    Model this - a simple cube
    72 Posts 30 Posters 10.1k Views 30 Watching
    • GaieusG
      As a response to this thread of Pete. ๐Ÿ˜’
      • dermotcollD
        dermotcoll
        ๐Ÿคฃ
        I hope your are giving us an hour for this level of difficulty Gaieus!!
        When you burn your arse - you gotta sit on the blisters!!
        • K
          Khai
          an hour only!?
          I'm gonna need more time!
          • david_hD
            david_h
            I blew it. . . ๐Ÿคฃ
            • stefanqS
              stefanq
              ๐Ÿคฃ funny guys..
              EDIT: can't wait to see Pete's model for this ๐Ÿ˜„
              • Chris FullmerC
                I figured out the front, but I'm struggling with the how to do the back.
                • david_hD
                  david_h
                  nope. . .can't do it. . . .
                    rev3rse
                    This is impossible to model with SU.. I need 3ds or Maya or something more powerful.. ๐Ÿ˜•
                    • GaieusG
                      Yeah, I know. I had to import it, too. I suffered the most with UV Mapping. ๐Ÿ˜ข
                        rev3rse
                        Gaieus.. really hard challenge I see.. sorry for the poor result with this bad low-poly model ๐Ÿ˜ณ
                        • T
                          toxicvoxel
                          Here is my version , but I think it was removed by a moderator... ๐Ÿ˜„
                          • GaieusG
                            No, that's probably a parallel projection/front view cube.
                            • soloS
                              ๐Ÿคฃ
                              oops. ๐Ÿ˜‰
                              • soloS
                                TIG, that thing hypnotised me. ๐Ÿ˜•
                                  Sorry I think I misunderstood the type of Cube...
                                  ๐Ÿ˜‰ Hope plugins were allowed... ๐Ÿคฃ
                                    Perhaps it should have been in the 'Is Anything Impossible' thread ? ๐Ÿ’ญ
                                    • olisheaO
                                      olishea
                                      TIG my brain is melting! ๐Ÿคข ๐Ÿ‘
                                      oli
                                      • T
                                        toxicvoxel
                                        edit: Only those with a two dimensional point of view will see it that way.
                                        • GaieusG
                                          And that's not even fair, TIG. We are suffering with the basics here and you post such a teaser! ๐Ÿ˜ฎ
                                          • Al HartA
                                            Al Hart
                                            Tutorial for creating a cube.
                                            1. Start up ARRIS CAD (You might be able to do this with AutoCAD as well)
                                            2. Type in the "Single Line" command: :sln
                                            3. Enter 5 points for the base of the cube
                                            =A(0,0,0)
                                            =A(10,0,0)
                                            =A(10,10,0)
                                            =A(0,10,0)
                                            =A(0,0,0)
                                            1. Repeat for the top of the cube:
                                            :sln;=A(0,0,10);=A(10,0,10);=A(10,10,10);=A(0,10,10);=A(0,0,10)
                                            1. Switch to an isometric view:
                                            2. Use "Single Alternating Line" :sal to connect the base points with the top points.
                                            • Use the cursor and the mouse, and the right-hand mouse button to snap to the ends of the existing lines.
                                            1. Export model to DWG and import into SketchUp
                                            2. Use the SketchUp Face tool to draw faces on each of the 6 sides.
                                            :svw;iso
                                            Al Hart
                                            IRender nXt from Render Plus
                                            • 1 / 4
