    How to make a structural curvy roof [tutorial]
    24 Posts 13 Posters 20.9k Views 13 Watching
    • daleD
      dale
      Looks like a gridshell. If your interested here is a link to the Downland Gridshell site.http://www.wealddown.co.uk/Buildings%20and%20Exhibits/gridshell/downland-gridshell-construction-progress.htm
        Example...CurvedRoof.pngCurvedRoof.skp
          Yes perfect for presentation โ˜€ but not for fabrication ๐Ÿ˜‰
          • mitcorbM
            mitcorb
            Pilou wrote: Problem of Didier's Plug is that intersections are not solved at any level of precision! ๐Ÿ˜ฎ
            (triangle, square,...circle ๐Ÿ˜’
            Pilou, I have been modelling pipes and cables on a roof with Lines2tubes. The roof area is full of mechanical equipment and pipes. What I do is use SU arc tool to fillet the angles, erase the segments after fitting the arcs, and then run the conversion. This makes the turns somewhat smooth--not perfect, but at the right viewing distances and the diameters of the pipes and cables at 1/2" or 2" or 3", it is sufficient for my "as-built" model. And I use this model for decisions on how to eliminate these pipes and cables in corrective construction.
            mitcorb
              @Mitcorb
              Of course! ๐Ÿ˜„
              I have written
              Depending of what you do you want
              ๐Ÿ˜‰
              Here the British Museum system shown on the first post ๐Ÿ˜‰
              http://communities.bentley.com/photos/matteosarroccos_images/images/58188/290x480.aspx
                Who would ever want to make fabrication information this way !
                It's only a 'model' !
                If you made it out of cardboard and balsa-wood you'd not make it exactly as it'll be made when full-size...
                If I were to make fabrication info using only SUp I'd detail typical elements and intersections separately, not in the overall model - that's only there to show us what it will look like, not how to build it !
                ๐Ÿค“
                  Of course yes โ˜€
                  But as computer permit to make any precise structures, if it's not a painful work this can be made in one time ๐Ÿ˜‰
                  Who can make more can make less ๐Ÿ˜„
                    Slimdog
                    Yes looks simple for the architect or modeler but would be a hand full for the steel detailer and fabricator.
                      mambo.harts.u
                      Hello! I am also working on this kind of project. The thing is its a pretty big file ones you made the space frame by the lines2tube script. But if that's only way better stick to it!
                      My problem is, is there a way that i can reduce the file size so its would be easier to work on the whole project? Maybe reducing the poly lines or anything?
                      Any help is appreciated! TIA!!
                      • simon le bonS
                        simon le bon
                        I have worked on this.
                        I'm to explain it in Tutorial Section
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/dome001_kt_th.jpg
                        ๐Ÿ˜‰ simon
                        • simon le bonS
                          simon le bon
                          Done!
                          structural curvy roof answer
                          ๐Ÿ˜Ž
                            stevebo
                            Hi Pilou. Do you know where you got this image? I'm working on a project which will use a similar construction, and would love to get some details of the Great Court!
                              Here ๐Ÿ˜‰
                                stevebo
                                Merci Beaucoup ๐Ÿ˜„. Now time to learn to model this ***** ๐Ÿ˜„
                                • H
                                  haynesc
                                  @tig said:
                                  Example...[attachment=1:9be683oa]<!-- ia1 -->CurvedRoof.png<!-- ia1 -->[/attachment:9be683oa][attachment=0:9be683oa]<!-- ia0 -->CurvedRoof.skp<!-- ia0 -->[/attachment:9be683oa]
                                  this is really nice i would like to create a library of these sort of canopies and shade structures ...
                                  • C
                                    chang11234
                                    Thank u every one. Final outcome of my project.
                                    • GaieusG
                                      It's definitely gallery stuff - and not only the desig, the modelling excellence but even the presented style!
                                      Congrats!
                                        MattWidd
                                        Simon, can I download this model to look at?
