    How to create a depression with complex curves?
    20 Posts 6 Posters 3.5k Views 6 Watching
      Now if you do have the arrow head, just cut it into two (delete one part) and you already have the negative. Of course, orienting front/back faces would be also good.
      (The inscriptions were mostly Latin and some very few Greek - but this is already the "Hellenised East" from the 2nd-3rd century AD)
      • charly2008C Offline
        charly2008
        Hi ushumgal,
        i copied the the Contour and made it a group. Then i modelled as i explained the triangles at each endpoint of the curves. Below is a better example.
        Karlheinz
        Speer.skp
          charly2008
          I am always surprised by the different techniques used to execute a design. Thanks TIG, your second step in your example was new to me. Thanks Simon and Jean that you showed your technique. It's nice that there are so many creative people.
          Karlheinz
          • U Offline
            ushumgal
            Gotcha...sounds like good stuff! 😄
            I see what you mean about deleting one half to get the negative, but unfortunately I put mine together a different way. I had trouble correctly aligning the bottom half once I copied and flipped it...is there some trick to it to get things to line up correctly? Instead, I made a rectangle and then drew a line down the center of the 4 sides, and brought the edges down to that center line. So I modeled it whole rather than in half. But I'm not sure how to cut it in half now, especially since I used a cylinder for the tang.
            @simon le bon said:
            Hi ushumgal
            As I can understand, you need round spoon shapes (I don't know better how to express 😆 )
            Thanks for the links to the plugins, Simon...TIG's extrude edges by rails is amazing!! I'm having some success with it, but I do have a question. I divided the arrowhead into 3 segments (which all have somewhat different sections). When using this tool, how do you merge one segment into the next? For example, if one segment is nearly cylindrical and the next is significantly flatter? I always have a gap between the segments when I try it.
            @charly2008 said:
            Hi ushumgal,
            Karlheinz
            Thanks for the example! To skin an object using the triangles, do you do it manually or is there a plugin to do it automatically for you?
            Also, when you flip the quarter of the arrowhead around to make a complete example, can you tell me how you get everything to line up correctly? When I tried to do that with halves, I could never get them perfectly aligned.
            Thanks everyone!! I started with Sketchup about a month ago, but I've learned more in the last 24 hours than in the last 28 days!
              charly2008
              I did it manually
              • U Offline
                ushumgal
                Oh, never mind about the flipping/mirroring question...I just figured out mirror_selection... 😉
                • simon le bonS Offline
                  simon le bon
                  @ushumgal said:
                  What I would like to do now is to remove the center line and have a cavity that curves from one line to the other so that when I mirror the block, there will be a clear arrowhead-shaped depression in the middle of it, deep along the center line and tapering to the surface at the edges. Of course, when I simply erase the center line, it just leaves a hole right now. Is this what the skin plugin is for?
                  @gaieus said:
                  No, TIG, arrow heads are not circular like that. 😉
                  You can start however with a lathed shape like in TIG's example model the "positive" (the arrow head) however - then remove half of it and use the scale tool to "flatten" the piece a bit.
                  Hi ushumgal
                  Here is a way with
                  TIG_Extrude Edges by Rails
                  I Have also used:
                  RickWilson_Weld.rb
                  Fredo_BezierSpline
                  TIG _ Mirror.rb
                  In your mould work, a boolean tool seems very useful
                  Whaat_BoolTools (commercial)
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Arrow001_th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Arrow002_th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Arrow003_th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Arrow004_th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Arrow005_th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/arrowKT001_th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/arrowKT002_th.jpg
                  😉 simon
                  • U Offline
                    ushumgal
                    Hi everyone!
                    The holidays slowed me down, but now I'm back at it and I have made a number of very sexy arrowhead models (in the process of which I learned a LOT about SketchUp!). Now I have one remaining problem...I'm following the instructions that Jean provided. Using a complete model of an arrowhead, I draw a rectangle around it and drag it down to become the block forming half of the mould. Now I should intersect and then delete the arrowhead itself, leaving a cavity in its shape. But whenever I try this, it never seems to work. Should the arrowhead be a group? And I try intersecting both the arrowhead and the block with the model, but I still end up with a mess when I try to delete.
                    Anyone have any ideas what I am doing wrong?
                    [See images of before and after I delete the arrowhead below.]
                    http://i1015.photobucket.com/albums/af276/tupsharru/bilobateinblock.png
                    http://i1015.photobucket.com/albums/af276/tupsharru/bilobateinblock_deleted.png
                      Well, first of all, Jeans method would work best with a single faced object but you obviously have wall thickness for the part you slide the arrow stick in so that will make it a bit more complex.
                      If you leave the arrow head a group or component, you should do the intersection twice - once for the "box" from outside of the group and once inside the group for the group itself. So best would be to explode the baby so that both parts will be in the same editing context.
                        simon le bon
                        Hi ushumgal Hi everybody,
                        Tig has is own explanation about that: Here
                        But In fact it was very uneasy to skin the middle segment with EEBR for it was not possible to skin directly 4 joining curves.
                        I said "IT WAS" because ExtrudeEdgesByRail V2 is out and this limitation has now expired 🎉
                        Segmented arrow:
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Arrow2nd_001_th.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Arrow2nd_002_th.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Arrow2nd_003_th.jpg
                        You can also use Soap Skin & Bubble
                        Which add the possibility to inflate or depress the skined faces.
                        The process need to be initiate with Weld operation for SS&B works with two joining curves. Some small fails may happen and need to be repaired. Something a bit difficult for newbies.
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Arrow2nd_004_th.jpg
                        The two different skins:
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Arrow2nd_005_th.jpg
                        I see you are doing skins manually to join your curves (good thing). This can be made with plugins. Unfortunately, powerful ArchitectBoy's Skin.rb (& see also& skin thread) only skin separate curves, but Rick Wilson Curve Stitcher does it very simply
                        (you can throw a glance on my little skin reminder here even if it must be updated)
                        ++simon
