    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 990.9k Views 175 Watching
      @chris fullmer said:
      And I get hate mail from people saying I don't speak clearly enough.
      ❓ 😲 Really? I've always thought you spoke very clearly in your videos. (They should hear me talking - then they'd shut up!) I have several times considered to offer to hire you to do some videos.
        That is the cherry on the cake! 😎
        • boofredlayB Offline
          boofredlay
          Chris, you need your own band playing while you do your tuts 😄
            @arc said:
            Here is video I created tut use EEBR.
            Arc - it's reporting as 'blocked in your region' - at least in the UK...
              sunchart
              Thank u very much.
                And I get just a white square. (Norway)
                  Pilou has updated all 4 of the FR lingvo files - they'll be included in future updates but if you want to install them straightaway then download this zip file and extract the 4 files into ../Plugins/TIGtools/ and overwrite any earlier copies...
                  Tip: If you want the FR language for the tools' dialogs and prompts etc BUT have your locale set to another id - e.g. EN-US - then simply rename the file with that suffix and it'll be used... e.g. XxxxFR.lingvo becomes XxxxEN-US.lingvo
                  Extrusion Tools FRlingvos.zip
                  • ArcA Offline
                    Arc
                    [flash=500,405:130oyn5u]http://www.youtube.com/v/DFzteN0CvrA&hl=zh_CN&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:130oyn5u]
                    • ArcA Offline
                      Arc
                      Now I upload video on youtube.
                        Thanks, it works fine now - a quick and useful insight into just one way of using EEbyRails... 😄
                          And it's a cool video, too! 👍
                          First I thought I would hate that there is music with it but then I even liked it!
                          • MALAISEM Offline
                            MALAISE
                            Hurrah for TIG 😍
                            MALAISE
                              http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                              Is the latest update - the main changes are updated lingvo files and in EEbyR a picking order glitch has been fixed.
                              See the individual tools' threads' links for more details... ☀
                              • mitcorbM Offline
                                mitcorb
                                @Arc:
                                Nice video!!! Music was pleasant enough, just not my style 😄
                                Would love to see the process between the completion of the crescent and the final product, perhaps in another thread.
                                • jeff hammondJ Offline
                                  hey TIG,
                                  is the zip updated as well?
                                  personally, it's easier to update the entire suite instead of individually (even if only one of the tools have been updated) because i can just overwrite everything instead of having to open the TIGtools folder and only overwrite certain files.
                                    hey TIG,
                                    http://forums.sketchucation.com/viewtopic.php?p=217663#p217663 links to a zip of everything current today [in this thread] - see the suffix on zip's name... This time I also updated each tools' thread too - from now on I'll probably keep the combo zip up to date, and then remove any zips from the four tools' threads - bt keeping the threads' links for the tools' instruction/version-info parts only...
                                    So there's no need to get the other tool zips... IF you get the combo-zip here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                      cool, thanks
                                      i think that's the best way to keep everyone up to date. (vs 4 individual threads/tools)
                                        driven
                                        Cheers TIG,
                                        zip Combo works first time out on the Mac, great to see them altogether now, well done...
                                        still get the 5th button? maybe Jeff could see if it replicates on his Mac.
                                        Jeff, if I open SU with the toolbar off, and then open it I get 4 EEby... tool buttons, if I open SU having not turned off EEby...TB before quiting, I get a 5th button, it does nothing except changes colour, everthing works if it's there or not, would you mind checking before I fresh install everything again? it might be a Mac thing...
                                        • N Offline
                                          notareal
                                          Thanks, It's good to have just one archive that is needed to load.
                                            @driven said:
                                            Cheers TIG,
                                            i can't replicate it.. i always get only 4 toolbar buttons no matter what i do.
                                            i've done it on a PPC/tiger/SU6 & intel/leopard/SU7.
                                            could there be a conflict with another plugin causing this?
                                            • 31
                                            • 32
                                            • 1 / 32
