    [Plugin] Import OBJ with Materials v2.1 20131118
    279 Posts 87 Posters 434.3k Views 87 Watching
      tomot
      Thank you Tig for this wonderful OBJ importer. It means I can now delete all my DXF files which I needed first so I could import into SU.
      I'm baffled why this Import feature has not been made part of SU at this late stage of SU development. If it were not for a small group of talented Ruby Scripters, my Plugins folder would not be descending past the bottom of my monitor display. Perhaps Google could, when they find some time, add a scroll bar to the Plugins Folder, or better yet the ability to add more Plugin folders to the menu bar.
      my plugins
      tomot
        sepo
        I tried to import .obj form Modo. It keeps telling me to change import units without creating any geometry. I tried with several ones but without success.
        • TIGT Online
          It guesses the units if there are none set in the obj file.
          The dialog let's you select the units.
          Have you tried all of the unit options ?
          Sometimes large/small units in the obj file affect SUp's ability to make the meshes...
          Post a problem obj file [PM me if desired] - not too large !
            sepo
            It is 40mb scene. I tried several units but without real success.
            • TIGT Online
              What does it zip down to ? OBJ files are very compressible...
              I'd try the range of metric from mm to cm and m.
              Some very complex meshes won't import but most do...
              • mitcorbM Offline
                mitcorb
                Am I reading that this Plugin works with any version of Sketchup, free or Pro?
                • TIGT Online
                  Should be no difference with either version...
                    sepo
                    Tig , I tried it with every available units ...still nothing.
                      sepo
                      When zipped it is 4.3MB, still big for sending you via pm.
                      • TIGT Online
                        Split it into 2 pieces and I'll join it together...
                          sepo
                          How about you send me your email ands I email it to you.
                          • TIGT Online
                            I have the file and am looking at it now - It does have almost 1.1 million edges !!!
                            No texture-images just materials in the mtl...
                              sepo
                              Yes I know....I managed to import bigger file than that, It has just over 2mil edges.
                                sepo
                                OK..thanks for trying.
                                • TIGT Online
                                  Well... after along time processing it the importer produced no geometry and no console warnings.
                                  I also tried importing it into Blender... and that failed with an 'out of range error message', so there's something adrift in the obj file's geometry...
                                  Seems your obj file has at least one problem that's giving at least two separate importers hiccups...
                                    monkey2007
                                    You Saved my day with this one! 😍
                                    Need to import a lot obj. but it takes more then an hour to retexture it in Sketchup. Good work !!
                                    • halroachH Offline
                                      halroach
                                      nice plugin!
                                      FlexTools - Super Quick Windows, Doors, Slats...
                                        pibuz
                                        Sorry guys.. I don't want to spam this topic but I'd be very glad if someone could explain how to import correctly-mapped Xfrog trees into sketchy... 😳
                                        Sorry TIG if I go a little off-topic: I've stumbled on your topic because I am very interested in your plugin: you did a good work. A big thank you.
                                        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                        • Z Offline
                                          ZFRPS
                                          this idea is nice !
                                          but this plugin is bad !
                                          sketchup is bim
                                          • TIGT Online
                                            this idea is nice !
                                            Why is it ?
                                            You write a better plugin then... it's a free country/world...
                                            If my best isn't good enough then make it better, and share it...
                                            • 13
                                            • 14
                                            • 3 / 14
