    How to make a structural curvy roof [tutorial]
    24 Posts 13 Posters 20.4k Views 13 Watching
      Yes perfect for presentation โ˜€ but not for fabrication ๐Ÿ˜‰
      • mitcorbM
        mitcorb
        Pilou wrote: Problem of Didier's Plug is that intersections are not solved at any level of precision! ๐Ÿ˜ฎ
        (triangle, square,...circle ๐Ÿ˜’
        Pilou, I have been modelling pipes and cables on a roof with Lines2tubes. The roof area is full of mechanical equipment and pipes. What I do is use SU arc tool to fillet the angles, erase the segments after fitting the arcs, and then run the conversion. This makes the turns somewhat smooth--not perfect, but at the right viewing distances and the diameters of the pipes and cables at 1/2" or 2" or 3", it is sufficient for my "as-built" model. And I use this model for decisions on how to eliminate these pipes and cables in corrective construction.
        mitcorb
          @Mitcorb
          Of course! ๐Ÿ˜„
          I have written
          Depending of what you do you want
          ๐Ÿ˜‰
          Here the British Museum system shown on the first post ๐Ÿ˜‰
          http://communities.bentley.com/photos/matteosarroccos_images/images/58188/290x480.aspx
            Who would ever want to make fabrication information this way !
            It's only a 'model' !
            If you made it out of cardboard and balsa-wood you'd not make it exactly as it'll be made when full-size...
            If I were to make fabrication info using only SUp I'd detail typical elements and intersections separately, not in the overall model - that's only there to show us what it will look like, not how to build it !
            ๐Ÿค“
              Of course yes โ˜€
              But as computer permit to make any precise structures, if it's not a painful work this can be made in one time ๐Ÿ˜‰
              Who can make more can make less ๐Ÿ˜„
                Slimdog
                Yes looks simple for the architect or modeler but would be a hand full for the steel detailer and fabricator.
                  mambo.harts.u
                  Hello! I am also working on this kind of project. The thing is its a pretty big file ones you made the space frame by the lines2tube script. But if that's only way better stick to it!
                  My problem is, is there a way that i can reduce the file size so its would be easier to work on the whole project? Maybe reducing the poly lines or anything?
                  Any help is appreciated! TIA!!
                  • simon le bonS
                    simon le bon
                    I have worked on this.
                    I'm to explain it in Tutorial Section
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/dome001_kt_th.jpg
                    ๐Ÿ˜‰ simon
                    • simon le bonS
                      simon le bon
                      Done!
                      structural curvy roof answer
                      ๐Ÿ˜Ž
                        stevebo
                        Hi Pilou. Do you know where you got this image? I'm working on a project which will use a similar construction, and would love to get some details of the Great Court!
                          Here ๐Ÿ˜‰
                            stevebo
                            Merci Beaucoup ๐Ÿ˜„. Now time to learn to model this ***** ๐Ÿ˜„
                            • H
                              haynesc
                              @tig said:
                              Example...[attachment=1:9be683oa]<!-- ia1 -->CurvedRoof.png<!-- ia1 -->[/attachment:9be683oa][attachment=0:9be683oa]<!-- ia0 -->CurvedRoof.skp<!-- ia0 -->[/attachment:9be683oa]
                              this is really nice i would like to create a library of these sort of canopies and shade structures ...
                              • C
                                chang11234
                                Thank u every one. Final outcome of my project.
                                • GaieusG
                                  It's definitely gallery stuff - and not only the desig, the modelling excellence but even the presented style!
                                  Congrats!
                                    MattWidd
                                    Simon, can I download this model to look at?
