    Model this - a simple cube
    72 Posts 30 Posters 6.8k Views 30 Watching
      rev3rse
      Gaieus.. really hard challenge I see.. sorry for the poor result with this bad low-poly model ๐Ÿ˜ณ
        toxicvoxel
        Here is my version , but I think it was removed by a moderator... ๐Ÿ˜„
          No, that's probably a parallel projection/front view cube.
          • soloS Offline
            ๐Ÿคฃ
            oops. ๐Ÿ˜‰
            • soloS Offline
              TIG, that thing hypnotised me. ๐Ÿ˜•
                Sorry I think I misunderstood the type of Cube...
                ๐Ÿ˜‰ Hope plugins were allowed... ๐Ÿคฃ
                  Perhaps it should have been in the 'Is Anything Impossible' thread ? ๐Ÿ’ญ
                  • olisheaO Offline
                    olishea
                    TIG my brain is melting! ๐Ÿคข ๐Ÿ‘
                    oli
                      toxicvoxel
                      edit: Only those with a two dimensional point of view will see it that way.
                        And that's not even fair, TIG. We are suffering with the basics here and you post such a teaser! ๐Ÿ˜ฎ
                        • Al HartA Offline
                          Al Hart
                          Tutorial for creating a cube.
                          1. Start up ARRIS CAD (You might be able to do this with AutoCAD as well)
                          2. Type in the "Single Line" command: :sln
                          3. Enter 5 points for the base of the cube
                          =A(0,0,0)
                          =A(10,0,0)
                          =A(10,10,0)
                          =A(0,10,0)
                          =A(0,0,0)
                          1. Repeat for the top of the cube:
                          :sln;=A(0,0,10);=A(10,0,10);=A(10,10,10);=A(0,10,10);=A(0,0,10)
                          1. Switch to an isometric view:
                          2. Use "Single Alternating Line" :sal to connect the base points with the top points.
                          • Use the cursor and the mouse, and the right-hand mouse button to snap to the ends of the existing lines.
                          1. Export model to DWG and import into SketchUp
                          2. Use the SketchUp Face tool to draw faces on each of the 6 sides.
                          :svw;iso
                          Al Hart
                          IRender nXt from Render Plus
                          • david57D Offline
                            david57
                            No Way, To many Polygons or Faces for my Lap Top.
                              Aerilius
                              http://forums.sketchucation.com/download/file.php?id=38945
                              And I thought my one was quite successful:
                              but now you completely confused me. Maybe someone should explain me first what the 3 means in 3d...
                                Aaaah, a 3D cube not a n-dimensional hypercube then? ๐Ÿ˜ณ
                                • michaliszissiouM Offline
                                  michaliszissiou
                                  A cube? Here are 64 cubes. Its a SU raw 2d export, some PP in toycamera analogcolor.
                                  • david_hD Offline
                                    david_h
                                    okay . ..showing off now and making us strugglers feel bad.
                                    and when I say US i mean me. ๐Ÿ’š
                                    • olisheaO Offline
                                      olishea
                                      haha good one michalis.....u can make anything look beautiful! ๐Ÿ‘
                                      and raw su? haha ๐Ÿ˜ฒ
                                      oli
                                        About the Tig model you have a crazzy psychedylic prog! ๐Ÿ’š
                                        Jenn3D ๐Ÿ˜ฎ Clic image if scroll barr
                                        My cube ๐Ÿ˜’ has spherized, inflated difracted and multiply ๐Ÿ˜†
                                        • charly2008C Offline
                                          charly2008
                                          With Sketchup is really hard to make. I'll try with Zbrush, then maybe it works better.
                                            michaliszissiou
                                            I like this thread, practically we can model almost everything, beginning with a cube.
                                            Pilou, c'est tres beau ๐Ÿ‘
                                            But its not a cube.
                                            • 1 / 4
