    Need help Please!
    27 Posts 8 Posters 3.2k Views 8 Watching
      roadie3rd
      Why did i agree to do this for my father inlaw 😲 😕
      thought id get some brownie points stacked up for future use but obviously its proving harder than expected
      Just so people know this is what im trying to create in sketchup
      http://www.mcs-justright.org.uk/Libraries/Hotpics/The_Boat.sflb.ashx
      http://www.mcs-justright.org.uk/Libraries/Building_the_boat_over_the_years/Summer_09_New_hatch_in_place.sflb.ashx
      http://www.mcs-justright.org.uk/Libraries/Building_the_boat_over_the_years/06_New_look_coachroof.sflb.ashx
      Im finding it quite hard to get the hull started. Tigs help is great many thanks and has got me started a bit but im still finding it hard to get my head round
      Thanks for all the help anymore would be greatfully accepted
      Cheers Mark 👍
        roadie3rd
        numbthumb wrote:
        Take a look at this and see if it helps viewtopic.php?f=323&t=6708&st=0&sk=t&sd=a&hilit=joint+push+pull
        Ive tried this and it keeps crashing the model and shutting sketchup
        i think the model is too complex and has a spas attack and closes it.
        Cheers anyway is a useful plugin
        Mark 👍
          What the name of the boat model?
          • ely862meE Offline
            ely862me
            Roadie,first of all u should be sure to find and download some blueprints(without them is very hard),then search for lot of reference images,then(but not last) u should have some average skills in sketchup..and only after these steps start building it. imho
            All the best!
            Elisei
            Elisei (sketchupper)
            Come and See EliseiDesign
            • numbthumbN Offline
              numbthumb
              Or maybe you can give this a try http://www.delftship.net/delftship/index.php?option=com_content&view=article&id=31:delftship-free&catid=13:products&Itemid=4
              It exports .DXF, and .OBJ AFAIK, so you can load these in SU.
              Comfortably numb...
                roadie3rd
                Ive got the plans he built the boat to which are printouts which ive caded up the drawings in autocad. The guy who designed the boat drew it all by hand old school style and doesnt have downloadable plans. Plus you have to pay for the plans which is about £500
                I have loads of images ive taken of the boat and have been given by my father inlaw
                I have average skills in solidworks as i use it at work for architecture concepts but its mostly straight lines and curves not organic shapes. Ive used sketchup lots but cant get my head around the the hull shape and making it work. Ive drawn the majority of the other bits to attach to the hull but the hull is the most important bit.
                Mark
                  roadie3rd
                  Its a Golant Gaffer
                    roadie3rd
                    cheers for this ill give it a go on the weekend
                      roadie3rd
                      ive found these pics if people want them
                      full side
                      top/side
                        Jim
                        Give the guy a break - he doesn't know where to start. Posting a model of a completed hull (even if it lacks accuracy) doesn't help much because it doesn't show how to set it up.
                        • ely862meE Offline
                          ely862me
                          I don t see u struggling too much making it..
                          Here is the hull,if i don t see you finishing it ,means u don t wanna make it..
                          Happy sketching!
                          Elisei
                          Golant Gaffer hull by EliseiDesign.skp
                          BTW The halves are components,u can just work at one of them and the other will update by itself.
                          EDITED: A small mistake i made without my will, model uploaded again .
                          • ely862meE Offline
                            ely862me
                            Jim,in this case...should i remove the files?
                            Roadie,sorry if i m(was) a bit harsh to you!
                            All the best!
                            Elisei
                              mac1
                              Its a Golant Gaffer
                              roadie3rd
                              Additi0nal info for you ref problen areas:http://sketchup.google.com/3dwarehouse/details?mid=1f56117edc6c5690ab9c83967811b1f7 It looks to me like a problem with the rail profiles 3 to 4 down. I used the shown cutting plane to get intersection points with the rails . You should then be able to create good bulk head profiles for TIG's suggestion pending issue with the rails
                                Jim
                                All the best!
                                Elisei
                                No no, you were not harsh. I think this is a tough model to start with.
                                  chrisjk
                                  Elisei,
                                  I'd be interested to learn how you did the modelling of the surface. I can't get it that smooth. I used TIG's EEBR and as can be seen, I get "pleats" at the front.
                                  http://woodgen.smugmug.com/Other/MIsc-Forum-posts-1/Screen-shot-2010-01-29-at/776096510_ySzMU-L.png
                                    Make several equally segmented 'bulkheads' and so it in pieces...
                                    Profile 2 for one becomes profile 1 for the next - split the rails a long the 'keel' and 'side' ❓
                                      chrisjk
                                      Thanks TIG.
                                        Jim
                                        The mesh in the first post isn't very clean - there are many edges that are not connected to anything, and many that do not actually intersect. You really need to get in close to find them, but they are there. It might explain some of the results of using some of the plug-ins.
                                        Is this sort of thing a use for TIG's manifold plug-in?
                                          mac1
                                          All of the rail ( cline) profiles do not intersect( except some places at the ends) with the bulkheads and if one uses a cutting plane and tries to create them there are points that look obviously out of place. Trying to fill in with a bezier curve can be done but the hull then is not correct. Working with the orginal post model with out correcting the profiles and itersection will probably result in problems just getting worse IMHO.
