    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 1.0m Views 175 Watching
    • GaieusG
      And it's a cool video, too! 👍
      First I thought I would hate that there is music with it but then I even liked it!
      • MALAISEM
        MALAISE
        Hurrah for TIG 😍
        MALAISE
          http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
          Is the latest update - the main changes are updated lingvo files and in EEbyR a picking order glitch has been fixed.
          See the individual tools' threads' links for more details... ☀
          • mitcorbM
            mitcorb
            @Arc:
            Nice video!!! Music was pleasant enough, just not my style 😄
            Would love to see the process between the completion of the crescent and the final product, perhaps in another thread.
            • jeff hammondJ
              hey TIG,
              is the zip updated as well?
              personally, it's easier to update the entire suite instead of individually (even if only one of the tools have been updated) because i can just overwrite everything instead of having to open the TIGtools folder and only overwrite certain files.
                hey TIG,
                http://forums.sketchucation.com/viewtopic.php?p=217663#p217663 links to a zip of everything current today [in this thread] - see the suffix on zip's name... This time I also updated each tools' thread too - from now on I'll probably keep the combo zip up to date, and then remove any zips from the four tools' threads - bt keeping the threads' links for the tools' instruction/version-info parts only...
                So there's no need to get the other tool zips... IF you get the combo-zip here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                • jeff hammondJ
                  cool, thanks
                  i think that's the best way to keep everyone up to date. (vs 4 individual threads/tools)
                    driven
                    Cheers TIG,
                    zip Combo works first time out on the Mac, great to see them altogether now, well done...
                    still get the 5th button? maybe Jeff could see if it replicates on his Mac.
                    Jeff, if I open SU with the toolbar off, and then open it I get 4 EEby... tool buttons, if I open SU having not turned off EEby...TB before quiting, I get a 5th button, it does nothing except changes colour, everthing works if it's there or not, would you mind checking before I fresh install everything again? it might be a Mac thing...
                    • N
                      notareal
                      Thanks, It's good to have just one archive that is needed to load.
                      • jeff hammondJ
                        @driven said:
                        Cheers TIG,
                        i can't replicate it.. i always get only 4 toolbar buttons no matter what i do.
                        i've done it on a PPC/tiger/SU6 & intel/leopard/SU7.
                        could there be a conflict with another plugin causing this?
                        • wind-borneW
                          wind-borne
                          @driven said:
                          Cheers TIG,
                          following john's scenario, I can replicate.
                          Maybe a new tool on the horizon 😆 👍
                          "To read between the lines was easier than to follow the text."OSX 10.11.6
                          %(#BF80BF)[SU 8 pro
                          • jeff hammondJ
                            oh wait, if i give the toolbar a horizontal orientation then i do in fact get the extra button.. i keep all of my tool bars vertically on the left side and when done like that, it's always 4 buttons.
                            if i move the 5 button bar to vertical prior to restarting , only 4 will show up after the relaunch.
                              driven
                              so it is a Mac thing, but quite harmless it seems, and I already asked TIG if it was a new tool pending (sorry no), I also stripped out all my rubies and then did a clean-instal of SU just to see if it would go-away, all to no avail. So I'm quite please it can be replicated... sort of.
                              I'll try the vertical tip from Jeff and then forget all about.
                                There MIGHT be a new tool coming... BUT it's nothing to do with that extra button !
                                • ken28875K
                                  ken28875
                                  Awesome tools, TIG.
                                  I have been using it a lot lately and love it. But I run into a problem each time. After using it, whenever I right click on an object, most of the functions are not working and i have to restart Sketchup. I wonder if it's a bug and if anyone else has experienced it.
                                  http://i593.photobucket.com/albums/tt12/ken28875/right_click_not_working.jpg
                                  Thanks,
                                  _KN
                                  Follow Your Dreams.
                                    Rip Tanion
                                    I've only really tried EEBR so far, but it's really cool and has a multitude of uses.
                                    Personally, I find a tutorial for EEBR unnecessary. I find the plug-in pretty straightforward and easy to use. Still, Arc did a good job with his vid.
                                      @ken28875 said:
                                      Awesome tools, TIG.
                                      _KN
                                      This is a known problem - BUT not related directly to any particular Plugin. The latest versions of SUp have a bug where the context-menu items can get 'grayed-out' after a number of repeated 'clicks' on objects; it might also be related to the number of plugins that you have installed.
                                      I also have the problem - the Edit menu last item repeats the context-menu without a glitch - but it is still annoying having to save and restart to fix it...
                                      The SUp team are onto it - hopefully a maintenance release will fix back it as it was... 😒
                                      • ken28875K
                                        ken28875
                                        Thanks, TIG.
                                        Follow Your Dreams.
                                        • JClementsJ
                                          JClements
                                          And I thought I was the only one having this problem! Thanks for mentioning it.
                                            d12dozr
                                            Thanks TIG, Just dl'd and played a bit. I like the zipped set...makes it so much easier. Cheers!
                                            http://goo.gl/f7ooYh
                                            • 31
                                            • 32
                                            • 2 / 32
