Vapors: clouds, steam, smoke
I wanted to hang some small clouds in the sky behind Biplane to make his loops more clear. Didn't figure that one out.
Anyone had any success with clouds, airplane sky-writing, smoke coming out of a locomotive, steam from a kettle?
Particle effects. Been tempted - but I'm not good enough with the math.
i think your best bet would be with some decent textures, perhaps created in something that has proper particle effects like vue or blender.
I had an idea where you created a volume, and the volume would be populated by CPoints. Then the CPoint could be toggled on and off to be replaced with components.
In 3DsMax I made some smoke effect by making the particles into a face, facing the camera, with a white circle on transparent background. Simple effect.
Working out if a Point3d is inside a 'volume' is quite easy - it's been discussed here recently.
Making a random Point3d [so that the xyz stays within the volume's bounds] is also relatively easy.
Making a number of these by looping till a 'density' is reached is also easy.
Placing cpoints at these Point3d is also easy.
As is making a faceme 2d-rectangular semi-opaque 'dot' [png] component that is then swapped with these cpoints is also quite easy...
So let's do it...
that ray tracing thing?
Of course you can simply miss out the cpoint steps and use something like
tr=Geom::Transformation.new(point3d) cloud_group.entities.add_instance(dot_component,tr)
inside the point3d generating loop... -
Yes - and since you will make the 'volume' first it should be 'watertight' ?
You can obtain a fairly quick and basic effect by using gradient transparency pngs in front of the camera as here
http://forums.sketchucation.com/viewtopic.php?f=81&t=23368&p=198149#p198149
