    Model this: 3D Connexion Space explorer
    67 Posts 26 Posters 14.2k Views 26 Watching
    • EarthMoverE
      EarthMover
      Definitely challenging Pete. I'm going to try playing with TIG's sweep along rails plugin to see if I can get a cleaner mesh, then booltools as well. TOS & JPP seems to leave me with undesirable mesh. Also thought about SDS, but it will take some trial and error to get right.
      Content Creator at Skapeup
      • K
        kwistenbiebel
        Wow, this is a nutcracker.
        I don't have a clue how to pull this off to be honest.
        Adams results are already quite good.
        Adam, could you explain the abbreviations VPP and SSB (below the images)?
          VPP could be Vector Push Pull from. Joint Push Pull plugin as for SSB, I thought itwas for Subdivide and Smooth but now you mention it I'm stumped
          excellent modeling Adam BTW. Really innovative thinking
          • EarthMoverE
            EarthMover
            Sorry bout the abbreviations. SSB = Soap Skin Bubble and yes VPP = Vector Push Pull.
            • N
              nomeradona
              wow thank you for those screen shots its very easy to follow.
                Slimdog
                Holy crap I am still working on the first challenge. Guess I will have to hurry up with the first one.
                This one looks to be quite a bit above my head for sure.
                  dedmin
                  http://www.rwlabs.com/article.php?cat=&id=152&pagenumber=4
                  http://metku.net/index.html?path=reviews/spaceexplorer/index_eng2
                    Funny thing of this design model is that is like a shoe! πŸ˜„
                    Yes maybe the new Tig plug sweep 2 rails can help you on this shoe under the hand πŸ˜‰
                    • U
                      Ultimatez 32
                      tried using sds.. result better then expected πŸ˜„
                      basic side view outline
                      basic top view outline
                      after intersection and erase
                      erased bottom, and sds 3 iterations
                      Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                      • soloS
                        I gave it a quick try using Bool tools, Poly reduce and SDS.
                        • EarthMoverE
                          EarthMover
                          Nice Pete. What did you use to reduce the mesh before SDS?
                          Nevermind, I see you used Polyreduce. Nice trick to get a clean mesh!!
                          • jeff hammondJ
                            a not so quick try... a lot of manual stuff with
                            definitely not impossible to do in sketchup but i would put it near the bottom of the list as the go-to app for doing it πŸ˜„
                            i'm not sure how much further i'll be able to go with this one (i'm already 2.5 hrs in) but i'll clean up some of the mesh and post it here incase someone wants to add on to it..
                            a couple of bumps in there and the nose is too pointy but it shouldn't be too hard to correct..
                            • soloS
                              Okay, now for a different approach, I made a thumb sucky proxy (as I do for making cartoon characters, by trial and error)
                              It's not accurate but definitely looks better and smoother.
                              I have added the basic SDS model if y'all wanna play.
                              proxy
                              proxy
                              SDS of proxy
                              Intersect plane for bottom
                              SDS version model
                                Solidseal
                                My work so far πŸ˜„
                                Not perfect but thats all I know about this programm πŸ˜„
                                No plug ins used
                                and the big knob is a tad to big
                                • jeff hammondJ
                                  ok, here's my stopping point.. i might draw it in rhino eventually for practice but i'm already burned out on the SU version πŸ˜„
                                  feel free to use the mesh to take it further though i'm not sure it's at the best point for that..
                                  the attached skp looks like this
                                  i used tig's Extrude Edges By Rail.. the hardest part for that was getting the curves to have an equal number of segments (which isn't necessary for the plugin.. it's just that the poly count can go through the roof if it isn't done like that.)
                                  navigator_JH.skp
                                  • ely862meE
                                    ely862me
                                    Here is my try..got lazy at the finish and i didn t pay much attention to the keys ..
                                    Tools used...hmm:line,move,scale,ffd,joint push&pull,sds..
                                    Take care!
                                    Elisei
                                    remcon.skp
                                    Elisei (sketchupper)
                                    Come and See EliseiDesign
                                    • jeff hammondJ
                                      awesome job ely!
                                      that's a big time SDS ad right there πŸ˜„
                                      [edit] seriously impressive.. i didn't think anyone was going to get that close.
                                      a few years worth of modeling cars in SU really pays off huh.. πŸ˜„
                                        Solidseal
                                        @ely862me said:
                                        πŸ˜„ Thanks!
                                        Sorry i didn t kept the model without subdividing ..Maybe other time!
                                        Elisei
                                        Elisei .. I have seen your vids @ tube making that supercar (posted there also πŸ˜› )
                                        I was just wondering. What kinda system do you have ?
                                        • ely862meE
                                          ely862me
                                          It s not that good.. trust me..
                                          Intel(R) Pentium(R) Dual Core 2.80 Ghz
                                          1 Gb ram
                                          nVidia 8600Gt 1 Gb video card
                                          Why are u asking!?
                                          Elisei
                                          • stefanqS
                                            stefanq
                                            Bravo Ely!
                                            • 1 / 4
