    Model this: 3D Connexion Space explorer
    67 Posts 26 Posters 13.0k Views 26 Watching
    • EscapeArtistE Offline
      EscapeArtist
      Wow, that's gonna take a little time; a real challenge. There's a lot of curves in that thing. "Moderate" you say...
      • dermotcollD Offline
        dermotcoll
        Dear sir,
        My dog ate my monitor so I couldnt do my homework!!!!
        As Father Jack would say "Arse, Feck, DRINK!!!!"
        When you burn your arse - you gotta sit on the blisters!!
        • EarthMoverE Offline
          EarthMover
          Frustrating model to try and build without true orthographical blueprints. I've decided to start over. I saved some screen shots as I was modeling to the point I got to. It was going okay, but my geometry started to get a little out of control and I'd like to try a different approach. Here's the results of my first attempt....perhaps someone can expand upon the method. This is definitely a model suited for nurbs!
          Started by tracing the outline in topview, using Bezier tools
          Use extrude lines plugin to extrude bezier curves on Z
          Repeated procedure and extruded the side profile
          Intersected and deleted unwanted geometry and then used a plane to slice the model in half
          Attached halves and used VPP to extrude face down on Z.  Then traced the base of the navigator and intersected.
          Made a copy of surface mesh and ran SSB on it.
          I used the sandbox smoove to push the bubble mesh for the palm pad and wheel.  Modeled the navigator wheel using standard follow me tool.  Used TOS and JPP to start making the buttons.
          Content Creator at Skapeup
          • soloS Offline
            Great start Adam, I was thinking along the same lines, using 'Booltools' for the intersecting groups.
              EarthMover
              Definitely challenging Pete. I'm going to try playing with TIG's sweep along rails plugin to see if I can get a cleaner mesh, then booltools as well. TOS & JPP seems to leave me with undesirable mesh. Also thought about SDS, but it will take some trial and error to get right.
                kwistenbiebel
                Wow, this is a nutcracker.
                I don't have a clue how to pull this off to be honest.
                Adams results are already quite good.
                Adam, could you explain the abbreviations VPP and SSB (below the images)?
                  VPP could be Vector Push Pull from. Joint Push Pull plugin as for SSB, I thought itwas for Subdivide and Smooth but now you mention it I'm stumped
                  excellent modeling Adam BTW. Really innovative thinking
                    EarthMover
                    Sorry bout the abbreviations. SSB = Soap Skin Bubble and yes VPP = Vector Push Pull.
                    • N Offline
                      nomeradona
                      wow thank you for those screen shots its very easy to follow.
                        Slimdog
                        Holy crap I am still working on the first challenge. Guess I will have to hurry up with the first one.
                        This one looks to be quite a bit above my head for sure.
                          dedmin
                          http://www.rwlabs.com/article.php?cat=&id=152&pagenumber=4
                          http://metku.net/index.html?path=reviews/spaceexplorer/index_eng2
                            Funny thing of this design model is that is like a shoe! ๐Ÿ˜„
                            Yes maybe the new Tig plug sweep 2 rails can help you on this shoe under the hand ๐Ÿ˜‰
                            • U Offline
                              Ultimatez 32
                              tried using sds.. result better then expected ๐Ÿ˜„
                              basic side view outline
                              basic top view outline
                              after intersection and erase
                              erased bottom, and sds 3 iterations
                              Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                              • soloS Offline
                                I gave it a quick try using Bool tools, Poly reduce and SDS.
                                  EarthMover
                                  Nice Pete. What did you use to reduce the mesh before SDS?
                                  Nevermind, I see you used Polyreduce. Nice trick to get a clean mesh!!
                                  • jeff hammondJ Offline
                                    a not so quick try... a lot of manual stuff with
                                    definitely not impossible to do in sketchup but i would put it near the bottom of the list as the go-to app for doing it ๐Ÿ˜„
                                    i'm not sure how much further i'll be able to go with this one (i'm already 2.5 hrs in) but i'll clean up some of the mesh and post it here incase someone wants to add on to it..
                                    a couple of bumps in there and the nose is too pointy but it shouldn't be too hard to correct..
                                    • soloS Offline
                                      Okay, now for a different approach, I made a thumb sucky proxy (as I do for making cartoon characters, by trial and error)
                                      It's not accurate but definitely looks better and smoother.
                                      I have added the basic SDS model if y'all wanna play.
                                      proxy
                                      proxy
                                      SDS of proxy
                                      Intersect plane for bottom
                                      SDS version model
                                        Solidseal
                                        My work so far ๐Ÿ˜„
                                        Not perfect but thats all I know about this programm ๐Ÿ˜„
                                        No plug ins used
                                        and the big knob is a tad to big
                                          ok, here's my stopping point.. i might draw it in rhino eventually for practice but i'm already burned out on the SU version ๐Ÿ˜„
                                          feel free to use the mesh to take it further though i'm not sure it's at the best point for that..
                                          the attached skp looks like this
                                          i used tig's Extrude Edges By Rail.. the hardest part for that was getting the curves to have an equal number of segments (which isn't necessary for the plugin.. it's just that the poly count can go through the roof if it isn't done like that.)
                                          navigator_JH.skp
                                          • ely862meE Offline
                                            ely862me
                                            Here is my try..got lazy at the finish and i didn t pay much attention to the keys ..
                                            Tools used...hmm:line,move,scale,ffd,joint push&pull,sds..
                                            Take care!
                                            Elisei
                                            remcon.skp
                                            Elisei (sketchupper)
                                            Come and See EliseiDesign
                                            • 1 / 4
