    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Model this - a simple cube
    72 Posts 30 Posters 6.7k Views 30 Watching
      @rev3rse said:
      This is impossible to model with SU.. I need 3ds or Maya or something more powerful.. ๐Ÿ˜•
      Yeah, I know. I had to import it, too. I suffered the most with UV Mapping. ๐Ÿ˜ข
        rev3rse
        Gaieus.. really hard challenge I see.. sorry for the poor result with this bad low-poly model ๐Ÿ˜ณ
          toxicvoxel
          Here is my version , but I think it was removed by a moderator... ๐Ÿ˜„
            No, that's probably a parallel projection/front view cube.
            • soloS Offline
              ๐Ÿคฃ
              oops. ๐Ÿ˜‰
              • soloS Offline
                TIG, that thing hypnotised me. ๐Ÿ˜•
                  Sorry I think I misunderstood the type of Cube...
                  ๐Ÿ˜‰ Hope plugins were allowed... ๐Ÿคฃ
                    Perhaps it should have been in the 'Is Anything Impossible' thread ? ๐Ÿ’ญ
                    • olisheaO Offline
                      olishea
                      TIG my brain is melting! ๐Ÿคข ๐Ÿ‘
                      oli
                        toxicvoxel
                        edit: Only those with a two dimensional point of view will see it that way.
                          And that's not even fair, TIG. We are suffering with the basics here and you post such a teaser! ๐Ÿ˜ฎ
                          • Al HartA Offline
                            Al Hart
                            Tutorial for creating a cube.
                            1. Start up ARRIS CAD (You might be able to do this with AutoCAD as well)
                            2. Type in the "Single Line" command: :sln
                            3. Enter 5 points for the base of the cube
                            =A(0,0,0)
                            =A(10,0,0)
                            =A(10,10,0)
                            =A(0,10,0)
                            =A(0,0,0)
                            1. Repeat for the top of the cube:
                            :sln;=A(0,0,10);=A(10,0,10);=A(10,10,10);=A(0,10,10);=A(0,0,10)
                            1. Switch to an isometric view:
                            2. Use "Single Alternating Line" :sal to connect the base points with the top points.
                            • Use the cursor and the mouse, and the right-hand mouse button to snap to the ends of the existing lines.
                            1. Export model to DWG and import into SketchUp
                            2. Use the SketchUp Face tool to draw faces on each of the 6 sides.
                            :svw;iso
                            Al Hart
                            IRender nXt from Render Plus
                            • david57D Offline
                              david57
                              No Way, To many Polygons or Faces for my Lap Top.
                                Aerilius
                                http://forums.sketchucation.com/download/file.php?id=38945
                                And I thought my one was quite successful:
                                but now you completely confused me. Maybe someone should explain me first what the 3 means in 3d...
                                  Aaaah, a 3D cube not a n-dimensional hypercube then? ๐Ÿ˜ณ
                                  • michaliszissiouM Offline
                                    michaliszissiou
                                    A cube? Here are 64 cubes. Its a SU raw 2d export, some PP in toycamera analogcolor.
                                    • david_hD Offline
                                      david_h
                                      okay . ..showing off now and making us strugglers feel bad.
                                      and when I say US i mean me. ๐Ÿ’š
                                      • olisheaO Offline
                                        olishea
                                        haha good one michalis.....u can make anything look beautiful! ๐Ÿ‘
                                        and raw su? haha ๐Ÿ˜ฒ
                                        oli
                                          About the Tig model you have a crazzy psychedylic prog! ๐Ÿ’š
                                          Jenn3D ๐Ÿ˜ฎ Clic image if scroll barr
                                          My cube ๐Ÿ˜’ has spherized, inflated difracted and multiply ๐Ÿ˜†
                                          • charly2008C Offline
                                            charly2008
                                            With Sketchup is really hard to make. I'll try with Zbrush, then maybe it works better.
                                            • 1 / 4
