    [Plugin] Selection Toys
    594 Posts 121 Posters 565.6k Views 121 Watching
    • JClementsJ
      JClements
      Yeh, I edited my post because part of it didn't make sense. 😲
      Another Bug; Select Edge Loops?
      If after an edge loop is selected, then using the Layers Toolbar (PC) dropdown list to move the edge to a new layer does not work. Interestly though, using Entity Info to move the selected edge to a new layer does.
      [Edit]
      Select Default Front and Default Back not working?
        @jclements said:
        Hi Thom:
        Selection Tools must be a labor of love! πŸ˜„
        Selecting Instances on same layer (both all and active) not working? See attached.
        Confirmed and fixed internally.
        Thanks for reporting.
          Can't reproduce.
            @thomthom said:
            Can't reproduce.
            Saying that, as it works now, the edges also needs to have the same material for the Select Connected by Material to select the neighbouring face... Might have to revise this function. ...and I wonder why I haven't added one that doesn't select connected....
              [attachment=0:137w7llf]<!-- ia0 -->Layers Toolbar, PC.png<!-- ia0 -->[/attachment:137w7llf]
              This is very odd. But it seems to be a Sketchup bug. I can't see anything in my code that'd do this. And as you say, the Entitiy Info works. I'll try to forward this to Google.
                rv1974
                Hi!
                What I really missinng is option to select all edges bitween "90 degrees faces" (the exact degree number should be ajustable)
                  Ah - took me a little while to understand this one, but being able to select edges where the angle between connected faces are larger than a given angle?
                  This would be something that filters an existing selection? Or make a new selection in the active space?
                    rv1974
                    ...being able to select edges where the angle between connected faces are larger than a given angle?..
                    -yes
                    ...filters an existing selection?
                    -yes
                    • juan974J
                      juan974
                      good idea rv1974, kind of : "select string edges", useful for complicated shape
                      juan974 (RΓ©union island)
                      website : http://sketchucation.com/click.php?url=http://www.tarn.us
                      • N3TON
                        N3TO
                        Where can I download Seletcion Toys (2.1.0)???
                        thanks
                          thanks
                          Bottom of the first post on the first page of this thread.
                          • Dan RathbunD
                            Dan Rathbun
                            Selection Modifier
                            Selection Submenu - Currently there's two kinds of modifiers.
                            The explanations are a bit confusing for me... I have alot of experience in Electronic Radio Frequency / Broadcast Engineering, where Filters are a very important device. So when I think of Filters I think of them in that respect. See if you think I'm correct here:
                            One filters out the type of entity you want.
                            This would be a 'Pass' filter?
                            http://en.wikipedia.org/wiki/Band-pass_filter
                            The other deselects the entity you specify.
                            This is a 'Reject' Filter? (also sometimes called a 'Trap' or 'Notch' Filter from the way the signal looks on a Spectrum Analyser.)
                            http://en.wikipedia.org/wiki/Notch_filter
                            I'm not here much anymore.
                              I think so ... from what I understood of that definition of filters... unfamiliar territory to me.
                                DIEGO-RODRIGUEZ
                                hi tom.
                                a question
                                as I select only:
                                1 - Lines with a free end (no connection with another line or entity)
                                2 - lines with the two free ends (no connection with another line or entity, in its extreme ningudo)
                                http://img534.imageshack.us/img534/1747/sinttulo1zd.jpg
                                  arjunmax09
                                  please help me.... i'm not getting all the buttons in the toolbar... only able to get faces, edges, groups and component options
                                  when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                    Tools->Selection Toys->UI Settings
                                      @diego-rodriguez said:
                                      hi tom.
                                      a question
                                      as I select only:
                                      Never noticed this post.
                                      I'm adding it to my list.
                                        DIEGO-RODRIGUEZ
                                        I think it would be a useful tool for working with drawings imported from autocad.
                                        drawings with many lines, could detect lines, what not intersect
                                          File Not Found
                                          (www.smustard.com)
                                            DIEGO-RODRIGUEZ
                                            oooooo. πŸ˜„
                                            excellent, thank you very much. did not know
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 29
                                            • 30
                                            • 12 / 30
