    [Plugin] Component Dropper
    49 Posts 21 Posters 53.1k Views 21 Watching
      Tools -> Component Dropper
      Works like the Material Dropper - but for components and groups.
      [flash=600,450:286laqax]http://www.youtube.com/v/5RhuVc36ADY[/flash:286laqax]
      1. Make a selection containing groups and components. (Doesn't matter if it contains more, it'll be ignored.)
      2. Activate the tool
      3. Pick another group or component instance to replace the ones in your selection.
      The replaced instances will be made to match the bounding box of the old.
      SketchUp Plugins | PluginStore | SketchUcation
      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
      (sketchucation.com)
      Known Issues:
      • 2D components won't work. Don't try to replace them. The replaced instances will end up as Zero Dimensional! You've been warned! (How many of you silly lads will still try this? Yea - I know what you're like.)
        hmm... think I'm seeing some oddities in some cases... looks like I need to take another look.
        • X Offline
          xrok1
          another good one. ๐Ÿ˜„ maybe swapper or changer would be a better name though. ๐Ÿ˜‰
          โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
          • soloS Offline
            Thomthom, let's say i have a tree with 1000 leaves,I have a single polygon representing the leaf, can I substitute the single polygon (which is a group) for another group say a higher poly one with mapped texture to replace all instances of the low one?
            • X Offline
              xrok1
              he he, you try it and tell us all ๐Ÿ˜‰
                Yes - I'd think so.
                Just occurred to me that I don't copy the group/component material of the instance I replace...
                  I was considering that, but choose "Dropper" to indicate it was a tool like the Material Dropper.
                  but I got another one baking which will be a "??? Swapper" ๐Ÿ˜‰
                  • X Offline
                    xrok1
                    good then, its just that when i first spotted this thread i was thinking of smartdrop at intersection and wondered what else could be done? drop is drop. ๐Ÿ˜• ๐Ÿ˜†
                    • soloS Offline
                      swopper.rb?
                      • X Offline
                        xrok1
                        very punny Solo. but i like it!
                        • TIGT Online
                          Unfortunately 'dropper' in English is usually taken as something to do with 'dropping' - i.e. it is 'something that 'makes drops' [drops = either some actual or potential physical movements downwards, or small globules of liquid] or makes things 'drop' [i.e. to move downwards] - long before it clicks that it is meant as 'eye-dropper' [something that makes **eye-**drops - i.e. globules of liquid that fall into the eye from a rubber-bulb activated pipette - commonly called an 'eye-dropper']...
                          So I recommend that you either rename it 'eye-dropper' or 'matcher' or 'swapper/swopper' or something else that doesn't sound like it's to do with things being made to fall downwards - the older tool 'Drop' moves selected components downwards so 'Dropper' sounds like it'll do something similar !!! ... ๐Ÿ˜’
                          PS: it's a great idea otherwise ๐Ÿ˜„
                            Swopper it is!
                            Well, that is - you got until my next update to name this ... thingy-ma-jiggy.
                            • utilerU Offline
                              utiler
                              cool, Thomas, D/L and having a play!!!
                              Just Curious...
                                What happend about the old component? Killed?
                                  Yes, the instance is slaughtered.
                                    d12dozr
                                    ๐Ÿ˜ฎ ๐Ÿคฃ Thanks for a good laugh Thomthom!
                                    http://goo.gl/f7ooYh
                                    • bagateloB Offline
                                      bagatelo
                                      Great ThomThom. I had already thought previously about a plugin that made this.
                                      For the name given to this script I thought that it was this plugin:
                                      http://forums.sketchucation.com/viewtopic.php?f=323&t=20233&p=223396#p223396
                                      ๐Ÿ˜ž
                                        Thx for the precision ๐Ÿ˜‰
                                        http://www.monsieurpoulet.com/fichiers/7848/produits/4985/max_tir_au_pigeons.jpg
                                        • H Offline
                                          hsjzyangbin
                                          very funny
                                            arjunmax09
                                            cool plugin thomthom... don't take a cookie .... you deserve a cake man... ๐Ÿ˜„chocolate-cake-oh-1727433-x.jpg
                                            PS... i've eaten one piece out of it... hehe ๐Ÿ˜†
                                            when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                            • 1 / 3
