👍
                          I'm starting really wish you would take these algorithms and write a new plugin to handle making terrains similar to "From Contours" but without the rats nest of a mesh the native tool creates. Your meshes are so smooth. Google needs you on staff immediately with a nice fat salary so you can code to your hearts content!
                          Content Creator at Skapeup
                          • C
                            chrisjk
                            I don't know if this is another Mac peculiarity but I get very strange results. From three circles (two copies plus an original), when I would expect a cylinder to result, I get this:-
                            I attach the skp file just in case there is something weird lurking in it.
                            Twisted.skp
                            • MALAISEM
                              MALAISE
                              TIG's plugin's , what else ???? 😄
                              MALAISE
                                  dedmin
                                  Erased the copies and made the new ones
                                  • C
                                    chrisjk
                                    Fantastic! TIG, thank you very much indeed for these great plugins.
                                      altap
                                      😲 This is really GREAT TIG... and BTW, I want to thank every ruby scripts developpers here again, you're making people happy 👍 .
                                      On another side while it may be irrelevant in sketchup ?! , what if it was a live loft sort of modifing the profiles( on which the loft volume is created ) and sketchup regenerate automatically the lofted volume. maybe it is too much asked as i'm already very glad to have a loft tool in Sketchup
                                        DIEGO-RODRIGUEZ
                                        thanks tig. excellent plugins. actually this set of tools for extrusion is increasingly complete. and further expand the potential of modeling sketchup.
                                        a small observation.
                                        http://img704.imageshack.us/img704/3393/loft.jpg
                                        when you select a curve, changes color.
                                        but generates a rare color "Dashedlines" between blue and another color
                                        a question
                                        You can set the number of Segments per Section: independently?
                                        or number of Segments per Section: General.
                                        osea
                                        number of segments between the first and last section selected
                                        Spanish translation:
                                        Small Correction
                                        extrudeEdgesByLoftES.rar
                                          The color 'dashing' is interference between the drawn color and the model's edges - it's pretty much unavoidable - the coloring is only intended to help you remember which curves you you have picked in what order - as ROYGBIV are the rainbow's colors...
                                          You can't currently have different segment-numbers in each section, it's based on the one value you give [which initially defaults as the most segmented curve's edge-count]...
                                          It would be possible to have varying segment counts - I suppose that the dialog could have a section-number entry for each segment defaulting to the maximum number of edges in the pair of curves bounding that section of mesh ? OR it could be a maximum count apportioned across the mesh based on some other factor like the numbers of edges in the curve-pairs...
                                          If users would like that I can come up with something ?
                                          Feedback first please...
                                          Thanks, I'll look at your ES lingvo for a future update...
                                            Coloft 😄
                                            • 2 / 4
