    [Plugin] Import OBJ with Materials v2.1 20131118
    279 Posts 87 Posters 413.9k Views 87 Watching
    • rami_lpmR Offline
      rami_lpm
      haha! Xfrog trees in SU models, that'll be the day.
        If you look over at ASGvis' forum you'll see a number of models rendered with Xfrog trees...
        • N Offline
          notareal
            tomot
            Thank you Tig for this wonderful OBJ importer. It means I can now delete all my DXF files which I needed first so I could import into SU.
            I'm baffled why this Import feature has not been made part of SU at this late stage of SU development. If it were not for a small group of talented Ruby Scripters, my Plugins folder would not be descending past the bottom of my monitor display. Perhaps Google could, when they find some time, add a scroll bar to the Plugins Folder, or better yet the ability to add more Plugin folders to the menu bar.
            my plugins
            tomot
              sepo
              I tried to import .obj form Modo. It keeps telling me to change import units without creating any geometry. I tried with several ones but without success.
                It guesses the units if there are none set in the obj file.
                The dialog let's you select the units.
                Have you tried all of the unit options ?
                Sometimes large/small units in the obj file affect SUp's ability to make the meshes...
                Post a problem obj file [PM me if desired] - not too large !
                  sepo
                  It is 40mb scene. I tried several units but without real success.
                    What does it zip down to ? OBJ files are very compressible...
                    I'd try the range of metric from mm to cm and m.
                    Some very complex meshes won't import but most do...
                    • mitcorbM Offline
                      mitcorb
                      Am I reading that this Plugin works with any version of Sketchup, free or Pro?
                        Should be no difference with either version...
                          sepo
                          Tig , I tried it with every available units ...still nothing.
                            sepo
                            When zipped it is 4.3MB, still big for sending you via pm.
                              Split it into 2 pieces and I'll join it together...
                                sepo
                                How about you send me your email ands I email it to you.
                                  I have the file and am looking at it now - It does have almost 1.1 million edges !!!
                                  No texture-images just materials in the mtl...
                                    sepo
                                    Yes I know....I managed to import bigger file than that, It has just over 2mil edges.
                                      sepo
                                      OK..thanks for trying.
                                        Well... after along time processing it the importer produced no geometry and no console warnings.
                                        I also tried importing it into Blender... and that failed with an 'out of range error message', so there's something adrift in the obj file's geometry...
                                        Seems your obj file has at least one problem that's giving at least two separate importers hiccups...
                                          monkey2007
                                          You Saved my day with this one! 😍
                                          Need to import a lot obj. but it takes more then an hour to retexture it in Sketchup. Good work !!
                                          • halroachH Offline
                                            halroach
                                            nice plugin!
                                            FlexTools - Super Quick Windows, Doors, Slats...
                                            • 13
                                            • 14
                                            • 3 / 14
