    [Plugin] Manifold v2.2
    126 Posts 19 Posters 69.3k Views 19 Watching
      d12dozr
      I just installed it...164 MB! I'll run some tests but if you have some models you know you are are having problems with, send them to me...easier than me starting over from scratch πŸ˜„
      http://goo.gl/f7ooYh
        driven
        @d12dozr said:
        I just installed it...164 MB! I'll run some tests but if you have some models you know you are are having problems with, send them to me...easier than me starting over from scratch πŸ™‚
        the 'pretzel' is posted up the top, TIG's name on front, that gives trouble on careful examination, small triangles round the back, I think... I've got harder tests but one step at a time, I got ahead of myself....
        TIG......THIS IS SO FAST... I didn't have time to start the stopwatch on the boxes.....CHEERS
        anyhow, more testing...
          Jim
          What does the word "manifold" mean in this context? I gather "water-tight", but is it more than that?
            driven
            Yes , and tons of info at wikipedia, but the way I described to my six year old if the computer trying to find the walls of a room from the inside and the window is open it will precede to circumnavigate the earth until it gets back to where it started and then panic... she believed me...
              Manifold means 'many' or 'of many parts' - it's also a type of thin typing paper !
              But in the sense of a 3D mesh it means 'whole', 'complete', 'imperforate', 'without holes, imperfections, complexities or sub-elements'... from the Mathematical term "Manifold: a Topological surface or space that is connected and locally Euclidean"...
              Ironically its 'antonym' is 'simple or single', which is exactly what we are trying to achieve with the processed mesh !!!
                driven
                TIG, no dialogs and I get this that I haven't had before,
                27/01/2010 16:26:58 [0x0-0x6f06f.com.google.sketchupfree7[925] #<NoMethodError: undefined method flattenUVQ' for #<Manifold:0x1e6005a4>> 27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:580:in triangulateFace'
                27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:574:in each' 27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:574:in triangulateFace'
                27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:621:in triangulate_faces' 27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:619:in each'
                27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:619:in triangulate_faces' 27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:112:in activate'
                27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:701:in select_tool' 27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:701:in manifold'
                27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:716]
                  I haven't changed that ? It's trying to map textures back onto triangulated faces properly ??? I'll investigate...
                  Avoid textured faces for now...
                    driven
                    TIG,
                    I have had it before, I just went back through the logs and buried in there is the same report, at least for 1.3, 1.4
                      driven
                      A re-start found the dialogs, so 1.3 would not pass this (which is correct) due to more then 2 faces per edge, also reversed faces made it through...
                      passed???
                        driven
                        Here's a semi complex one that sort of worked with 1.2, but on 1.3 it would only hang....
                        I might get this one printed in stainless, should only cost $100, and I can't think how else to make it.
                        I'm about to re-test it on my Mac and a PC comparison would show up if some of the problems are me or not...
                        If it fails first try, manually orient the reversed faces, then remove the internal disc on the bottom run and try again.
                        it 'should' remove the internal overlap on the bottom 2/3 twists (1.2 left these intact)
                        it might still make a hash of the end, Fredo's bend tool can be unkind to meshes.
                        I been running it without manual repairs
                        • H Offline
                          hsjzyangbin
                          HI,TIG,is there have some differece between trigulaer face .rb and Manifold v1.4?
                            @hsjzyangbin said:
                            HI,TIG,is there have some difference between trigulate face .rb and Manifold v1.4?
                            If the read the notes in the first post... 'manifold' does triangulate faces at the end, BUT it does so much more - it tidies the shapes to remove faceless edges, remove flaps, remove disconnected geometry, heal holes and very small faces, orient faces and then triangulates, and finally 'reports' on what it's done.
                            It is an attempt to automate the making of a 'manifold' surfaced mesh that will work properly when it's exported for use in a 3D printer, and some other 3D apps...
                            It's still under development...
                            • O Offline
                              otb designworks
                              You are the Man, TIG!
                              This plug in is a great great idea.
                              Cheers, Chuck
                              Cheers, Chuck
                              OTB Designworks is on Youtube
                                Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                                Various adjustments on speed, reporting, lingvo etc...
                                Still need to sort out 'pretzels' better... πŸ˜’
                                  driven
                                  Cheers TIG,
                                  I was just logging in to say, I've set up one of my Macs, with a fresh instal and only a few basic rubies that I've triple checked are clean. Just to test Manifold. That way any log errors on my system console should be easily spotted, and you posted this, so excellent timing. I'll keep you informed. john
                                    driven
                                    Can you PM that file so I can test it too... ❓
                                    Don't bother - I made one like it and I see the problem πŸ˜’
                                      driven
                                      inner face left
                                      Fresh off the press, No error messages in console, had lots of info zipping through, had Pass dialogs, so all seems to be functioning, but all passed have inner faces? john
                                      EDIT: I did the first with Transparency ON, so just in case it wasn't see the faces I re-did with Trans OFF, but the faces are still inside and the orientation is different from first
                                      turned transparency off, orientations flip
                                        Here's v1.6 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                                        Face making error fixed, 3-edge faces removal improved.
                                        Sub-groups/Instances now within Group removed & reported.
                                        Error reporting improved.
                                          driven
                                          Hi TIG,
                                          I think it's working really nicely now, lot faster, plenty of info, it still passes inner faces that don't necessarily break the 1 edge, 2 face rule.
                                          There are only two '4-faced' edges in the original drawing and if a BoolTool, VWS, or a manual delete is done first, (as it should be) than manifold does a speedy and detailed correction, orientation and triangulation. I'm wondering if a simple pre-flight check that states, "I'm not doing this-there are inner faces highlighted that you need to remove first" or something less long winded, might not be in order. I'll PM you some other screen shot's as well.
                                          acid test
                                          Am I the only one testing this????
                                            Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                                            It now does a quick initial 'Health-Check' on the group and a dialog reports - it also temporarily shows any probable 'internal faces' in Magenta and faces adjoining probable 'holes' in Cyan etc...
                                            If it's a lot of errors you can answer 'No' to not continue and then attempt to fix them manually, before trying again - or answer Yes to continue if there are no problems identified, or answer Yes anyway to try and auto-fix any problems [with a final error report and red/green/.../-.- highlighting in an "error-group"]...
                                            πŸ€“
                                            • 4 / 7
