    [Plugin] Manifold v2.2
    126 Posts 19 Posters 82.5k Views 19 Watching
      @driven said:
      TIG, no dialogs and I get this that I haven't had before,
      27/01/2010 16:26:58 [0x0-0x6f06f.com.google.sketchupfree7[925] #<NoMethodError: undefined method flattenUVQ' for #<Manifold:0x1e6005a4>> 27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:580:in triangulateFace'
      27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:574:in each' 27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:574:in triangulateFace'
      27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:621:in triangulate_faces' 27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:619:in each'
      27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:619:in triangulate_faces' 27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:112:in activate'
      27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:701:in select_tool' 27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:701:in manifold'
      27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:716]
      I haven't changed that ? It's trying to map textures back onto triangulated faces properly ??? I'll investigate...
      Avoid textured faces for now...
        driven
        TIG,
        I have had it before, I just went back through the logs and buried in there is the same report, at least for 1.3, 1.4
          driven
          A re-start found the dialogs, so 1.3 would not pass this (which is correct) due to more then 2 faces per edge, also reversed faces made it through...
          passed???
            driven
            @d12dozr said:
            ...easier than me starting over from scratch πŸ™‚
            Here's a semi complex one that sort of worked with 1.2, but on 1.3 it would only hang....
            I might get this one printed in stainless, should only cost $100, and I can't think how else to make it.
            I'm about to re-test it on my Mac and a PC comparison would show up if some of the problems are me or not...
            If it fails first try, manually orient the reversed faces, then remove the internal disc on the bottom run and try again.
            it 'should' remove the internal overlap on the bottom 2/3 twists (1.2 left these intact)
            it might still make a hash of the end, Fredo's bend tool can be unkind to meshes.
            I been running it without manual repairs
            • H
              hsjzyangbin
              HI,TIG,is there have some differece between trigulaer face .rb and Manifold v1.4?
                @hsjzyangbin said:
                HI,TIG,is there have some difference between trigulate face .rb and Manifold v1.4?
                If the read the notes in the first post... 'manifold' does triangulate faces at the end, BUT it does so much more - it tidies the shapes to remove faceless edges, remove flaps, remove disconnected geometry, heal holes and very small faces, orient faces and then triangulates, and finally 'reports' on what it's done.
                It is an attempt to automate the making of a 'manifold' surfaced mesh that will work properly when it's exported for use in a 3D printer, and some other 3D apps...
                It's still under development...
                • O
                  otb designworks
                  You are the Man, TIG!
                  This plug in is a great great idea.
                  Cheers, Chuck
                  Cheers, Chuck
                  OTB Designworks is on Youtube
                    Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                    Various adjustments on speed, reporting, lingvo etc...
                    Still need to sort out 'pretzels' better... πŸ˜’
                      driven
                      Cheers TIG,
                      I was just logging in to say, I've set up one of my Macs, with a fresh instal and only a few basic rubies that I've triple checked are clean. Just to test Manifold. That way any log errors on my system console should be easily spotted, and you posted this, so excellent timing. I'll keep you informed. john
                        driven
                        Can you PM that file so I can test it too... ❓
                        Don't bother - I made one like it and I see the problem πŸ˜’
                          driven
                          inner face left
                          Fresh off the press, No error messages in console, had lots of info zipping through, had Pass dialogs, so all seems to be functioning, but all passed have inner faces? john
                          EDIT: I did the first with Transparency ON, so just in case it wasn't see the faces I re-did with Trans OFF, but the faces are still inside and the orientation is different from first
                          turned transparency off, orientations flip
                            Here's v1.6 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                            Face making error fixed, 3-edge faces removal improved.
                            Sub-groups/Instances now within Group removed & reported.
                            Error reporting improved.
                              driven
                              Hi TIG,
                              I think it's working really nicely now, lot faster, plenty of info, it still passes inner faces that don't necessarily break the 1 edge, 2 face rule.
                              There are only two '4-faced' edges in the original drawing and if a BoolTool, VWS, or a manual delete is done first, (as it should be) than manifold does a speedy and detailed correction, orientation and triangulation. I'm wondering if a simple pre-flight check that states, "I'm not doing this-there are inner faces highlighted that you need to remove first" or something less long winded, might not be in order. I'll PM you some other screen shot's as well.
                              acid test
                              Am I the only one testing this????
                                Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                                It now does a quick initial 'Health-Check' on the group and a dialog reports - it also temporarily shows any probable 'internal faces' in Magenta and faces adjoining probable 'holes' in Cyan etc...
                                If it's a lot of errors you can answer 'No' to not continue and then attempt to fix them manually, before trying again - or answer Yes to continue if there are no problems identified, or answer Yes anyway to try and auto-fix any problems [with a final error report and red/green/.../-.- highlighting in an "error-group"]...
                                πŸ€“
                                  driven
                                  TIG....do you sleep???
                                  • O
                                    otb designworks
                                    any chance this can be adjusted to not triangulate all faces? It is very useful for me to be able to clean up a model that I have carefully constructed so that I have consistent quads everywhere, which is what I need for sending into ZBrush for further detail modeling.
                                    I know that Cheetah, too, triangulates everything when performing boolean functions, which I also find annoying. It is this, more than anything, that keeps me away from automated solutions for ensuring manifold meshes.
                                    Cheers, Chuck
                                    Cheers, Chuck
                                      Cheers, Chuck
                                      I'll add triangulation as a closing option ? πŸ€“
                                      • O
                                        otb designworks
                                        That would be quite useful, for me.
                                        Now, how about a plug-in that cuts a model up into beautifully perfect quads? I'd pay cold hard cash for that one, too.
                                        Thanks TIG!
                                        Cheers, Chuck
                                          Here's v1.8 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                                          Triangulation is now an option near the end - Answer Yes to do it... πŸ€“
                                            driven
                                            TIG,
                                            slight problem, when choosing Yes to continue after an 'initial health check' pass, it zapps everything even unselected groups.... both on badly grouped and clean booled groups, I'll do some more and send pics.
                                            I'll see if it still happening in 1.8
                                            • 4 / 7
