    Copying Holes?
    23 Posts 12 Posters 7.3k Views 12 Watching
    • Chris FullmerC
      This has been a common probelm for me. Especially in making square insets for windows, then copying a large chunk of windows across a face. I often have issues where some do not cut right. 😞
        Jim
        I can understand the hole not copying - it is a hole (as in nothing there) so why would I expect copying the cylinder to create a hole?
        But I don't understand why the cylinder does not intersect the top and bottom surfaces when copied.
        • C
          chrisjk
          A related behaviour is seen by push/pulling a hole through a cube - deleting the top surface of the cube and reinstating it by drawing a line along one edge. The surface so created fills the hole (as well as the cube) which then acts like the copied variety discussed earlier.
          • Jean LemireJ
            Jean Lemire
            Hi folks.
            See this SU file for ideas.
            Array of holes.skp
            Sorry for the large size, I could have used circles with less segments.
            • DavidBoulderD
              DavidBoulder
              What is interesting about a hole all of the way through is that if you just copy the circles (but the the cylinder wall) both faces are cut by the circles. But if you select the cylinder walls as well (or by itself) then the faces are not cut.
              David Goldwasser
              OpenStudio Developer
              National Renewable Energy Laboratory
              • X
                xrok1
                hmm.. played with it a bit. gotta be a bug. did anyone notice that you can get the circle to resize with the move tool??? 😕
                • Chris FullmerC
                  Yes, being able to click on one of the cardinal points with the move tool has always scaled a circle or arc in SU. Weird, huh?
                  • U
                    Ultimatez 32
                    @solo said:
                    If you make the hole a component that cuts it will work fine.
                    Yup, works fine if it makes a component that cuts.
                    Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                    • U
                      Ultimatez 32
                      ....and I've got video to prove it 😉
                      [flash=800,500:3rgcl2d4]http://vimeo.com/moogaloop.swf?clip_id=9879304[/flash:3rgcl2d4]
                      • newnoobN
                        newnoob
                        I just discoverd the "cut opening" function in the component dialog box.
                        I played a bit around and it works great except one thing:
                        I can not create a hole component which can cut holes through an entire object (from on face to the other), when I try to create such a component the "cut opening" check box in the "create component" dialog is not able to be selected.
                        Tomtom has already mentioned this behaviour in this tread.
                        Do I have to live with that or is there a fix?
                        • JQLJ
                          JQL
                          There is no fix, sadly it's by design. What you can do is a hole cutting component on each side of your volume...
                          www.casca.pt
                          Visit us on facebook!
                            OR... use my tool http://sketchucation.com/pluginstore?pln=HolePunchTool
                            to add associated reveal geometry to a hole-cutting component...
                            1 Reply Last reply 👍
                            • newnoobN
                              newnoob
                              Ok thanks for the information - at least I know now it is not my fault which is usually the case.
                              I'll check that out.
