    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 769.3k Views 175 Watching
    • TIGT Online
      @arc said:
      Here is video I created tut use EEBR.
      Arc - it's reporting as 'blocked in your region' - at least in the UK...
        sunchart
        Thank u very much.
          And I get just a white square. (Norway)
          • TIGT Online
            Pilou has updated all 4 of the FR lingvo files - they'll be included in future updates but if you want to install them straightaway then download this zip file and extract the 4 files into ../Plugins/TIGtools/ and overwrite any earlier copies...
            Tip: If you want the FR language for the tools' dialogs and prompts etc BUT have your locale set to another id - e.g. EN-US - then simply rename the file with that suffix and it'll be used... e.g. XxxxFR.lingvo becomes XxxxEN-US.lingvo
            Extrusion Tools FRlingvos.zip
            • ArcA Offline
              Arc
              [flash=500,405:130oyn5u]http://www.youtube.com/v/DFzteN0CvrA&hl=zh_CN&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:130oyn5u]
              • ArcA Offline
                Arc
                Now I upload video on youtube.
                • TIGT Online
                  Thanks, it works fine now - a quick and useful insight into just one way of using EEbyRails... 😄
                    And it's a cool video, too! 👍
                    First I thought I would hate that there is music with it but then I even liked it!
                    • MALAISEM Offline
                      MALAISE
                      Hurrah for TIG 😍
                      MALAISE
                      • TIGT Online
                        http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                        Is the latest update - the main changes are updated lingvo files and in EEbyR a picking order glitch has been fixed.
                        See the individual tools' threads' links for more details... ☀
                        • mitcorbM Offline
                          mitcorb
                          @Arc:
                          Nice video!!! Music was pleasant enough, just not my style 😄
                          Would love to see the process between the completion of the crescent and the final product, perhaps in another thread.
                          • jeff hammondJ Offline
                            hey TIG,
                            is the zip updated as well?
                            personally, it's easier to update the entire suite instead of individually (even if only one of the tools have been updated) because i can just overwrite everything instead of having to open the TIGtools folder and only overwrite certain files.
                            • TIGT Online
                              hey TIG,
                              http://forums.sketchucation.com/viewtopic.php?p=217663#p217663 links to a zip of everything current today [in this thread] - see the suffix on zip's name... This time I also updated each tools' thread too - from now on I'll probably keep the combo zip up to date, and then remove any zips from the four tools' threads - bt keeping the threads' links for the tools' instruction/version-info parts only...
                              So there's no need to get the other tool zips... IF you get the combo-zip here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                cool, thanks
                                i think that's the best way to keep everyone up to date. (vs 4 individual threads/tools)
                                  driven
                                  Cheers TIG,
                                  zip Combo works first time out on the Mac, great to see them altogether now, well done...
                                  still get the 5th button? maybe Jeff could see if it replicates on his Mac.
                                  Jeff, if I open SU with the toolbar off, and then open it I get 4 EEby... tool buttons, if I open SU having not turned off EEby...TB before quiting, I get a 5th button, it does nothing except changes colour, everthing works if it's there or not, would you mind checking before I fresh install everything again? it might be a Mac thing...
                                  • N Offline
                                    notareal
                                    Thanks, It's good to have just one archive that is needed to load.
                                    Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                      @driven said:
                                      Cheers TIG,
                                      i can't replicate it.. i always get only 4 toolbar buttons no matter what i do.
                                      i've done it on a PPC/tiger/SU6 & intel/leopard/SU7.
                                      could there be a conflict with another plugin causing this?
                                      • wind-borneW Offline
                                        wind-borne
                                        @driven said:
                                        Cheers TIG,
                                        following john's scenario, I can replicate.
                                        Maybe a new tool on the horizon 😆 👍
                                        "To read between the lines was easier than to follow the text."OSX 10.11.6
                                        %(#BF80BF)[SU 8 pro
                                          oh wait, if i give the toolbar a horizontal orientation then i do in fact get the extra button.. i keep all of my tool bars vertically on the left side and when done like that, it's always 4 buttons.
                                          if i move the 5 button bar to vertical prior to restarting , only 4 will show up after the relaunch.
                                            driven
                                            so it is a Mac thing, but quite harmless it seems, and I already asked TIG if it was a new tool pending (sorry no), I also stripped out all my rubies and then did a clean-instal of SU just to see if it would go-away, all to no avail. So I'm quite please it can be replicated... sort of.
                                            I'll try the vertical tip from Jeff and then forget all about.
                                            • 31
                                            • 32
                                            • 6 / 32
