    Need help Please!
    27 Posts 8 Posters 3.2k Views 8 Watching
      roadie3rd
      Hi to all
      Im trying to create a sketchup model for my father inlaw who is going to be sailing from plymouth (uk) to rhode island (usa) single handed in a 20 foot gaffer rig (which he built himself) in May 2010 and he wanted something he could use as a promotion tool to raise funds for macmillan cancer support http://www.mcs-justright.org.uk/Default.aspx
      Ive created the initial mesh from plans of the boat he gave me but the hull meshing is proving to be a pain
      ive created a line mesh from autocad and imported it into sketchup (not a problem)
      Edited it in sketchup
      Then when i go to sandbox it it comes out with jagged mesh (looks terrible)
      id love it if someone could take a look at my model and see if they can have any luck with it or point me in the right directionBoat Hull Model
      Many thanks in advance
      Mark
        Seems the more speedy is redraw over with BZ spline by fredo6 (take the F SPline)
        So you have just to pick the intersections or inflextions for horizontal lines!
        Some vertical lines can be "weld" (by rick Wilson) by selection
        Not a big deal!
        in 10 minutes you can make that πŸ˜‰
          roadie3rd
          Thanks Pilou tried all that but still did the same
          see attached model
          any other ideas?
          Problem model
            mac1
            see attached model
            any other ideas?
            Here is a possible approach using the plugin skin http://sketchup.google.com/3dwarehouse/details?mid=356919293504215ab9c83967811b1f7 I only selected the rails at the separation shown to reduce time because once the stitches are made the segments created will take some time to select for that tool. Reducing the number of rails and using this plugin may give you acceptable results.
            Some other observation: There were 24 stray lines ( used stray line plugin) mostly where ribs are not connected to the rails and 50 broken lines. I repaired the broken lines but the sandbox tool was still giving the peaks. Don't know if the former is causing your problem; your primitives ( lines) are showing on the surrond layer. They should be on layer 0. All drawing should be there and layers only used for visibility control of groups/ components. Number of segments( 120) on the rail seems excessive to me for large radius of curvature ?
            Getting late will play with your model tomorrow AM
              roadie3rd
              Thanks mac1
              your a star
              looks good
              Many thanks
              Mark
                Here's a quick version using my EEbyRails.
                You need to simplify the 'skeleton' into profiles across the boat [bulkheads?] and rails down the 'keel' and the 'bows'.
                Make each of these a curve using weld.
                Try to keep the same number of segments in the profiles/rails - you haven't got that currently and a 'lumpy' mesh results where the various grouped meshed meet and need exploding together at the end...
                Do a pair of profiles and rails in turn until you have completed the 'hull'.
                Make it a component and mirror the halves together... β˜€boat.pngboat.skp
                  roadie3rd
                  Thanks TIG
                  I'm really sorry to be a pain again
                  This is my first attempt at an 'organic' shape and im finding it quite tricky
                  how would I give the hull a thickness of say 60mm to the outside edges is this possible?
                  If so how
                  Cheers Mark
                  • numbthumbN Offline
                    numbthumb
                    Take a look at this and see if it helps http://forums.sketchucation.com/viewtopic.php?f=323&t=6708&st=0&sk=t&sd=a&hilit=joint+push+pull
                    Comfortably numb...
                      roadie3rd
                      Why did i agree to do this for my father inlaw 😲 πŸ˜•
                      thought id get some brownie points stacked up for future use but obviously its proving harder than expected
                      Just so people know this is what im trying to create in sketchup
                      http://www.mcs-justright.org.uk/Libraries/Hotpics/The_Boat.sflb.ashx
                      http://www.mcs-justright.org.uk/Libraries/Building_the_boat_over_the_years/Summer_09_New_hatch_in_place.sflb.ashx
                      http://www.mcs-justright.org.uk/Libraries/Building_the_boat_over_the_years/06_New_look_coachroof.sflb.ashx
                      Im finding it quite hard to get the hull started. Tigs help is great many thanks and has got me started a bit but im still finding it hard to get my head round
                      Thanks for all the help anymore would be greatfully accepted
                      Cheers Mark πŸ‘
                        roadie3rd
                        numbthumb wrote:
                        Take a look at this and see if it helps viewtopic.php?f=323&t=6708&st=0&sk=t&sd=a&hilit=joint+push+pull
                        Ive tried this and it keeps crashing the model and shutting sketchup
                        i think the model is too complex and has a spas attack and closes it.
                        Cheers anyway is a useful plugin
                        Mark πŸ‘
                          What the name of the boat model?
                          • ely862meE Offline
                            ely862me
                            Roadie,first of all u should be sure to find and download some blueprints(without them is very hard),then search for lot of reference images,then(but not last) u should have some average skills in sketchup..and only after these steps start building it. imho
                            All the best!
                            Elisei
                            Elisei (sketchupper)
                            Come and See EliseiDesign
                              numbthumb
                              Or maybe you can give this a try http://www.delftship.net/delftship/index.php?option=com_content&view=article&id=31:delftship-free&catid=13:products&Itemid=4
                              It exports .DXF, and .OBJ AFAIK, so you can load these in SU.
                              Comfortably numb...
                                roadie3rd
                                Ive got the plans he built the boat to which are printouts which ive caded up the drawings in autocad. The guy who designed the boat drew it all by hand old school style and doesnt have downloadable plans. Plus you have to pay for the plans which is about Β£500
                                I have loads of images ive taken of the boat and have been given by my father inlaw
                                I have average skills in solidworks as i use it at work for architecture concepts but its mostly straight lines and curves not organic shapes. Ive used sketchup lots but cant get my head around the the hull shape and making it work. Ive drawn the majority of the other bits to attach to the hull but the hull is the most important bit.
                                Mark
                                  roadie3rd
                                  Its a Golant Gaffer
                                    roadie3rd
                                    cheers for this ill give it a go on the weekend
                                      roadie3rd
                                      ive found these pics if people want them
                                      full side
                                      top/side
                                        Jim
                                        Give the guy a break - he doesn't know where to start. Posting a model of a completed hull (even if it lacks accuracy) doesn't help much because it doesn't show how to set it up.
                                        • ely862meE Offline
                                          ely862me
                                          I don t see u struggling too much making it..
                                          Here is the hull,if i don t see you finishing it ,means u don t wanna make it..
                                          Happy sketching!
                                          Elisei
                                          Golant Gaffer hull by EliseiDesign.skp
                                          BTW The halves are components,u can just work at one of them and the other will update by itself.
                                          EDITED: A small mistake i made without my will, model uploaded again .
                                          • ely862meE Offline
                                            ely862me
                                            Jim,in this case...should i remove the files?
                                            Roadie,sorry if i m(was) a bit harsh to you!
                                            All the best!
                                            Elisei
