    Vapors: clouds, steam, smoke
    9 Posts 5 Posters 3.1k Views 5 Watching
      MartinRinehart
      I wanted to hang some small clouds in the sky behind Biplane to make his loops more clear. Didn't figure that one out.
      Anyone had any success with clouds, airplane sky-writing, smoke coming out of a locomotive, steam from a kettle?
        Particle effects. Been tempted - but I'm not good enough with the math.
          remus
          i think your best bet would be with some decent textures, perhaps created in something that has proper particle effects like vue or blender.
            I had an idea where you created a volume, and the volume would be populated by CPoints. Then the CPoint could be toggled on and off to be replaced with components.
            In 3DsMax I made some smoke effect by making the particles into a face, facing the camera, with a white circle on transparent background. Simple effect.
              Working out if a Point3d is inside a 'volume' is quite easy - it's been discussed here recently.
              Making a random Point3d [so that the xyz stays within the volume's bounds] is also relatively easy.
              Making a number of these by looping till a 'density' is reached is also easy.
              Placing cpoints at these Point3d is also easy.
              As is making a faceme 2d-rectangular semi-opaque 'dot' [png] component that is then swapped with these cpoints is also quite easy...
              So let's do it...
              πŸ˜‰
                that ray tracing thing?
                  Of course you can simply miss out the cpoint steps and use something like
                  tr=Geom::Transformation.new(point3d) cloud_group.entities.add_instance(dot_component,tr)
                  inside the point3d generating loop...
                    Yes - and since you will make the 'volume' first it should be 'watertight' ?
                      cosycat
                      You can obtain a fairly quick and basic effect by using gradient transparency pngs in front of the camera as here
                      http://forums.sketchucation.com/viewtopic.php?f=81&t=23368&p=198149#p198149
