    [Plugin] Manifold v2.2
    126 Posts 19 Posters 78.6k Views 19 Watching
      driven
      inner face left
      Fresh off the press, No error messages in console, had lots of info zipping through, had Pass dialogs, so all seems to be functioning, but all passed have inner faces? john
      EDIT: I did the first with Transparency ON, so just in case it wasn't see the faces I re-did with Trans OFF, but the faces are still inside and the orientation is different from first
      turned transparency off, orientations flip
        Here's v1.6 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
        Face making error fixed, 3-edge faces removal improved.
        Sub-groups/Instances now within Group removed & reported.
        Error reporting improved.
          driven
          Hi TIG,
          I think it's working really nicely now, lot faster, plenty of info, it still passes inner faces that don't necessarily break the 1 edge, 2 face rule.
          There are only two '4-faced' edges in the original drawing and if a BoolTool, VWS, or a manual delete is done first, (as it should be) than manifold does a speedy and detailed correction, orientation and triangulation. I'm wondering if a simple pre-flight check that states, "I'm not doing this-there are inner faces highlighted that you need to remove first" or something less long winded, might not be in order. I'll PM you some other screen shot's as well.
          acid test
          Am I the only one testing this????
            Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
            It now does a quick initial 'Health-Check' on the group and a dialog reports - it also temporarily shows any probable 'internal faces' in Magenta and faces adjoining probable 'holes' in Cyan etc...
            If it's a lot of errors you can answer 'No' to not continue and then attempt to fix them manually, before trying again - or answer Yes to continue if there are no problems identified, or answer Yes anyway to try and auto-fix any problems [with a final error report and red/green/.../-.- highlighting in an "error-group"]...
              driven
              TIG....do you sleep???
              • O
                otb designworks
                any chance this can be adjusted to not triangulate all faces? It is very useful for me to be able to clean up a model that I have carefully constructed so that I have consistent quads everywhere, which is what I need for sending into ZBrush for further detail modeling.
                I know that Cheetah, too, triangulates everything when performing boolean functions, which I also find annoying. It is this, more than anything, that keeps me away from automated solutions for ensuring manifold meshes.
                Cheers, Chuck
                Cheers, Chuck
                OTB Designworks is on Youtube
                  Cheers, Chuck
                  I'll add triangulation as a closing option ? 🤓
                  • O
                    otb designworks
                    That would be quite useful, for me.
                    Now, how about a plug-in that cuts a model up into beautifully perfect quads? I'd pay cold hard cash for that one, too.
                    Thanks TIG!
                    Cheers, Chuck
                      Here's v1.8 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                      Triangulation is now an option near the end - Answer Yes to do it... 🤓
                        driven
                        TIG,
                        slight problem, when choosing Yes to continue after an 'initial health check' pass, it zapps everything even unselected groups.... both on badly grouped and clean booled groups, I'll do some more and send pics.
                        I'll see if it still happening in 1.8
                          @driven said:
                          TIG,
                          Odd - I can't get it to error at all... 😕 Please 'feedback'.............
                            driven
                            @tig said:
                            Odd - I can't get it to error at all... :? Please 'feedback'.............
                            been trying to up load pics, site is slow, pics to follow
                            it's on both machines, 1.7 and 1.8
                            3 groups from Draw Shapes Menu, grouped, manifold_1.7and8, both give a pass
                            [attachment=0:19dcyp32]<!-- ia0 -->3 groups inside group_1.jpg<!-- ia0 -->[/attachment:19dcyp32]
                            Yes to continue....zapppp
                            Same 3 groups, exploded then regrouped is running as predicted on other mac at the moment, this site is slow from this machine....
                              driven
                              the first and last zap the drawing clean, i.e. everything goes
                                driven
                                something screwy going on with uploads, sorry it makes thing disjointed
                                  I get no problems... but can you PM me that model asap, so that I have exactly the same starting point... 😕
                                  The 'no problems found' report is on any geometry that hasn't already be relegated to 'red'... looks like everything is removed BEFORE we do the health check - it's not a group inside a group is it ?
                                    driven
                                    TIG,
                                    they were groups inside a group, and got a pass, (they are all manifold) it only zaps them if you say YES,
                                    the same thing happened after I BoolTool'd all 3 groups into 1 group, initial pass (as it should), but zapped if you choose YES, I only got the RED on that one drawing, I'll re run the first set-up and post the if no red is shown again.
                                    I have just set a Bool'd group run that Passed initial and didn't blitz the drawing when I hit YES
                                    It's on a pair of torus + geodasic sphere bool group, and it is running.
                                    original set ungrouped, but not booled
                                    and others work so smoothly
                                      Here's v1.9 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                                      It now traps for 'No Geometry' inside the Group... 🤓
                                        driven
                                        NO Zapping with 1.9... is it possible for the health check to report 'NO geometry to Check because the selection contains sub-groups'?
                                        I'll try some other breakers I've been working on...
                                        cheers john
                                          driven
                                          TIG,
                                          I've got a couple of test on the go, I'll report on them when they're cooked.
                                          some additional ?'s
                                          which should be faster for manifold, simply continuing after fail or a manual repair than re-test continue
                                          would it be possible to choose bothquad's and tri's as two separate groups, if you have two different post destinations for the object?
                                          or would EraseCoplanar on a copy of a Tri'd group give identical mesh results?
                                            driven
                                            TIG- found the problem with the Bool'd groups -BT can create a group inside a group when bool-ing more than two groups, which I should have spotted in Outliner.
                                            When manifold highlighted RED and said 'NO' I simply exploded the extra group and answered my earlier ?, it was much faster on the bool'd group and I assume would be the similar on a manually repaired group.
                                            Note for users: The manual option also gives more control over the mesh shape at the torus/box intersection.
                                            Basically TIG you've done a fantastic job on this, thank you
                                            I'm convinced you, Chuck, and I won't be the only end-user's for this, it has soo many uses.
                                            for now I'll keep putting up images that help or hinder, and get back to some bent text testing....
                                            do you think it's ready for a wider audience yet, I'm planing on trying to do a tutorial when your happy?
                                            un-intersected single groupinitial test picked up the buried group and then 'presto'
                                            ADD: it's what I thought re: tri/quads, just thought I'd ask
                                            • 5 / 7
