    [Plugin]Combin editor 0.08[2011.03.24] [TUTORIAL]
    52 Posts 38 Posters 61.1k Views 38 Watching
    • K
      Khai
      thank you.
      this looks very useful indeed.
        sepo
        Nice way to work, very interactive. Thank you.
        • CadFatherC
          CadFather
          Thank You Master Wikii - the snapping ruler is genius! 👍 😄
            Astonished! 😎
            There is no Scale xyz in the same time?
              Daniel S
              Astonished! 😎
              Yes:
              Daniel S
              • MALAISEM
                MALAISE
                Thanks wikii , for this precision tool
                MALAISE 👍
                • K
                  Khai
                  ok tried this out and damn.
                  the Sketchup version of Maya's / Hexagon's Universal Manipulator.
                  I love it!
                  puts it on the Must Have Ruby list
                  • EarthMoverE
                    EarthMover
                    Great Plugin - Thanks Wikii. This is going under keyboard shortcut "W" for Wikii!
                    Anyway to change the slide to default to chosen unit of measure?
                    If the tool only had inferencing, there would be no need to use anything else but this.
                    Content Creator at Skapeup
                    • PixeroP
                      Pixero
                      Very good. I have always wanted a Gizmo for transformation.
                      I wish it would be possible to move in the plane of two axis at the same time (xy, yz, xz). World and object space.
                      (Meaning: Dragging in two dimensional planes like you can in almost any other 3d application.)
                        Daniel S
                        With Alt+Drag you force to move object freely.
                        With Alt+Shift you toggle Local / World Coordinate
                        Is what you want?
                        Daniel S
                        • PixeroP
                          Pixero
                          Is what you want?
                          Daniel S
                          I want the dragging/moving to be restricted to two planes (x,y and so on) and interactive viewing so I can see what I do.
                          Other 3d appz usually have a small square near the center of the gizmo. One for each "pair" of axis.
                          Here's a image:
                          http://www.architectural-rendering-guide.com/images/3ds-max-transform-01.jpg
                          • urgenU
                            urgen
                            ....thanks! 👍 👍 👍
                            --pupil forever...------
                              Drag is also cool 😉
                                • K
                                  kostas_designer
                                  • ken28875K
                                    ken28875
                                    Hi all,
                                    Best wishes for 2010! 🎉
                                    I could not find that plugin. It seems like it stops working.
                                    Has anyone managed to use it lately?
                                    Thanks,
                                    _KN
                                    Follow Your Dreams.
                                      sus4
                                      do not work 7.1...
                                        sus4
                                        mnn.. I need like Manipulator ...Do you know that similar to plug-in for sketchup?
                                        • B
                                          blajnov
                                          @ken28875 said:
                                          Hi all,
                                          Thanks,
                                          _KN
                                          Set the system time on the computer in 2009, but inconvenient plugin will work.
                                          • W
                                            wikii
                                            Version:0.07
                                            Add background color to ruler
                                            Drag handle with Alt key to force move/scale in other two direction.
                                            This free version can work before 2011.
                                            • 1 / 3
