    [Plugin]Combin editor 0.08[2011.03.24] [TUTORIAL]
    52 Posts 38 Posters 57.8k Views 38 Watching
    • CadFatherC Offline
      CadFather
      Thank You Master Wikii - the snapping ruler is genius! 👍 😄
        Astonished! 😎
        There is no Scale xyz in the same time?
          Daniel S
          Astonished! 😎
          Yes:
          Daniel S
          • MALAISEM Offline
            MALAISE
            Thanks wikii , for this precision tool
            MALAISE 👍
              Khai
              ok tried this out and damn.
              the Sketchup version of Maya's / Hexagon's Universal Manipulator.
              I love it!
              puts it on the Must Have Ruby list
              • EarthMoverE Offline
                EarthMover
                Great Plugin - Thanks Wikii. This is going under keyboard shortcut "W" for Wikii!
                Anyway to change the slide to default to chosen unit of measure?
                If the tool only had inferencing, there would be no need to use anything else but this.
                Content Creator at Skapeup
                • PixeroP Offline
                  Pixero
                  Very good. I have always wanted a Gizmo for transformation.
                  I wish it would be possible to move in the plane of two axis at the same time (xy, yz, xz). World and object space.
                  (Meaning: Dragging in two dimensional planes like you can in almost any other 3d application.)
                    Daniel S
                    With Alt+Drag you force to move object freely.
                    With Alt+Shift you toggle Local / World Coordinate
                    Is what you want?
                    Daniel S
                    • PixeroP Offline
                      Pixero
                      Is what you want?
                      Daniel S
                      I want the dragging/moving to be restricted to two planes (x,y and so on) and interactive viewing so I can see what I do.
                      Other 3d appz usually have a small square near the center of the gizmo. One for each "pair" of axis.
                      Here's a image:
                      http://www.architectural-rendering-guide.com/images/3ds-max-transform-01.jpg
                      • urgenU Offline
                        urgen
                        ....thanks! 👍 👍 👍
                        --pupil forever...------
                          Drag is also cool 😉
                              kostas_designer
                              • ken28875K Offline
                                ken28875
                                Hi all,
                                Best wishes for 2010! 🎉
                                I could not find that plugin. It seems like it stops working.
                                Has anyone managed to use it lately?
                                Thanks,
                                _KN
                                Follow Your Dreams.
                                  sus4
                                  do not work 7.1...
                                    sus4
                                    mnn.. I need like Manipulator ...Do you know that similar to plug-in for sketchup?
                                      blajnov
                                      @ken28875 said:
                                      Hi all,
                                      Thanks,
                                      _KN
                                      Set the system time on the computer in 2009, but inconvenient plugin will work.
                                      • W Offline
                                        wikii
                                        Version:0.07
                                        Add background color to ruler
                                        Drag handle with Alt key to force move/scale in other two direction.
                                        This free version can work before 2011.
                                          DIEGO-RODRIGUEZ
                                          thank you very much for this update.
                                          can add a toolbar, optional?
                                          You can add a shortcut to Sutool?
                                            dedmin
                                            Perfect!!!!!
                                            • 1 / 3
