    New API doc - typos and questions
    370 Posts 35 Posters 355.3k Views 35 Watching
      Entities.add_curve
      http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#add_curve
      Returns:
      curve a Curve object if successful
      SU7.1M1 PC returns an array of edges. Other versions untested. I'm submitting this as a bug.
        Curve.move_vertices
        http://code.google.com/apis/sketchup/docs/ourdoc/curve.html#move_vertices
        The vertices method retrieves a collection of all vertices in a curve.
        Seem to have copied the text from Curve.vertices.
        Description needs updating along with an example.
          @thomthom said:
          Entities.add_curve
          Returns:
          It's always returned an array of edges - the curve is then array[0].curve
          • Dan RathbunD
            Dan Rathbun
            _
            Model.title
            The tile method retrieves the name of the model. If the model is saved on disk, returns the file name without extension. Otherwise returns an empty string.
            http://code.google.com/apis/sketchup/docs/ourdoc/model.html#title
            Change 'tile' to 'title' in method description.
            We could use Model.is_saved? and Model.is_unsaved? methods, as the Model.title method is the only way (that I can find) to determine if the model has yet been saved or not. We cannot rely upon the word 'Untitled' (in the caption bar) because that may actually be a valid filename.
            Workaround:
            class Sketchup;;Model
            def is_saved?
              return not title.empty?
            def is_unsaved?
              return title.empty?
            end # class
            _
            I'm not here much anymore.
              Camera.set
              http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#set
              The initialize method is deprecated. It essentially does the same thing as Camera.set.
              Seems that's the description for Camera.new http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#new
              ...and that Camera.new has the description for Camera.set
                View.pickray
                http://code.google.com/apis/sketchup/docs/ourdoc/view.html#pickray
                Returns:
                ray
                a ray
                "a ray"? Without testing this I#m guessing either a vector or line.
                • Dan RathbunD
                  Dan Rathbun
                  @thomthom said:
                  View.pickray
                  Returns:
                  ray a ray
                  see this...
                  Model.raytest
                  A ray is a two element array containing a point and a vector [Geom::Point3d(), Geom::Vector3d()]. http://code.google.com/apis/sketchup/docs/ourdoc/model.html#raytest
                  _
                    Yea - I tested it later that day. It's what the Geom module describes as a line.
                    • Dan RathbunD
                      Dan Rathbun
                      Shouldn't the API have a definition for Line and/or Ray as a class (under the Geom module) ?
                      something like:
                      class Geom;;Ray < Array
                        def new(*args)
                          Array[Geom;;Point3d().new, Geom;;Vector3d().new]
                          super()
                        Line and Plane? hm... maybe... thought of that myself. but never really felt the need for it to make a request. works fine as it is.
                        Dealing with them as Arrays works ok. They are simple structures.
                        • Dan RathbunD
                          Dan Rathbun
                          Model.add_note
                          The note is not displayed unless there are entities in the model. If you add a note first thing in a new model, it is invisible but .visible? on the note object still returns true.
                          As soon as you draw something, the note appears.
                            Jim
                            Thanks Dan - yet more never-seen-before docs coming to light.
                              I have the mental image of Scott drowning in printouts from this thread... 😒 😆
                                Jim
                                Oh, I think there is a completely undocumented UTM class in there somewhere under Geom.
                                  hm.. all I can find out about that one is:
                                  Geom::UTM.instance_methods.sort.join("\n") (eval):894: warning: instance_methods: parameter will default to 'true' as of 1.8.1 to_a to_latlong to_s x y zone_letter zone_number
                                    Jim
                                    View.show_frame
                                    Documentation for this method contains some poorly-parsed html tags.
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Geom::UTM.instance_methods.sort.join("\n")... snip ...
                                      from Wikipedia search on "UTM":
                                      Universal Transverse Mercator coordinate system, a grid-based method of mapping locations on the surface of the Earth.
                                      http://en.wikipedia.org/wiki/Universal_Transverse_Mercator_coordinate_system
                                      _
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Model.get_product_family
                                        http://code.google.com/apis/sketchup/docs/ourdoc/model.html#get_product_family
                                        Returns a constant number which indicates the product family of the installed SketchUp application.
                                        This is an Application related attribute, why is it part of the Model class?
                                        This should be a method of the Sketchup module as in: Sketchup.get_product_family
                                        _
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Model.export
                                          http://code.google.com/apis/sketchup/docs/ourdoc/model.html#export
                                          options_hash______ A hash containing the COLLADA (.dae) export options.
                                          The options listed in the hash example is missing the option for hidden geometry.
                                          The Registry Attribute Name is "ExportHiddenGeometry", but what is the options hash key?
                                          • hiddengeometry ?* hidden_geometry ?
                                            _
                                          • Dan RathbunD
                                            Dan Rathbun
                                            Set class
                                            http://code.google.com/apis/sketchup/docs/ourdoc/set.html
                                            This class is defined in the Objectspace and should be listed under "Core Ruby Classes" (along with Array, Length, Numeric and String.)
                                            Instead it's buried under "App Level Classes" and listed with all those classes that are defined inside the Sketchup module.
                                            _
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 18
                                            • 19
                                            • 13 / 19
