    New API doc - typos and questions
    370 Posts 35 Posters 263.5k Views 35 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      The class Sketchup::HLR is undocumented in the API.
      It's an Entity subclass.
      It inherits all the Entity baseclass methods, and adds 2 of it's own:
      • .calculate* .num_faces
      If you create a HLR object at the console, and call .parent (when it has no parent) a BUG SPLAT! results. See post: http://forums.sketchucation.com/viewtopic.php?f=11&t=24740#p212101
      What is this class HLR used for? (.. as there is no .add_HLR method for the Entities collection object.)
      I'm not here much anymore.
        Tool.getExtents
        http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#getExtents
        The example given isn't a good one. From my observations, clipping occurs only when you draw outside the model boundary. So returning model.bounds is pointless.
          Dan Rathbun
          Sketchup.send_action
          http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#send_action
          You can toggle the StatusBar on/off in Ruby (PC only?) via:
          Sketchup.send_action(59393)
          The following have no effect on my PC in SU ver 7.1.x:
          Sketchup.send_action(21019) hide Status bar and VCB
          Sketchup.send_action(21020) show Status bar and VCB
          Sketchup.send_action(21022) hide Status bar and VCB?
          ..whereas the above id 59393 does work for just the StatusBar.
          [ NOTE: I've moved my VCB up to the 2nd line of the Top Toolbar Container in 2nd position after the Layers toolbar, so I'd not want the VCB turned off with the StatusBar anyhow. I see them as two different things. ]
            Dan Rathbun
            @dan rathbun said:
            (An alternative... we might create tb_Name constantsunder the UI module that would be the same for both platforms.)
            Here's an example, call it 'UI_tb_const.rb'
            module UI
            # Example ONLY
            case Sketchup;;OS
            when ;WIN
              tb_CAM = 'Camera'.freeze
              tb_CONS = 'Construction'.freeze
              tb_DISP = 'DisplayMode'.freeze
              tb_DRAW = 'Drawing'.freeze
              tb_EDIT = 'Edit'.freeze
              tb_GETS = 'GettingStarted'.freeze
              tb_GOOG = 'Google'.freeze
              tb_LTS = 'LargeToolSet'.freeze
              tb_LAYR = 'Layers'.freeze
              tb_STD = 'Standard'.freeze
              tb_TABS = 'SceneTabs'.freeze
              tb_PRIN = 'Principle'.freeze # spelling!
              tb_SBAR = 'StatusBar'.freeze
              tb_SECT = 'Section'.freeze
              tb_SHAD = 'Shadows'.freeze
              tb_VIEW = 'StandardViews'.freeze
              tb_VCB = 'VCB'.freeze
              tb_WALK = 'Walk'.freeze
            when ;OSX
            	#     what are the Mac Strings?
            end # case
            end # module UI extension
              Dan Rathbun
              UI.toolbar_names
              http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#toolbar_names
              The toolbar_names method is used to returns the name of all the available toolbars (this differs between PC and Mac).
              (1) In the above sentence "returns" should be singular.
              (2) I believe punctuation marks are supposed to go at the end of the words, ie: "Mac.)" not "Mac)." ...Language majors, confirm?
              (3) It would nice if we are to do cross-platform scripts, that you list the names for PC and Mac in the API.
              (4) UI.toolbar_names.sort on the PC, ver 7.1 returns:
              ["Camera", "Construction", "DisplayMode", "Drawing", "Edit", "GettingStarted", "Google", "Principle", "Section", "Standard", "StandardViews", "VCB", "Walk"]
              On the [Win32] Sketchup Menu: View > Toolbars(and toolbar captions):
              • Principle is Principal* Edit is Modification* VCB is Measurements* StandardViews is Views* Section is Sections* DisplayMode is FaceStyle* Walk is Walkthrough
                These are on the [Win32] Menu: View > Toolbars but, missing from the UI toolbar methods:
              • LargeToolSet* Layers* SceneTabs (on View menu )* Shadows
                Missing from View Menu and toolbar methods:
              • StatusBar
                (We can toggle it on/off [with send_action on PC], so might as well add it to the toolbar methods so we can test it's visiblilty, and use set_toolbar_visible for cross platform [if it can be toggled on MAC.])* If a user has the StatusBar off, a tool might want to instead display a messagebox if it must inform the user of some fact, so it needs to test whether it's on/off.
              (5) This same Toolbar Name Identifier Set is used with the following methods, and have the same problems, missing Identifiers, etc.
              • UI.set_toolbar_visible* UI.toolbar_visible?
              So.. we don't mind variation in the toolbar names/symbols, so long as we know what that variation is.
              (An alternative... we might create tb_Name constants under the UI module that would be the same for both platforms.)
                Entities.add_curve
                http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#add_curve
                Returns:
                curve a Curve object if successful
                SU7.1M1 PC returns an array of edges. Other versions untested. I'm submitting this as a bug.
                  Curve.move_vertices
                  http://code.google.com/apis/sketchup/docs/ourdoc/curve.html#move_vertices
                  The vertices method retrieves a collection of all vertices in a curve.
                  Seem to have copied the text from Curve.vertices.
                  Description needs updating along with an example.
                    @thomthom said:
                    Entities.add_curve
                    Returns:
                    It's always returned an array of edges - the curve is then array[0].curve
                      Dan Rathbun
                      _
                      Model.title
                      The tile method retrieves the name of the model. If the model is saved on disk, returns the file name without extension. Otherwise returns an empty string.
                      http://code.google.com/apis/sketchup/docs/ourdoc/model.html#title
                      Change 'tile' to 'title' in method description.
                      We could use Model.is_saved? and Model.is_unsaved? methods, as the Model.title method is the only way (that I can find) to determine if the model has yet been saved or not. We cannot rely upon the word 'Untitled' (in the caption bar) because that may actually be a valid filename.
                      Workaround:
                      class Sketchup;;Model
                      def is_saved?
                        return not title.empty?
                      def is_unsaved?
                        return title.empty?
                      end # class
                      _
                        Camera.set
                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#set
                        The initialize method is deprecated. It essentially does the same thing as Camera.set.
                        Seems that's the description for Camera.new http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#new
                        ...and that Camera.new has the description for Camera.set
                          View.pickray
                          http://code.google.com/apis/sketchup/docs/ourdoc/view.html#pickray
                          Returns:
                          ray
                          a ray
                          "a ray"? Without testing this I#m guessing either a vector or line.
                            Dan Rathbun
                            @thomthom said:
                            View.pickray
                            Returns:
                            ray a ray
                            see this...
                            Model.raytest
                            A ray is a two element array containing a point and a vector [Geom::Point3d(), Geom::Vector3d()]. http://code.google.com/apis/sketchup/docs/ourdoc/model.html#raytest
                            _
                              Yea - I tested it later that day. It's what the Geom module describes as a line.
                                Dan Rathbun
                                Shouldn't the API have a definition for Line and/or Ray as a class (under the Geom module) ?
                                something like:
                                class Geom;;Ray < Array
                                  def new(*args)
                                    Array[Geom;;Point3d().new, Geom;;Vector3d().new]
                                    super()
                                  Line and Plane? hm... maybe... thought of that myself. but never really felt the need for it to make a request. works fine as it is.
                                  Dealing with them as Arrays works ok. They are simple structures.
                                    Dan Rathbun
                                    Model.add_note
                                    The note is not displayed unless there are entities in the model. If you add a note first thing in a new model, it is invisible but .visible? on the note object still returns true.
                                    As soon as you draw something, the note appears.
                                      Jim
                                      Thanks Dan - yet more never-seen-before docs coming to light.
                                        I have the mental image of Scott drowning in printouts from this thread... πŸ˜’ πŸ˜†
                                          Jim
                                          Oh, I think there is a completely undocumented UTM class in there somewhere under Geom.
                                            hm.. all I can find out about that one is:
                                            Geom::UTM.instance_methods.sort.join("\n") (eval):894: warning: instance_methods: parameter will default to 'true' as of 1.8.1 to_a to_latlong to_s x y zone_letter zone_number
                                            • 18
                                            • 19
                                            • 8 / 19
