    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 580 Posters 6.6m Views 582 Watching
      works fine on my windows7. But I have the UAC diabled, maybe that makes a difference.... Think there was an issue on Vista where files some times ended up in a compatibility folder...
        Khai
        ok.. installed the Library to my new SU install and on starting SU I just get a load of Load Errors:
        Error Loading File D:/7500 Modeling Apps/Google/Google Sketchup 7/plugins/LIBFREDO6_Dir_34/lib6config/tb uninitalized constant Traductor::T6
        etc etc (list goes on...)
        Edit ok - found it was an issue with Smustards Plugin organiser.
          pcrego
          I am trying to download Round Corner but it says I am not authorized to do so.. Any help please?
          • Q Offline
            qiujie19
            great i need the chinese version
            • cherokee_roC Offline
              cherokee_ro
              hi, i'm getting an error like this : "uninitialized constant LibFredo6::Traductor" i installed the last version of libfredo6...anybidy knows why?
                davidgold
                have installed v3.4b will not show up in sketchup. Have deleted and re-downloaded, unzipped etc several times...any clues?
                Running xp sketchup 7pro
                • fredo6F Offline
                  Did you install one of my plugin (FredoScale, Roundcorner). LibFredo6 alone is not doing anything. It is just a shared library.
                    davidgold1
                    downloaded LibFredo6 .Winrar says system cannot find path specified,,c/prog files/google/sketchup7/plugins. what could be the problem here? Would the fact that i have 2 comptrs one xp and one vista be a problem? i.e. while dnlding to vista machine is it trying to accomodate xp machine....please help. And which additional files are actually required to get it working...i successfully extracted files to xp machine, but nothing shows up within sketchup. (these may be dumb questions but i am a bit dumb)
                      Rick Zook
                      I've dowloaded the LibFredo6 3.4 into the plugins folder and unzipped it.
                      Everything is there per the instructions (pdf). When I open SU the LibFredo6 doesn't show in the Windows menu.
                      What am I doing wrong?
                      Thanks,
                      -Zook
                      • fredo6F Offline
                        Thanks,
                        -Zook
                        LibFredo6 does not do anything 'alone'. It is only activated when my other scripts are used (like FredoScale, RoundCorner, etc...). Actually, LibFredo6 does not even load if not invoked from my other scripts (so it does preserve memory).
                        Thanks to confirm that you did (or did not)install any other script along with LibFredo6.
                          pepijn korner
                          where can i download this fabulous plug in πŸ˜„?
                            romain210
                            thank you fredo
                            vive la france
                              affyx
                              Thnk you fredo - you have saved me countless hours! I would like to make a paypal donation to your continued efforts - anyone know how?
                              • fredo6F Offline
                                Thanks for the recognition.
                                There is a menu for donation in Tools > Fredo6 Collection, and then for the plugin you prefer (LibFredo6 is not really a plugin, but a shared utility used by several of my scripts).
                                  aea
                                  super !
                                  • Z Offline
                                    zuralo
                                    fredo, I am a mac user, I tried everything...
                                    I downloaded libfredo6 v3.4b, put in in the MacHD...\plugin, following the instructions, I even read through the forum a suggestion to put it in user\application support...\plugin and still it did not work.
                                    what should I do?
                                    • I Offline
                                      icsthorp
                                      Hi Fredo, I'm also a Mac user - expanded the "Roundcorner" plugin and the "LibFredo6 - v3.4b" files in the HD/Application Support/Google Sketchup 7/Sketchup/Plugins directory with no luck, even after logging out and back in. Tried it in version 6 and 7. Any suggestions?
                                      • fredo6F Offline
                                        Did you install one of my plugins (like RoundCorner or FredoScale)? LibFredo6 does not do anything useful by itself and does not load until a plugin starts using it.
                                        Fred
                                          groomden
                                          Is it possible to stretch by assigning a new dimension? i.e. i have an object that is 30 inches high. After selecting the fredo stretch and placing the stretch plane i would like to make the new overall height of my object be 28.5 inches high. Can i type in 1.5inches to get this result?
                                          Also, I noticed that when you are stretching a group of components where there are multiple instances present, the other components are not updating to the new size that is being stretched? Can this be made a toggle or something to 'update all instances of components in model?'
                                          Dennis
                                          • fredo6F Offline
                                            This is supported. Just move the mouse over the handle corresponding to the stretching direction (you don't even need to click, highlighting is enough). Then press TAB or select "enter new dimension' in the contextual menu. The dialog box shows you the current dimension. You can enter a new one. Note that the dialog box accepts formulas, so you can keep the current number and append -1 1/2'' if you like.
                                            This is intentional, because in most cases you wish to create a new component with different dimensions and may want to keep the original version, but the idea of a toggle is interesting.
                                            • 111
                                            • 112
                                            • 5 / 112
