    New vray
    renderpluginsextensions
    35 Posts 15 Posters 7.7k Views 15 Watching
      sketchup_fan
      Has anyone bought the new vray for sketchup 7? If you do, could you share your impressions about the render engine with us?
        Been using the beta. Had V-Ray before that.
        Many nice new features.
        • IES Lights
        • Ambient Occulsion
        • Render Region
        • More procedural maps
        Many good improvements:
        • Materials can be copied between models - V-Ray data is preserved
        • Missing groups are fixed
        • Group/Component materials doesn't cause instance parsing slowdown any more
        • 2sided materials accepts bitmap as blending map
        Very nice update.
          sketchup_fan
          Wow, i'd buy it i f i had the money, but you see, i'm missing 350 euros. πŸ˜†
            steelers05
            thomthom....so if I set materials up for an object and started to overhaul my 3d import library, they should import into my projects with the proper material settings? If that is so....im pumped. That would be an awesome workflow change
              Yea, you can now build components with V-Ray materials pre-setup. πŸ˜„ Big workflow improvement. Plus the fixed group/component material issue which previously used to add insane processing time. πŸ˜„
              That and you can render Image elements - and VfSU uses the alpha channel from the diffuse texture.
              It's a very good improvement over the old version. Not to mention that this was intended as a pure rewrite to make it work on OSX. We got so much more new stuff. I mean - render region! πŸ˜„
              • broomstickB Offline
                broomstick
                and ambient occlusion!!
                Have you tried the AO in the new version? Does it work well?
                  Oh yea, it works very nice. It often makes the render pick up more details in the corners. But I'm vary of over using it.
                  The Dirt map is also nice.
                    broomstick
                    Yeah I know. Sometimes the AO render is a very nice image in itself! As soon as I get to do something decent I'll post it πŸ˜„
                    • N Offline
                      nomeradona
                      additional spotlight too. i think its faster. still trying to look on material editor. still having difficulty with the amount of multipliers. but overall its an excellent upgrade.
                        Ruturaj
                        that information is very helpful,
                        but my problem is i can't activate demo version
                        please help me thanks ............
                        Thanks,
                        RuturaJ
                          @ruturaj said:
                          Contact support@asgvis.com for license problems and program errors.
                            Ruturaj
                            Hello,
                            Thanks thomthom.............
                            Thanks,
                            RuturaJ
                            • E Offline
                              edu1987
                              where is the manual for the new version with all the new improvements?
                              always be psycho about perfection
                                Being written.
                                  sketchup_fan
                                  Thomthom, if i have a model in one sketchup file with vray materials made in the material editor, if i copy the model to another sketchup file, will the materials in the material editor transfer from one file to the other? In the older version of vray the materials didn't pass from on file to the other.
                                    with the new version they are transferred. You can make components libraries where V-Ray materials are already set up. And copy between models works as well.
                                      sketchup_fan
                                      Does the new version has come out, or only the beta? Because when i go to asgvis under 'buy' doesn't mention anything that this is the new vray.
                                        Did you really look?
                                        On the front page, http://asgvis.com/ it says in the little speech bubble: "Why am I here? To announce the release of the New V-Ray for Sketchup "
                                        When you click on Software, the next screen says in big letter "Introducing The New V-Ray for SketchUp"
                                        Ditto with the Store section.
                                        πŸ˜‰
                                        The new version was released last Wednesday.
                                          DIEGO-RODRIGUEZ
                                          I have a problem to install the demo version of vray. can someone help?
                                          use sketchup 7.1 in Spanish
                                          windows xp sp3 in Spanish
                                          [flash=853,505:3gkehgnd]http://www.youtube.com/v/cy_cwWDSZ20&fs=1[/flash:3gkehgnd]
                                            archigrafix
                                            took a look at your video and must say I dont have solution but have you tried to contact: support@asgvis.com ?
                                            Agir comme un homme de pensΓ©e, et penser comme un homme d'action...
