    [Plugin]Combin editor 0.08[2011.03.24] [TUTORIAL]
    52 Posts 38 Posters 59.7k Views 38 Watching
      Daniel S
      Astonished! 😎
      There is no Scale xyz in the same time?
      Yes:
      Daniel S
      • MALAISEM Offline
        MALAISE
        Thanks wikii , for this precision tool
        MALAISE 👍
          Khai
          ok tried this out and damn.
          the Sketchup version of Maya's / Hexagon's Universal Manipulator.
          I love it!
          puts it on the Must Have Ruby list
          • EarthMoverE Offline
            EarthMover
            Great Plugin - Thanks Wikii. This is going under keyboard shortcut "W" for Wikii!
            Anyway to change the slide to default to chosen unit of measure?
            If the tool only had inferencing, there would be no need to use anything else but this.
            Content Creator at Skapeup
            • PixeroP Offline
              Pixero
              Very good. I have always wanted a Gizmo for transformation.
              I wish it would be possible to move in the plane of two axis at the same time (xy, yz, xz). World and object space.
              (Meaning: Dragging in two dimensional planes like you can in almost any other 3d application.)
                Daniel S
                With Alt+Drag you force to move object freely.
                With Alt+Shift you toggle Local / World Coordinate
                Is what you want?
                Daniel S
                • PixeroP Offline
                  Pixero
                  Is what you want?
                  Daniel S
                  I want the dragging/moving to be restricted to two planes (x,y and so on) and interactive viewing so I can see what I do.
                  Other 3d appz usually have a small square near the center of the gizmo. One for each "pair" of axis.
                  Here's a image:
                  http://www.architectural-rendering-guide.com/images/3ds-max-transform-01.jpg
                  • urgenU Offline
                    urgen
                    ....thanks! 👍 👍 👍
                    --pupil forever...------
                      Drag is also cool 😉
                          kostas_designer
                          • ken28875K Offline
                            ken28875
                            Hi all,
                            Best wishes for 2010! 🎉
                            I could not find that plugin. It seems like it stops working.
                            Has anyone managed to use it lately?
                            Thanks,
                            _KN
                            Follow Your Dreams.
                              sus4
                              do not work 7.1...
                                sus4
                                mnn.. I need like Manipulator ...Do you know that similar to plug-in for sketchup?
                                  blajnov
                                  @ken28875 said:
                                  Hi all,
                                  Thanks,
                                  _KN
                                  Set the system time on the computer in 2009, but inconvenient plugin will work.
                                  • W Offline
                                    wikii
                                    Version:0.07
                                    Add background color to ruler
                                    Drag handle with Alt key to force move/scale in other two direction.
                                    This free version can work before 2011.
                                      DIEGO-RODRIGUEZ
                                      thank you very much for this update.
                                      can add a toolbar, optional?
                                      You can add a shortcut to Sutool?
                                        dedmin
                                        Perfect!!!!!
                                          Panga
                                          Thanks a lot !!
                                          • ken28875K Offline
                                            ken28875
                                            Awesome! Thanks Wikii
                                            Follow Your Dreams.
                                            • 1 / 3
