    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Model this - a simple cube
    72 Posts 30 Posters 5.8k Views 30 Watching
    • stefanqS Offline
      stefanq
      ๐Ÿคฃ funny guys..
      EDIT: can't wait to see Pete's model for this ๐Ÿ˜„
      • Chris FullmerC Offline
        I figured out the front, but I'm struggling with the how to do the back.
        • david_hD Offline
          david_h
          nope. . .can't do it. . . .
            rev3rse
            This is impossible to model with SU.. I need 3ds or Maya or something more powerful.. ๐Ÿ˜•
              Yeah, I know. I had to import it, too. I suffered the most with UV Mapping. ๐Ÿ˜ข
                rev3rse
                Gaieus.. really hard challenge I see.. sorry for the poor result with this bad low-poly model ๐Ÿ˜ณ
                  toxicvoxel
                  Here is my version , but I think it was removed by a moderator... ๐Ÿ˜„
                    No, that's probably a parallel projection/front view cube.
                    • soloS Offline
                      ๐Ÿคฃ
                      oops. ๐Ÿ˜‰
                      • soloS Offline
                        TIG, that thing hypnotised me. ๐Ÿ˜•
                        • TIGT Online
                          Sorry I think I misunderstood the type of Cube...
                          ๐Ÿ˜‰ Hope plugins were allowed... ๐Ÿคฃ
                          • TIGT Online
                            Perhaps it should have been in the 'Is Anything Impossible' thread ? ๐Ÿ’ญ
                            • olisheaO Offline
                              olishea
                              TIG my brain is melting! ๐Ÿคข ๐Ÿ‘
                              oli
                                toxicvoxel
                                edit: Only those with a two dimensional point of view will see it that way.
                                  And that's not even fair, TIG. We are suffering with the basics here and you post such a teaser! ๐Ÿ˜ฎ
                                  • Al HartA Offline
                                    Al Hart
                                    Tutorial for creating a cube.
                                    1. Start up ARRIS CAD (You might be able to do this with AutoCAD as well)
                                    2. Type in the "Single Line" command: :sln
                                    3. Enter 5 points for the base of the cube
                                    =A(0,0,0)
                                    =A(10,0,0)
                                    =A(10,10,0)
                                    =A(0,10,0)
                                    =A(0,0,0)
                                    1. Repeat for the top of the cube:
                                    :sln;=A(0,0,10);=A(10,0,10);=A(10,10,10);=A(0,10,10);=A(0,0,10)
                                    1. Switch to an isometric view:
                                    2. Use "Single Alternating Line" :sal to connect the base points with the top points.
                                    • Use the cursor and the mouse, and the right-hand mouse button to snap to the ends of the existing lines.
                                    1. Export model to DWG and import into SketchUp
                                    2. Use the SketchUp Face tool to draw faces on each of the 6 sides.
                                    :svw;iso
                                    Al Hart
                                    IRender nXt from Render Plus
                                    • david57D Offline
                                      david57
                                      No Way, To many Polygons or Faces for my Lap Top.
                                        Aerilius
                                        http://forums.sketchucation.com/download/file.php?id=38945
                                        And I thought my one was quite successful:
                                        but now you completely confused me. Maybe someone should explain me first what the 3 means in 3d...
                                        • TIGT Online
                                          Aaaah, a 3D cube not a n-dimensional hypercube then? ๐Ÿ˜ณ
                                          • michaliszissiouM Offline
                                            michaliszissiou
                                            A cube? Here are 64 cubes. Its a SU raw 2d export, some PP in toycamera analogcolor.
                                            • 3 / 4
