    [Plugin] Manifold v2.2
    126 Posts 19 Posters 61.0k Views 19 Watching
      driven
      @d12dozr said:
      ...easier than me starting over from scratch πŸ™‚
      Here's a semi complex one that sort of worked with 1.2, but on 1.3 it would only hang....
      I might get this one printed in stainless, should only cost $100, and I can't think how else to make it.
      I'm about to re-test it on my Mac and a PC comparison would show up if some of the problems are me or not...
      If it fails first try, manually orient the reversed faces, then remove the internal disc on the bottom run and try again.
      it 'should' remove the internal overlap on the bottom 2/3 twists (1.2 left these intact)
      it might still make a hash of the end, Fredo's bend tool can be unkind to meshes.
      I been running it without manual repairs
      • H Offline
        hsjzyangbin
        HI,TIG,is there have some differece between trigulaer face .rb and Manifold v1.4?
          @hsjzyangbin said:
          HI,TIG,is there have some difference between trigulate face .rb and Manifold v1.4?
          If the read the notes in the first post... 'manifold' does triangulate faces at the end, BUT it does so much more - it tidies the shapes to remove faceless edges, remove flaps, remove disconnected geometry, heal holes and very small faces, orient faces and then triangulates, and finally 'reports' on what it's done.
          It is an attempt to automate the making of a 'manifold' surfaced mesh that will work properly when it's exported for use in a 3D printer, and some other 3D apps...
          It's still under development...
          • O Offline
            otb designworks
            You are the Man, TIG!
            This plug in is a great great idea.
            Cheers, Chuck
            Cheers, Chuck
            OTB Designworks is on Youtube
              Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
              Various adjustments on speed, reporting, lingvo etc...
              Still need to sort out 'pretzels' better... πŸ˜’
                driven
                Cheers TIG,
                I was just logging in to say, I've set up one of my Macs, with a fresh instal and only a few basic rubies that I've triple checked are clean. Just to test Manifold. That way any log errors on my system console should be easily spotted, and you posted this, so excellent timing. I'll keep you informed. john
                  driven
                  Can you PM that file so I can test it too... ❓
                  Don't bother - I made one like it and I see the problem πŸ˜’
                    driven
                    inner face left
                    Fresh off the press, No error messages in console, had lots of info zipping through, had Pass dialogs, so all seems to be functioning, but all passed have inner faces? john
                    EDIT: I did the first with Transparency ON, so just in case it wasn't see the faces I re-did with Trans OFF, but the faces are still inside and the orientation is different from first
                    turned transparency off, orientations flip
                      Here's v1.6 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                      Face making error fixed, 3-edge faces removal improved.
                      Sub-groups/Instances now within Group removed & reported.
                      Error reporting improved.
                        driven
                        Hi TIG,
                        I think it's working really nicely now, lot faster, plenty of info, it still passes inner faces that don't necessarily break the 1 edge, 2 face rule.
                        There are only two '4-faced' edges in the original drawing and if a BoolTool, VWS, or a manual delete is done first, (as it should be) than manifold does a speedy and detailed correction, orientation and triangulation. I'm wondering if a simple pre-flight check that states, "I'm not doing this-there are inner faces highlighted that you need to remove first" or something less long winded, might not be in order. I'll PM you some other screen shot's as well.
                        acid test
                        Am I the only one testing this????
                          Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                          It now does a quick initial 'Health-Check' on the group and a dialog reports - it also temporarily shows any probable 'internal faces' in Magenta and faces adjoining probable 'holes' in Cyan etc...
                          If it's a lot of errors you can answer 'No' to not continue and then attempt to fix them manually, before trying again - or answer Yes to continue if there are no problems identified, or answer Yes anyway to try and auto-fix any problems [with a final error report and red/green/.../-.- highlighting in an "error-group"]...
                          πŸ€“
                            driven
                            TIG....do you sleep???
                            • O Offline
                              otb designworks
                              any chance this can be adjusted to not triangulate all faces? It is very useful for me to be able to clean up a model that I have carefully constructed so that I have consistent quads everywhere, which is what I need for sending into ZBrush for further detail modeling.
                              I know that Cheetah, too, triangulates everything when performing boolean functions, which I also find annoying. It is this, more than anything, that keeps me away from automated solutions for ensuring manifold meshes.
                              Cheers, Chuck
                              Cheers, Chuck
                                Cheers, Chuck
                                I'll add triangulation as a closing option ? πŸ€“
                                • O Offline
                                  otb designworks
                                  That would be quite useful, for me.
                                  Now, how about a plug-in that cuts a model up into beautifully perfect quads? I'd pay cold hard cash for that one, too.
                                  Thanks TIG!
                                  Cheers, Chuck
                                    Here's v1.8 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                                    Triangulation is now an option near the end - Answer Yes to do it... πŸ€“
                                      driven
                                      TIG,
                                      slight problem, when choosing Yes to continue after an 'initial health check' pass, it zapps everything even unselected groups.... both on badly grouped and clean booled groups, I'll do some more and send pics.
                                      I'll see if it still happening in 1.8
                                        @driven said:
                                        TIG,
                                        Odd - I can't get it to error at all... πŸ˜• Please 'feedback'.............
                                          driven
                                          @tig said:
                                          Odd - I can't get it to error at all... :? Please 'feedback'.............
                                          been trying to up load pics, site is slow, pics to follow
                                          it's on both machines, 1.7 and 1.8
                                          3 groups from Draw Shapes Menu, grouped, manifold_1.7and8, both give a pass
                                          [attachment=0:19dcyp32]<!-- ia0 -->3 groups inside group_1.jpg<!-- ia0 -->[/attachment:19dcyp32]
                                          Yes to continue....zapppp
                                          Same 3 groups, exploded then regrouped is running as predicted on other mac at the moment, this site is slow from this machine....
                                            driven
                                            the first and last zap the drawing clean, i.e. everything goes
                                            • 2 / 7
