    [Plugin] Extrude Edges by Loft
    70 Posts 33 Posters 75.6k Views 33 Watching
    • Didier BurD
      Didier Bur
      Hi Solo,
      the debabelizer is in the Zip.
      Just in case, here it is (put it in Plugins folder)
      goes to Plugins folder
      DB
        Tremendous scripting and very welcome addition to 'must have' toolset ๐Ÿ‘
        • soloS
          Thanks TIG that solved that, now playtime!!
            You make a plug by a day! ๐Ÿ˜ฎ
            That is a good average ๐Ÿ˜„ ๐Ÿ˜‰
            PS An automatic order Selection curves will be fine for exemple in case of use plug like Grow by TIG? ๐Ÿ˜‰
              Pilou you are cruel ๐Ÿ˜‰
              There's the 3rd update of the day here http://forums.sketchucation.com/viewtopic.php?p=231137#p231137 - new FR lingvo by Didier... โ˜€
              • jason_marantoJ
                jason_maranto
                Thank-you so much TIG for the cool new tool and the pictures to go along with it.
                Best,
                Jason.
                • teufT
                  teuf
                  Wow !!
                  Really a good plug. Relevant to do 3D.
                  Thanx thanx thanx
                    rv1974
                    Super! Thank you TIG so much!
                    Though it skips segments in the very first try.
                      Without the skp to try I'm unsure what's up...
                      Are the curves continuous - it would help it they had the same number of segments [although that IS meant to be coped with].
                      Can you post [or PM me] a skp displaying this glitch ?
                      ๐Ÿ˜•
                      • N
                        notareal
                        Nice work. Thanks!
                        • erikBE
                          erikB
                          Yet another, but very helpfull, extension of the (extrude) set.
                          Thanks very much TIG ๐Ÿ‘
                          erikB
                            rv1974
                            ๐Ÿ˜•
                            loft.skp
                              I've tested your skp and I agree that the tool has a glitch - for some reason it's missing out a part of the mesh in the latter/earlier stages - the two versions I first illustrate below are by picking the curves in their reverse order - different bits get missed out...
                              The original has curves with varying edge counts...
                              In the 'copy' I edited the curves so each has 12 edges [or 24 for the S one] - to make them readily sub-dividable - now it works fine - so it must be a bug in the re-division of the edges to try and get them to match each other - also used in EEbyRails incidentally
                              I'll debug and get back to you...
                              In the meanwhile please use curves with more closely related edge counts - they will work... any number SHOULD work...
                                I see that the problem is that the 6-segment zigzag is being divided into pieces of four to match the 24-segment S-curve BUT at one point it's becoming 1 piece short [3] and at another one too many [5] so that the 'apportionment' of the edges goes wrong and it fails - so at least I have the effect... but now to find the cause ๐Ÿ˜’
                                • mitcorbM
                                  mitcorb
                                  And what logically follows in the ExtrudeTools collection?
                                  It was inevitable. Thank you, TIG
                                  • mitcorbM
                                    mitcorb
                                    TIG:
                                    What would it take to make the resultant mesh into a Bezier mesh? Or am I talking about another tool?
                                    In other words after generating the mesh, you could modify it by Bezier control points that would allow you to pull and stretch the mesh like a rubber sheet, and even unfold some unwanted contortions.
                                      Thomthom is working on a Vertex-Editor. which I think would become the basis of this editing tool ?
                                      • P
                                        Panga
                                        Thanks a lot TIG for this one !!
                                          There's an update of EEbyLoft - see the notes here: http://forums.sketchucation.com/viewtopic.php?p=231016#p231016
                                          Get the tool in the zipped set from here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                          • EarthMoverE
                                            EarthMover
                                            UNREAL!!!!!! You are the man TIG!!!! ๐Ÿ‘ ๐Ÿ‘
                                            I'm starting really wish you would take these algorithms and write a new plugin to handle making terrains similar to "From Contours" but without the rats nest of a mesh the native tool creates. Your meshes are so smooth. Google needs you on staff immediately with a nice fat salary so you can code to your hearts content!
                                            Content Creator at Skapeup
                                            • 1 / 4
