    Model this - a simple cube
    72 Posts 30 Posters 10.1k Views 30 Watching
      rev3rse
      This is impossible to model with SU.. I need 3ds or Maya or something more powerful.. ๐Ÿ˜•
      • GaieusG
        Yeah, I know. I had to import it, too. I suffered the most with UV Mapping. ๐Ÿ˜ข
          rev3rse
          Gaieus.. really hard challenge I see.. sorry for the poor result with this bad low-poly model ๐Ÿ˜ณ
          • T
            toxicvoxel
            Here is my version , but I think it was removed by a moderator... ๐Ÿ˜„
            • GaieusG
              No, that's probably a parallel projection/front view cube.
              • soloS
                ๐Ÿคฃ
                oops. ๐Ÿ˜‰
                • soloS
                  TIG, that thing hypnotised me. ๐Ÿ˜•
                    Sorry I think I misunderstood the type of Cube...
                    ๐Ÿ˜‰ Hope plugins were allowed... ๐Ÿคฃ
                      Perhaps it should have been in the 'Is Anything Impossible' thread ? ๐Ÿ’ญ
                      • olisheaO
                        olishea
                        TIG my brain is melting! ๐Ÿคข ๐Ÿ‘
                        oli
                        • T
                          toxicvoxel
                          edit: Only those with a two dimensional point of view will see it that way.
                          • GaieusG
                            And that's not even fair, TIG. We are suffering with the basics here and you post such a teaser! ๐Ÿ˜ฎ
                            • Al HartA
                              Al Hart
                              Tutorial for creating a cube.
                              1. Start up ARRIS CAD (You might be able to do this with AutoCAD as well)
                              2. Type in the "Single Line" command: :sln
                              3. Enter 5 points for the base of the cube
                              =A(0,0,0)
                              =A(10,0,0)
                              =A(10,10,0)
                              =A(0,10,0)
                              =A(0,0,0)
                              1. Repeat for the top of the cube:
                              :sln;=A(0,0,10);=A(10,0,10);=A(10,10,10);=A(0,10,10);=A(0,0,10)
                              1. Switch to an isometric view:
                              2. Use "Single Alternating Line" :sal to connect the base points with the top points.
                              • Use the cursor and the mouse, and the right-hand mouse button to snap to the ends of the existing lines.
                              1. Export model to DWG and import into SketchUp
                              2. Use the SketchUp Face tool to draw faces on each of the 6 sides.
                              :svw;iso
                              Al Hart
                              IRender nXt from Render Plus
                              • david57D
                                david57
                                No Way, To many Polygons or Faces for my Lap Top.
                                  Aerilius
                                  http://forums.sketchucation.com/download/file.php?id=38945
                                  And I thought my one was quite successful:
                                  but now you completely confused me. Maybe someone should explain me first what the 3 means in 3d...
                                    Aaaah, a 3D cube not a n-dimensional hypercube then? ๐Ÿ˜ณ
                                    • michaliszissiouM
                                      michaliszissiou
                                      A cube? Here are 64 cubes. Its a SU raw 2d export, some PP in toycamera analogcolor.
                                      • david_hD
                                        david_h
                                        okay . ..showing off now and making us strugglers feel bad.
                                        and when I say US i mean me. ๐Ÿ’š
                                        • olisheaO
                                          olishea
                                          haha good one michalis.....u can make anything look beautiful! ๐Ÿ‘
                                          and raw su? haha ๐Ÿ˜ฒ
                                          oli
                                            About the Tig model you have a crazzy psychedylic prog! ๐Ÿ’š
                                            Jenn3D ๐Ÿ˜ฎ Clic image if scroll barr
                                            My cube ๐Ÿ˜’ has spherized, inflated difracted and multiply ๐Ÿ˜†
                                            • 1 / 4
