    Model this: 3D Connexion Space explorer
    67 Posts 26 Posters 13.7k Views 26 Watching
      kwistenbiebel
      Wow, this is a nutcracker.
      I don't have a clue how to pull this off to be honest.
      Adams results are already quite good.
      Adam, could you explain the abbreviations VPP and SSB (below the images)?
        VPP could be Vector Push Pull from. Joint Push Pull plugin as for SSB, I thought itwas for Subdivide and Smooth but now you mention it I'm stumped
        excellent modeling Adam BTW. Really innovative thinking
        • EarthMoverE Offline
          EarthMover
          Sorry bout the abbreviations. SSB = Soap Skin Bubble and yes VPP = Vector Push Pull.
          Content Creator at Skapeup
          • N Offline
            nomeradona
            wow thank you for those screen shots its very easy to follow.
              Slimdog
              Holy crap I am still working on the first challenge. Guess I will have to hurry up with the first one.
              This one looks to be quite a bit above my head for sure.
                dedmin
                http://www.rwlabs.com/article.php?cat=&id=152&pagenumber=4
                http://metku.net/index.html?path=reviews/spaceexplorer/index_eng2
                  Funny thing of this design model is that is like a shoe! πŸ˜„
                  Yes maybe the new Tig plug sweep 2 rails can help you on this shoe under the hand πŸ˜‰
                  • U Offline
                    Ultimatez 32
                    tried using sds.. result better then expected πŸ˜„
                    basic side view outline
                    basic top view outline
                    after intersection and erase
                    erased bottom, and sds 3 iterations
                    Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                    • soloS Offline
                      I gave it a quick try using Bool tools, Poly reduce and SDS.
                        EarthMover
                        Nice Pete. What did you use to reduce the mesh before SDS?
                        Nevermind, I see you used Polyreduce. Nice trick to get a clean mesh!!
                        • jeff hammondJ Offline
                          a not so quick try... a lot of manual stuff with
                          definitely not impossible to do in sketchup but i would put it near the bottom of the list as the go-to app for doing it πŸ˜„
                          i'm not sure how much further i'll be able to go with this one (i'm already 2.5 hrs in) but i'll clean up some of the mesh and post it here incase someone wants to add on to it..
                          a couple of bumps in there and the nose is too pointy but it shouldn't be too hard to correct..
                          • soloS Offline
                            Okay, now for a different approach, I made a thumb sucky proxy (as I do for making cartoon characters, by trial and error)
                            It's not accurate but definitely looks better and smoother.
                            I have added the basic SDS model if y'all wanna play.
                            proxy
                            proxy
                            SDS of proxy
                            Intersect plane for bottom
                            SDS version model
                              Solidseal
                              My work so far πŸ˜„
                              Not perfect but thats all I know about this programm πŸ˜„
                              No plug ins used
                              and the big knob is a tad to big
                                ok, here's my stopping point.. i might draw it in rhino eventually for practice but i'm already burned out on the SU version πŸ˜„
                                feel free to use the mesh to take it further though i'm not sure it's at the best point for that..
                                the attached skp looks like this
                                i used tig's Extrude Edges By Rail.. the hardest part for that was getting the curves to have an equal number of segments (which isn't necessary for the plugin.. it's just that the poly count can go through the roof if it isn't done like that.)
                                navigator_JH.skp
                                • ely862meE Offline
                                  ely862me
                                  Here is my try..got lazy at the finish and i didn t pay much attention to the keys ..
                                  Tools used...hmm:line,move,scale,ffd,joint push&pull,sds..
                                  Take care!
                                  Elisei
                                  remcon.skp
                                  Elisei (sketchupper)
                                  Come and See EliseiDesign
                                    awesome job ely!
                                    that's a big time SDS ad right there πŸ˜„
                                    [edit] seriously impressive.. i didn't think anyone was going to get that close.
                                    a few years worth of modeling cars in SU really pays off huh.. πŸ˜„
                                      Solidseal
                                      @ely862me said:
                                      πŸ˜„ Thanks!
                                      Sorry i didn t kept the model without subdividing ..Maybe other time!
                                      Elisei
                                      Elisei .. I have seen your vids @ tube making that supercar (posted there also πŸ˜› )
                                      I was just wondering. What kinda system do you have ?
                                      • ely862meE Offline
                                        ely862me
                                        It s not that good.. trust me..
                                        Intel(R) Pentium(R) Dual Core 2.80 Ghz
                                        1 Gb ram
                                        nVidia 8600Gt 1 Gb video card
                                        Why are u asking!?
                                        Elisei
                                        • stefanqS Offline
                                          stefanq
                                          Bravo Ely!
                                          • ely862meE Offline
                                            ely862me
                                            πŸ˜„ Thanks!
                                            Elisei
                                            yes sir,it does πŸ˜„
                                            • 1 / 4
