    Model this - a simple cube
    72 Posts 30 Posters 10.1k Views 30 Watching
    • olisheaO
      olishea
      TIG my brain is melting! 🤢 👍
      oli
      • T
        toxicvoxel
        @gaieus said:
        No, that's probably a parallel projection/front view cube.
        edit: Only those with a two dimensional point of view will see it that way.
        • GaieusG
          And that's not even fair, TIG. We are suffering with the basics here and you post such a teaser! 😮
          • Al HartA
            Al Hart
            Tutorial for creating a cube.
            1. Start up ARRIS CAD (You might be able to do this with AutoCAD as well)
            2. Type in the "Single Line" command: :sln
            3. Enter 5 points for the base of the cube
            =A(0,0,0)
            =A(10,0,0)
            =A(10,10,0)
            =A(0,10,0)
            =A(0,0,0)
            1. Repeat for the top of the cube:
            :sln;=A(0,0,10);=A(10,0,10);=A(10,10,10);=A(0,10,10);=A(0,0,10)
            1. Switch to an isometric view:
            2. Use "Single Alternating Line" :sal to connect the base points with the top points.
            • Use the cursor and the mouse, and the right-hand mouse button to snap to the ends of the existing lines.
            1. Export model to DWG and import into SketchUp
            2. Use the SketchUp Face tool to draw faces on each of the 6 sides.
            :svw;iso
            Al Hart
            IRender nXt from Render Plus
            • david57D
              david57
              No Way, To many Polygons or Faces for my Lap Top.
                Aerilius
                @tig said:
                Sorry I think I misunderstood the type of Cube...
                😉 Hope plugins were allowed... 🤣
                http://forums.sketchucation.com/download/file.php?id=38945
                And I thought my one was quite successful:
                but now you completely confused me. Maybe someone should explain me first what the 3 means in 3d...
                  Aaaah, a 3D cube not a n-dimensional hypercube then? 😳
                  • michaliszissiouM
                    michaliszissiou
                    A cube? Here are 64 cubes. Its a SU raw 2d export, some PP in toycamera analogcolor.
                    • david_hD
                      david_h
                      okay . ..showing off now and making us strugglers feel bad.
                      and when I say US i mean me. 💚
                      • olisheaO
                        olishea
                        haha good one michalis.....u can make anything look beautiful! 👍
                        and raw su? haha 😲
                        oli
                          About the Tig model you have a crazzy psychedylic prog! 💚
                          Jenn3D 😮 Clic image if scroll barr
                          My cube 😒 has spherized, inflated difracted and multiply 😆
                          • charly2008C
                            charly2008
                            With Sketchup is really hard to make. I'll try with Zbrush, then maybe it works better.
                            • michaliszissiouM
                              michaliszissiou
                              I like this thread, practically we can model almost everything, beginning with a cube.
                              Pilou, c'est tres beau 👍
                              But its not a cube.
                              • charly2008C
                                charly2008
                                3D means = 3 times Double because a cube has 6 faces.
                                • daleD
                                  dale
                                  NPR Watercolor.
                                  • charly2008C
                                    charly2008
                                    I tried again to build a cube, but now i'm really confused. I wonder what happened.
                                    • soloS
                                      hmmm...
                                      I may need to scale back my 'Model this' complexity, as clearly we are all still struggling with the basics.
                                      • EscapeArtistE
                                        EscapeArtist
                                        My cube turned out inside-out, I'll post a picture when I get it right...
                                        • T
                                          toxicvoxel
                                          Another view - this time from the back.
                                          • stefanqS
                                            stefanq
                                            After lot's of tutorials, I get this....
                                            http://img686.imageshack.us/img686/3618/cube.jpg
                                            Gai.....PLEASE!!!!! share your blueprints!! 😒
                                            • 2 / 4
