    New API doc - typos and questions
    370 Posts 35 Posters 295.5k Views 35 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @dan rathbun said:
      (An alternative... we might create tb_Name constantsunder the UI module that would be the same for both platforms.)
      Here's an example, call it 'UI_tb_const.rb'
      module UI
      # Example ONLY
      case Sketchup;;OS
      when ;WIN
        tb_CAM = 'Camera'.freeze
        tb_CONS = 'Construction'.freeze
        tb_DISP = 'DisplayMode'.freeze
        tb_DRAW = 'Drawing'.freeze
        tb_EDIT = 'Edit'.freeze
        tb_GETS = 'GettingStarted'.freeze
        tb_GOOG = 'Google'.freeze
        tb_LTS = 'LargeToolSet'.freeze
        tb_LAYR = 'Layers'.freeze
        tb_STD = 'Standard'.freeze
        tb_TABS = 'SceneTabs'.freeze
        tb_PRIN = 'Principle'.freeze # spelling!
        tb_SBAR = 'StatusBar'.freeze
        tb_SECT = 'Section'.freeze
        tb_SHAD = 'Shadows'.freeze
        tb_VIEW = 'StandardViews'.freeze
        tb_VCB = 'VCB'.freeze
        tb_WALK = 'Walk'.freeze
      when ;OSX
      	#     what are the Mac Strings?
      end # case
      end # module UI extension
      I'm not here much anymore.
        Dan Rathbun
        UI.toolbar_names
        http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#toolbar_names
        The toolbar_names method is used to returns the name of all the available toolbars (this differs between PC and Mac).
        (1) In the above sentence "returns" should be singular.
        (2) I believe punctuation marks are supposed to go at the end of the words, ie: "Mac.)" not "Mac)." ...Language majors, confirm?
        (3) It would nice if we are to do cross-platform scripts, that you list the names for PC and Mac in the API.
        (4) UI.toolbar_names.sort on the PC, ver 7.1 returns:
        ["Camera", "Construction", "DisplayMode", "Drawing", "Edit", "GettingStarted", "Google", "Principle", "Section", "Standard", "StandardViews", "VCB", "Walk"]
        On the [Win32] Sketchup Menu: View > Toolbars(and toolbar captions):
        • Principle is Principal* Edit is Modification* VCB is Measurements* StandardViews is Views* Section is Sections* DisplayMode is FaceStyle* Walk is Walkthrough
          These are on the [Win32] Menu: View > Toolbars but, missing from the UI toolbar methods:
        • LargeToolSet* Layers* SceneTabs (on View menu )* Shadows
          Missing from View Menu and toolbar methods:
        • StatusBar
          (We can toggle it on/off [with send_action on PC], so might as well add it to the toolbar methods so we can test it's visiblilty, and use set_toolbar_visible for cross platform [if it can be toggled on MAC.])* If a user has the StatusBar off, a tool might want to instead display a messagebox if it must inform the user of some fact, so it needs to test whether it's on/off.
        (5) This same Toolbar Name Identifier Set is used with the following methods, and have the same problems, missing Identifiers, etc.
        • UI.set_toolbar_visible* UI.toolbar_visible?
        So.. we don't mind variation in the toolbar names/symbols, so long as we know what that variation is.
        (An alternative... we might create tb_Name constants under the UI module that would be the same for both platforms.)
          Entities.add_curve
          http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#add_curve
          Returns:
          curve a Curve object if successful
          SU7.1M1 PC returns an array of edges. Other versions untested. I'm submitting this as a bug.
            Curve.move_vertices
            http://code.google.com/apis/sketchup/docs/ourdoc/curve.html#move_vertices
            The vertices method retrieves a collection of all vertices in a curve.
            Seem to have copied the text from Curve.vertices.
            Description needs updating along with an example.
              @thomthom said:
              Entities.add_curve
              Returns:
              It's always returned an array of edges - the curve is then array[0].curve
                Dan Rathbun
                _
                Model.title
                The tile method retrieves the name of the model. If the model is saved on disk, returns the file name without extension. Otherwise returns an empty string.
                http://code.google.com/apis/sketchup/docs/ourdoc/model.html#title
                Change 'tile' to 'title' in method description.
                We could use Model.is_saved? and Model.is_unsaved? methods, as the Model.title method is the only way (that I can find) to determine if the model has yet been saved or not. We cannot rely upon the word 'Untitled' (in the caption bar) because that may actually be a valid filename.
                Workaround:
                class Sketchup;;Model
                def is_saved?
                  return not title.empty?
                def is_unsaved?
                  return title.empty?
                end # class
                _
                  Camera.set
                  http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#set
                  The initialize method is deprecated. It essentially does the same thing as Camera.set.
                  Seems that's the description for Camera.new http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#new
                  ...and that Camera.new has the description for Camera.set
                    View.pickray
                    http://code.google.com/apis/sketchup/docs/ourdoc/view.html#pickray
                    Returns:
                    ray
                    a ray
                    "a ray"? Without testing this I#m guessing either a vector or line.
                      Dan Rathbun
                      @thomthom said:
                      View.pickray
                      Returns:
                      ray a ray
                      see this...
                      Model.raytest
                      A ray is a two element array containing a point and a vector [Geom::Point3d(), Geom::Vector3d()]. http://code.google.com/apis/sketchup/docs/ourdoc/model.html#raytest
                      _
                        Yea - I tested it later that day. It's what the Geom module describes as a line.
                          Dan Rathbun
                          Shouldn't the API have a definition for Line and/or Ray as a class (under the Geom module) ?
                          something like:
                          class Geom;;Ray < Array
                            def new(*args)
                              Array[Geom;;Point3d().new, Geom;;Vector3d().new]
                              super()
                            Line and Plane? hm... maybe... thought of that myself. but never really felt the need for it to make a request. works fine as it is.
                            Dealing with them as Arrays works ok. They are simple structures.
                              Dan Rathbun
                              Model.add_note
                              The note is not displayed unless there are entities in the model. If you add a note first thing in a new model, it is invisible but .visible? on the note object still returns true.
                              As soon as you draw something, the note appears.
                                Jim
                                Thanks Dan - yet more never-seen-before docs coming to light.
                                  I have the mental image of Scott drowning in printouts from this thread... 😒 😆
                                    Jim
                                    Oh, I think there is a completely undocumented UTM class in there somewhere under Geom.
                                      hm.. all I can find out about that one is:
                                      Geom::UTM.instance_methods.sort.join("\n") (eval):894: warning: instance_methods: parameter will default to 'true' as of 1.8.1 to_a to_latlong to_s x y zone_letter zone_number
                                        Jim
                                        View.show_frame
                                        Documentation for this method contains some poorly-parsed html tags.
                                          Dan Rathbun
                                          Geom::UTM.instance_methods.sort.join("\n")... snip ...
                                          from Wikipedia search on "UTM":
                                          Universal Transverse Mercator coordinate system, a grid-based method of mapping locations on the surface of the Earth.
                                          http://en.wikipedia.org/wiki/Universal_Transverse_Mercator_coordinate_system
                                          _
                                            Dan Rathbun
                                            Model.get_product_family
                                            http://code.google.com/apis/sketchup/docs/ourdoc/model.html#get_product_family
                                            Returns a constant number which indicates the product family of the installed SketchUp application.
                                            This is an Application related attribute, why is it part of the Model class?
                                            This should be a method of the Sketchup module as in: Sketchup.get_product_family
                                            _
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 18
                                            • 19
                                            • 13 / 19
