    [Plugin] Extrude Edges by Loft
    70 Posts 33 Posters 72.1k Views 33 Watching
      You make a plug by a day! 😮
      That is a good average 😄 😉
      PS An automatic order Selection curves will be fine for exemple in case of use plug like Grow by TIG? 😉
        Pilou you are cruel 😉
        There's the 3rd update of the day here http://forums.sketchucation.com/viewtopic.php?p=231137#p231137 - new FR lingvo by Didier... ☀
        • jason_marantoJ Offline
          jason_maranto
          Thank-you so much TIG for the cool new tool and the pictures to go along with it.
          Best,
          Jason.
          • teufT Offline
            teuf
            Wow !!
            Really a good plug. Relevant to do 3D.
            Thanx thanx thanx
              rv1974
              Super! Thank you TIG so much!
              Though it skips segments in the very first try.
                Without the skp to try I'm unsure what's up...
                Are the curves continuous - it would help it they had the same number of segments [although that IS meant to be coped with].
                Can you post [or PM me] a skp displaying this glitch ?
                • N Offline
                  notareal
                  Nice work. Thanks!
                  Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                  • erikBE Offline
                    erikB
                    Yet another, but very helpfull, extension of the (extrude) set.
                    Thanks very much TIG 👍
                    erikB
                      rv1974
                      loft.skp
                        I've tested your skp and I agree that the tool has a glitch - for some reason it's missing out a part of the mesh in the latter/earlier stages - the two versions I first illustrate below are by picking the curves in their reverse order - different bits get missed out...
                        The original has curves with varying edge counts...
                        In the 'copy' I edited the curves so each has 12 edges [or 24 for the S one] - to make them readily sub-dividable - now it works fine - so it must be a bug in the re-division of the edges to try and get them to match each other - also used in EEbyRails incidentally
                        I'll debug and get back to you...
                        In the meanwhile please use curves with more closely related edge counts - they will work... any number SHOULD work...
                          I see that the problem is that the 6-segment zigzag is being divided into pieces of four to match the 24-segment S-curve BUT at one point it's becoming 1 piece short [3] and at another one too many [5] so that the 'apportionment' of the edges goes wrong and it fails - so at least I have the effect... but now to find the cause 😒
                          • mitcorbM Offline
                            mitcorb
                            And what logically follows in the ExtrudeTools collection?
                            It was inevitable. Thank you, TIG
                            • mitcorbM Offline
                              mitcorb
                              TIG:
                              What would it take to make the resultant mesh into a Bezier mesh? Or am I talking about another tool?
                              In other words after generating the mesh, you could modify it by Bezier control points that would allow you to pull and stretch the mesh like a rubber sheet, and even unfold some unwanted contortions.
                                Thomthom is working on a Vertex-Editor. which I think would become the basis of this editing tool ?
                                  Panga
                                  Thanks a lot TIG for this one !!
                                    There's an update of EEbyLoft - see the notes here: http://forums.sketchucation.com/viewtopic.php?p=231016#p231016
                                    Get the tool in the zipped set from here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                    • EarthMoverE Offline
                                      EarthMover
                                      UNREAL!!!!!! You are the man TIG!!!! 👍 👍
                                      I'm starting really wish you would take these algorithms and write a new plugin to handle making terrains similar to "From Contours" but without the rats nest of a mesh the native tool creates. Your meshes are so smooth. Google needs you on staff immediately with a nice fat salary so you can code to your hearts content!
                                      Content Creator at Skapeup
                                        chrisjk
                                        I don't know if this is another Mac peculiarity but I get very strange results. From three circles (two copies plus an original), when I would expect a cylinder to result, I get this:-
                                        I attach the skp file just in case there is something weird lurking in it.
                                        Twisted.skp
                                        • MALAISEM Offline
                                          MALAISE
                                          TIG's plugin's , what else ???? 😄
                                          MALAISE
                                            • 1 / 4
