    New API doc - typos and questions
    370 Posts 35 Posters 355.3k Views 35 Watching
    • scottliningerS
      scottlininger
      Thanks for all the feedback, Dan! Keep 'em coming.
      • Scott Lininger
        SketchUp Software Engineer
        Have you visited the Ruby API Docs?
        How is your to-do list compared to Santa's list? πŸ˜†
        • scottliningerS
          scottlininger
          Santa's got nothing on me. πŸ˜‰
          • Scott Lininger
            Edge.reversed_in?
            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/edge.html#reversed_in?
            Why is the example using a begin rescue structure? Does it on occasion cause errors?
            • Dan RathbunD
              Dan Rathbun
              The class Sketchup::HLR is undocumented in the API.
              It's an Entity subclass.
              It inherits all the Entity baseclass methods, and adds 2 of it's own:
              • .calculate* .num_faces
              If you create a HLR object at the console, and call .parent (when it has no parent) a BUG SPLAT! results. See post: http://forums.sketchucation.com/viewtopic.php?f=11&t=24740#p212101
              What is this class HLR used for? (.. as there is no .add_HLR method for the Entities collection object.)
              I'm not here much anymore.
                Tool.getExtents
                http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#getExtents
                The example given isn't a good one. From my observations, clipping occurs only when you draw outside the model boundary. So returning model.bounds is pointless.
                • Dan RathbunD
                  Dan Rathbun
                  Sketchup.send_action
                  http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#send_action
                  You can toggle the StatusBar on/off in Ruby (PC only?) via:
                  Sketchup.send_action(59393)
                  The following have no effect on my PC in SU ver 7.1.x:
                  Sketchup.send_action(21019) hide Status bar and VCB
                  Sketchup.send_action(21020) show Status bar and VCB
                  Sketchup.send_action(21022) hide Status bar and VCB?
                  ..whereas the above id 59393 does work for just the StatusBar.
                  [ NOTE: I've moved my VCB up to the 2nd line of the Top Toolbar Container in 2nd position after the Layers toolbar, so I'd not want the VCB turned off with the StatusBar anyhow. I see them as two different things. ]
                  • Dan RathbunD
                    Dan Rathbun
                    @dan rathbun said:
                    (An alternative... we might create tb_Name constantsunder the UI module that would be the same for both platforms.)
                    Here's an example, call it 'UI_tb_const.rb'
                    module UI
                    # Example ONLY
                    case Sketchup;;OS
                    when ;WIN
                      tb_CAM = 'Camera'.freeze
                      tb_CONS = 'Construction'.freeze
                      tb_DISP = 'DisplayMode'.freeze
                      tb_DRAW = 'Drawing'.freeze
                      tb_EDIT = 'Edit'.freeze
                      tb_GETS = 'GettingStarted'.freeze
                      tb_GOOG = 'Google'.freeze
                      tb_LTS = 'LargeToolSet'.freeze
                      tb_LAYR = 'Layers'.freeze
                      tb_STD = 'Standard'.freeze
                      tb_TABS = 'SceneTabs'.freeze
                      tb_PRIN = 'Principle'.freeze # spelling!
                      tb_SBAR = 'StatusBar'.freeze
                      tb_SECT = 'Section'.freeze
                      tb_SHAD = 'Shadows'.freeze
                      tb_VIEW = 'StandardViews'.freeze
                      tb_VCB = 'VCB'.freeze
                      tb_WALK = 'Walk'.freeze
                    when ;OSX
                    	#     what are the Mac Strings?
                    end # case
                    end # module UI extension
                    • Dan RathbunD
                      Dan Rathbun
                      UI.toolbar_names
                      http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#toolbar_names
                      The toolbar_names method is used to returns the name of all the available toolbars (this differs between PC and Mac).
                      (1) In the above sentence "returns" should be singular.
                      (2) I believe punctuation marks are supposed to go at the end of the words, ie: "Mac.)" not "Mac)." ...Language majors, confirm?
                      (3) It would nice if we are to do cross-platform scripts, that you list the names for PC and Mac in the API.
                      (4) UI.toolbar_names.sort on the PC, ver 7.1 returns:
                      ["Camera", "Construction", "DisplayMode", "Drawing", "Edit", "GettingStarted", "Google", "Principle", "Section", "Standard", "StandardViews", "VCB", "Walk"]
                      On the [Win32] Sketchup Menu: View > Toolbars(and toolbar captions):
                      • Principle is Principal* Edit is Modification* VCB is Measurements* StandardViews is Views* Section is Sections* DisplayMode is FaceStyle* Walk is Walkthrough
                        These are on the [Win32] Menu: View > Toolbars but, missing from the UI toolbar methods:
                      • LargeToolSet* Layers* SceneTabs (on View menu )* Shadows
                        Missing from View Menu and toolbar methods:
                      • StatusBar
                        (We can toggle it on/off [with send_action on PC], so might as well add it to the toolbar methods so we can test it's visiblilty, and use set_toolbar_visible for cross platform [if it can be toggled on MAC.])* If a user has the StatusBar off, a tool might want to instead display a messagebox if it must inform the user of some fact, so it needs to test whether it's on/off.
                      (5) This same Toolbar Name Identifier Set is used with the following methods, and have the same problems, missing Identifiers, etc.
                      • UI.set_toolbar_visible* UI.toolbar_visible?
                      So.. we don't mind variation in the toolbar names/symbols, so long as we know what that variation is.
                      (An alternative... we might create tb_Name constants under the UI module that would be the same for both platforms.)
                        Entities.add_curve
                        http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#add_curve
                        Returns:
                        curve a Curve object if successful
                        SU7.1M1 PC returns an array of edges. Other versions untested. I'm submitting this as a bug.
                          Curve.move_vertices
                          http://code.google.com/apis/sketchup/docs/ourdoc/curve.html#move_vertices
                          The vertices method retrieves a collection of all vertices in a curve.
                          Seem to have copied the text from Curve.vertices.
                          Description needs updating along with an example.
                            @thomthom said:
                            Entities.add_curve
                            Returns:
                            It's always returned an array of edges - the curve is then array[0].curve
                            • Dan RathbunD
                              Dan Rathbun
                              _
                              Model.title
                              The tile method retrieves the name of the model. If the model is saved on disk, returns the file name without extension. Otherwise returns an empty string.
                              http://code.google.com/apis/sketchup/docs/ourdoc/model.html#title
                              Change 'tile' to 'title' in method description.
                              We could use Model.is_saved? and Model.is_unsaved? methods, as the Model.title method is the only way (that I can find) to determine if the model has yet been saved or not. We cannot rely upon the word 'Untitled' (in the caption bar) because that may actually be a valid filename.
                              Workaround:
                              class Sketchup;;Model
                              def is_saved?
                                return not title.empty?
                              def is_unsaved?
                                return title.empty?
                              end # class
                              _
                                Camera.set
                                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#set
                                The initialize method is deprecated. It essentially does the same thing as Camera.set.
                                Seems that's the description for Camera.new http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#new
                                ...and that Camera.new has the description for Camera.set
                                  View.pickray
                                  http://code.google.com/apis/sketchup/docs/ourdoc/view.html#pickray
                                  Returns:
                                  ray
                                  a ray
                                  "a ray"? Without testing this I#m guessing either a vector or line.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    @thomthom said:
                                    View.pickray
                                    Returns:
                                    ray a ray
                                    see this...
                                    Model.raytest
                                    A ray is a two element array containing a point and a vector [Geom::Point3d(), Geom::Vector3d()]. http://code.google.com/apis/sketchup/docs/ourdoc/model.html#raytest
                                    _
                                      Yea - I tested it later that day. It's what the Geom module describes as a line.
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Shouldn't the API have a definition for Line and/or Ray as a class (under the Geom module) ?
                                        something like:
                                        class Geom;;Ray < Array
                                          def new(*args)
                                            Array[Geom;;Point3d().new, Geom;;Vector3d().new]
                                            super()
                                          Line and Plane? hm... maybe... thought of that myself. but never really felt the need for it to make a request. works fine as it is.
                                          Dealing with them as Arrays works ok. They are simple structures.
                                          • Dan RathbunD
                                            Dan Rathbun
                                            Model.add_note
                                            The note is not displayed unless there are entities in the model. If you add a note first thing in a new model, it is invisible but .visible? on the note object still returns true.
                                            As soon as you draw something, the note appears.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 18
                                            • 19
                                            • 12 / 19
