    [Plugin] Extrude Edges by Loft
    70 Posts 33 Posters 74.7k Views 33 Watching
      Panga
      Thanks a lot TIG for this one !!
        There's an update of EEbyLoft - see the notes here: http://forums.sketchucation.com/viewtopic.php?p=231016#p231016
        Get the tool in the zipped set from here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
        • EarthMoverE Offline
          EarthMover
          UNREAL!!!!!! You are the man TIG!!!! 👍 👍
          I'm starting really wish you would take these algorithms and write a new plugin to handle making terrains similar to "From Contours" but without the rats nest of a mesh the native tool creates. Your meshes are so smooth. Google needs you on staff immediately with a nice fat salary so you can code to your hearts content!
          Content Creator at Skapeup
            chrisjk
            I don't know if this is another Mac peculiarity but I get very strange results. From three circles (two copies plus an original), when I would expect a cylinder to result, I get this:-
            I attach the skp file just in case there is something weird lurking in it.
            Twisted.skp
            • MALAISEM Offline
              MALAISE
              TIG's plugin's , what else ???? 😄
              MALAISE
                  dedmin
                  Erased the copies and made the new ones
                    chrisjk
                    Fantastic! TIG, thank you very much indeed for these great plugins.
                      altap
                      😲 This is really GREAT TIG... and BTW, I want to thank every ruby scripts developpers here again, you're making people happy 👍 .
                      On another side while it may be irrelevant in sketchup ?! , what if it was a live loft sort of modifing the profiles( on which the loft volume is created ) and sketchup regenerate automatically the lofted volume. maybe it is too much asked as i'm already very glad to have a loft tool in Sketchup
                        DIEGO-RODRIGUEZ
                        thanks tig. excellent plugins. actually this set of tools for extrusion is increasingly complete. and further expand the potential of modeling sketchup.
                        a small observation.
                        http://img704.imageshack.us/img704/3393/loft.jpg
                        when you select a curve, changes color.
                        but generates a rare color "Dashedlines" between blue and another color
                        a question
                        You can set the number of Segments per Section: independently?
                        or number of Segments per Section: General.
                        osea
                        number of segments between the first and last section selected
                        Spanish translation:
                        Small Correction
                        extrudeEdgesByLoftES.rar
                          The color 'dashing' is interference between the drawn color and the model's edges - it's pretty much unavoidable - the coloring is only intended to help you remember which curves you you have picked in what order - as ROYGBIV are the rainbow's colors...
                          You can't currently have different segment-numbers in each section, it's based on the one value you give [which initially defaults as the most segmented curve's edge-count]...
                          It would be possible to have varying segment counts - I suppose that the dialog could have a section-number entry for each segment defaulting to the maximum number of edges in the pair of curves bounding that section of mesh ? OR it could be a maximum count apportioned across the mesh based on some other factor like the numbers of edges in the curve-pairs...
                          If users would like that I can come up with something ?
                          Feedback first please...
                          Thanks, I'll look at your ES lingvo for a future update...
                            Coloft 😄
                            • teufT Offline
                              teuf
                              @jonorman said:
                              A little render testing loft. Thnx for a great plugin.
                              Did you model this car with loft plugin ? 😲
                                jonorman
                                A little render testing loft. Thnx for a great plugin. (edit: the blue silke cloth 😳 )
                                • H Offline
                                  hebeijianke
                                  TIG: Here's the Chinese lingvo fileextrudeEdgesByLoftZH-CN.rar
                                    Thanks, the new lingvo will be zipped in with the next update... 😄
                                      sketch13
                                      fantastic thanks
                                      • H Offline
                                        hsjzyangbin
                                        @tig said:
                                        [attachment=0:mpce8awt]<!-- ia0 -->Twisted.png<!-- ia0 -->[/attachment:mpce8awt]
                                        is there any plugins forums that control the start/end point of line?
                                        • mitcorbM Offline
                                          mitcorb
                                          Hi, TIG:
                                          Attached is a clumsy half carcass of a fish.
                                          Tailfin done with EExR, I believe.
                                          Main body done with EExR too, but with some corrective restretching and knitting.
                                          Head section begun with progressive modeling by copying the curve and Fredoscaling it into place, and then knitting the faces closed.
                                          Last section done with EExLoft. This section shows the distortion/ drift away from the intended ground curve, even though the ground curve was not part of the selection. You might note the lofted mesh sort of makes a shallow sine wave shape above and below the ground face.
                                          Just wondering how you are progressing on the adjustments you are making.
                                          wip for review
                                            One of the reasons I think you are getting problems is that many faces of the mesh might be getting too small - try modeling the fish x10 real size and scaling the results down later.
                                            SUp has a limit to how small a face it can make but scaling downwards they stay OK...
                                            EEbyLoft does make a bezier transition curve. To control the form better use EEbyRail ?
                                            • 2 / 4
