    Copying Holes?
    23 Posts 12 Posters 7.3k Views 12 Watching
    • C
      chrisjk
      Not for me - even as a cutting component
        Jim
        The difference in results for such a fundamental behavior is not acceptable.
          Ok - I see what it is now. If you make a hole that cuts all the way through, connecting on the other side of the cube, then you won't get a hole. But a hole, simple or a little bit extruded, will make a new hole where it's copied to.
            Jim
            That seems like the exact opposite of how it should work.
            • Chris FullmerC
              This has been a common probelm for me. Especially in making square insets for windows, then copying a large chunk of windows across a face. I often have issues where some do not cut right. 😞
                Jim
                I can understand the hole not copying - it is a hole (as in nothing there) so why would I expect copying the cylinder to create a hole?
                But I don't understand why the cylinder does not intersect the top and bottom surfaces when copied.
                • C
                  chrisjk
                  A related behaviour is seen by push/pulling a hole through a cube - deleting the top surface of the cube and reinstating it by drawing a line along one edge. The surface so created fills the hole (as well as the cube) which then acts like the copied variety discussed earlier.
                  • Jean LemireJ
                    Jean Lemire
                    Hi folks.
                    See this SU file for ideas.
                    Array of holes.skp
                    Sorry for the large size, I could have used circles with less segments.
                    • DavidBoulderD
                      DavidBoulder
                      What is interesting about a hole all of the way through is that if you just copy the circles (but the the cylinder wall) both faces are cut by the circles. But if you select the cylinder walls as well (or by itself) then the faces are not cut.
                      David Goldwasser
                      OpenStudio Developer
                      National Renewable Energy Laboratory
                      • X
                        xrok1
                        hmm.. played with it a bit. gotta be a bug. did anyone notice that you can get the circle to resize with the move tool??? 😕
                        • Chris FullmerC
                          Yes, being able to click on one of the cardinal points with the move tool has always scaled a circle or arc in SU. Weird, huh?
                          • U
                            Ultimatez 32
                            @solo said:
                            If you make the hole a component that cuts it will work fine.
                            Yup, works fine if it makes a component that cuts.
                            Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                            • U
                              Ultimatez 32
                              ....and I've got video to prove it 😉
                              [flash=800,500:3rgcl2d4]http://vimeo.com/moogaloop.swf?clip_id=9879304[/flash:3rgcl2d4]
                              • newnoobN
                                newnoob
                                I just discoverd the "cut opening" function in the component dialog box.
                                I played a bit around and it works great except one thing:
                                I can not create a hole component which can cut holes through an entire object (from on face to the other), when I try to create such a component the "cut opening" check box in the "create component" dialog is not able to be selected.
                                Tomtom has already mentioned this behaviour in this tread.
                                Do I have to live with that or is there a fix?
                                • JQLJ
                                  JQL
                                  There is no fix, sadly it's by design. What you can do is a hole cutting component on each side of your volume...
                                  www.casca.pt
                                  Visit us on facebook!
                                    OR... use my tool http://sketchucation.com/pluginstore?pln=HolePunchTool
                                    to add associated reveal geometry to a hole-cutting component...
                                    1 Reply Last reply 👍
                                    • newnoobN
                                      newnoob
                                      Ok thanks for the information - at least I know now it is not my fault which is usually the case.
                                      I'll check that out.
