    [Plugin]Combin editor 0.08[2011.03.24] [TUTORIAL]
    52 Posts 38 Posters 59.7k Views 38 Watching
    • W Offline
      wikii
      Version:0.08
      Freely use forever
      Version:0.07
      Add background color to ruler
      Drag handle with Alt key to force move/scale in other two direction.
      This free version can work before 2011.
      Version:0.05
      Select a group or ComponentInstance as object to be Operated.
      Drag a handle:scale/rotate/move object in one direction
      Drag central handle:Scale
      Alt+Shift: toggle Local / World Coordinate
      Drag : move object freely
      Double click on handle:scale/rotate/move object with value that you input through a dialog box
      Shift + Double click:repeat last edit
      Alt+click:change the center of axis
      Click on other group or ComponentInstance:change object to be Operated
      Alt+Drag:force to move object freely
      This free version can work before 2010.
      http://img17.imageshack.us/img17/6638/0906290732172f8dba5c3d5.gif
      Wikii_MRS_0.05.rar
      0.07
      0.08
      • Chris FullmerC Offline
        Woohoo! THanks for this wikii.
          Khai
          thank you.
          this looks very useful indeed.
            sepo
            Nice way to work, very interactive. Thank you.
            • CadFatherC Offline
              CadFather
              Thank You Master Wikii - the snapping ruler is genius! 👍 😄
                Astonished! 😎
                There is no Scale xyz in the same time?
                  Daniel S
                  Astonished! 😎
                  Yes:
                  Daniel S
                  • MALAISEM Offline
                    MALAISE
                    Thanks wikii , for this precision tool
                    MALAISE 👍
                      Khai
                      ok tried this out and damn.
                      the Sketchup version of Maya's / Hexagon's Universal Manipulator.
                      I love it!
                      puts it on the Must Have Ruby list
                      • EarthMoverE Offline
                        EarthMover
                        Great Plugin - Thanks Wikii. This is going under keyboard shortcut "W" for Wikii!
                        Anyway to change the slide to default to chosen unit of measure?
                        If the tool only had inferencing, there would be no need to use anything else but this.
                        Content Creator at Skapeup
                        • PixeroP Offline
                          Pixero
                          Very good. I have always wanted a Gizmo for transformation.
                          I wish it would be possible to move in the plane of two axis at the same time (xy, yz, xz). World and object space.
                          (Meaning: Dragging in two dimensional planes like you can in almost any other 3d application.)
                            Daniel S
                            With Alt+Drag you force to move object freely.
                            With Alt+Shift you toggle Local / World Coordinate
                            Is what you want?
                            Daniel S
                            • PixeroP Offline
                              Pixero
                              Is what you want?
                              Daniel S
                              I want the dragging/moving to be restricted to two planes (x,y and so on) and interactive viewing so I can see what I do.
                              Other 3d appz usually have a small square near the center of the gizmo. One for each "pair" of axis.
                              Here's a image:
                              http://www.architectural-rendering-guide.com/images/3ds-max-transform-01.jpg
                              • urgenU Offline
                                urgen
                                ....thanks! 👍 👍 👍
                                --pupil forever...------
                                  Drag is also cool 😉
                                      kostas_designer
                                      • ken28875K Offline
                                        ken28875
                                        Hi all,
                                        Best wishes for 2010! 🎉
                                        I could not find that plugin. It seems like it stops working.
                                        Has anyone managed to use it lately?
                                        Thanks,
                                        _KN
                                        Follow Your Dreams.
                                          sus4
                                          do not work 7.1...
                                            sus4
                                            mnn.. I need like Manipulator ...Do you know that similar to plug-in for sketchup?
                                            • 1 / 3
