    [Plugin] Import OBJ with Materials v2.1 20131118
    279 Posts 87 Posters 434.3k Views 87 Watching
      @sepo said:
      I tried to import .obj form Modo. It keeps telling me to change import units without creating any geometry. I tried with several ones but without success.
      It guesses the units if there are none set in the obj file.
      The dialog let's you select the units.
      Have you tried all of the unit options ?
      Sometimes large/small units in the obj file affect SUp's ability to make the meshes...
      Post a problem obj file [PM me if desired] - not too large !
        sepo
        It is 40mb scene. I tried several units but without real success.
          What does it zip down to ? OBJ files are very compressible...
          I'd try the range of metric from mm to cm and m.
          Some very complex meshes won't import but most do...
          • mitcorbM Offline
            mitcorb
            Am I reading that this Plugin works with any version of Sketchup, free or Pro?
              Should be no difference with either version...
                sepo
                Tig , I tried it with every available units ...still nothing.
                  sepo
                  When zipped it is 4.3MB, still big for sending you via pm.
                    Split it into 2 pieces and I'll join it together...
                      sepo
                      How about you send me your email ands I email it to you.
                        I have the file and am looking at it now - It does have almost 1.1 million edges !!!
                        No texture-images just materials in the mtl...
                          sepo
                          Yes I know....I managed to import bigger file than that, It has just over 2mil edges.
                            sepo
                            OK..thanks for trying.
                              Well... after along time processing it the importer produced no geometry and no console warnings.
                              I also tried importing it into Blender... and that failed with an 'out of range error message', so there's something adrift in the obj file's geometry...
                              Seems your obj file has at least one problem that's giving at least two separate importers hiccups...
                                monkey2007
                                You Saved my day with this one! 😍
                                Need to import a lot obj. but it takes more then an hour to retexture it in Sketchup. Good work !!
                                • halroachH Offline
                                  halroach
                                  nice plugin!
                                  FlexTools - Super Quick Windows, Doors, Slats...
                                    pibuz
                                    Sorry guys.. I don't want to spam this topic but I'd be very glad if someone could explain how to import correctly-mapped Xfrog trees into sketchy... 😳
                                    Sorry TIG if I go a little off-topic: I've stumbled on your topic because I am very interested in your plugin: you did a good work. A big thank you.
                                    WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                    • Z Offline
                                      ZFRPS
                                      this idea is nice !
                                      but this plugin is bad !
                                      sketchup is bim
                                        this idea is nice !
                                        Why is it ?
                                        You write a better plugin then... it's a free country/world...
                                        If my best isn't good enough then make it better, and share it...
                                          Are you implying it's not working for you?
                                          • Chris FullmerC Offline
                                            this idea is nice !
                                            You're lack of details is astounding.....How about some useful information about what the plugin is or isn't doing? And maybe a test file that it fails on?
                                            • 13
                                            • 14
                                            • 3 / 14
