    Model this: 3D Connexion Space explorer
    67 Posts 26 Posters 11.0k Views 26 Watching
    • soloS Offline
      Okay, for the second challenge I thought we should try something that has a 'shape' very unique and will involve some head scratching, looks simple enough and I'm sure to a few guru's here it probably is.
      I'd consider this a moderate challenge and a good one for all to play with.
      Again, feel free to try anything, please post even if you do not succeed as this is a learning challenge, I am sure many here will help out where they can.
      http://www.gearcrave.com/wp-content/uploads/2008/05/space_explorer_05122008_msp1.jpg
      http://www.materiel.net/live/85631.jpg
      https://www.journeyed.co.il/images/product_images/popup_images/12656_0.jpg
      http://www.materiel.net/live/85628.jpg
      • Rich O BrienR Online
        ' for Pete's sake! '
        Sorry couldn't resist, nice challenge and I look forward to seeing to 'Guru's' models.
        • soloS Offline
          ๐Ÿ’š
          I like this choice for the challenge as the best model will be used for a render challenge, I'm sure you can see the reason this will make a great render challenge.
          I normally look around my home for things that will be challenging to model, I have a few other ideas for future challenges, however if y'all have something good that will can be used for these challenges please pm me so I can add them to the list.
          • EscapeArtistE Offline
            EscapeArtist
            Wow, that's gonna take a little time; a real challenge. There's a lot of curves in that thing. "Moderate" you say...
            • dermotcollD Offline
              dermotcoll
              Dear sir,
              My dog ate my monitor so I couldnt do my homework!!!!
              As Father Jack would say "Arse, Feck, DRINK!!!!"
              When you burn your arse - you gotta sit on the blisters!!
              • EarthMoverE Offline
                EarthMover
                Frustrating model to try and build without true orthographical blueprints. I've decided to start over. I saved some screen shots as I was modeling to the point I got to. It was going okay, but my geometry started to get a little out of control and I'd like to try a different approach. Here's the results of my first attempt....perhaps someone can expand upon the method. This is definitely a model suited for nurbs!
                Started by tracing the outline in topview, using Bezier tools
                Use extrude lines plugin to extrude bezier curves on Z
                Repeated procedure and extruded the side profile
                Intersected and deleted unwanted geometry and then used a plane to slice the model in half
                Attached halves and used VPP to extrude face down on Z.  Then traced the base of the navigator and intersected.
                Made a copy of surface mesh and ran SSB on it.
                I used the sandbox smoove to push the bubble mesh for the palm pad and wheel.  Modeled the navigator wheel using standard follow me tool.  Used TOS and JPP to start making the buttons.
                Content Creator at Skapeup
                • soloS Offline
                  Great start Adam, I was thinking along the same lines, using 'Booltools' for the intersecting groups.
                    EarthMover
                    Definitely challenging Pete. I'm going to try playing with TIG's sweep along rails plugin to see if I can get a cleaner mesh, then booltools as well. TOS & JPP seems to leave me with undesirable mesh. Also thought about SDS, but it will take some trial and error to get right.
                      kwistenbiebel
                      Wow, this is a nutcracker.
                      I don't have a clue how to pull this off to be honest.
                      Adams results are already quite good.
                      Adam, could you explain the abbreviations VPP and SSB (below the images)?
                        VPP could be Vector Push Pull from. Joint Push Pull plugin as for SSB, I thought itwas for Subdivide and Smooth but now you mention it I'm stumped
                        excellent modeling Adam BTW. Really innovative thinking
                          EarthMover
                          Sorry bout the abbreviations. SSB = Soap Skin Bubble and yes VPP = Vector Push Pull.
                          • N Offline
                            nomeradona
                            wow thank you for those screen shots its very easy to follow.
                              Slimdog
                              Holy crap I am still working on the first challenge. Guess I will have to hurry up with the first one.
                              This one looks to be quite a bit above my head for sure.
                                dedmin
                                http://www.rwlabs.com/article.php?cat=&id=152&pagenumber=4
                                http://metku.net/index.html?path=reviews/spaceexplorer/index_eng2
                                  Funny thing of this design model is that is like a shoe! ๐Ÿ˜„
                                  Yes maybe the new Tig plug sweep 2 rails can help you on this shoe under the hand ๐Ÿ˜‰
                                  • U Offline
                                    Ultimatez 32
                                    tried using sds.. result better then expected ๐Ÿ˜„
                                    basic side view outline
                                    basic top view outline
                                    after intersection and erase
                                    erased bottom, and sds 3 iterations
                                    Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                                    • soloS Offline
                                      I gave it a quick try using Bool tools, Poly reduce and SDS.
                                        EarthMover
                                        Nice Pete. What did you use to reduce the mesh before SDS?
                                        Nevermind, I see you used Polyreduce. Nice trick to get a clean mesh!!
                                        • jeff hammondJ Offline
                                          a not so quick try... a lot of manual stuff with
                                          definitely not impossible to do in sketchup but i would put it near the bottom of the list as the go-to app for doing it ๐Ÿ˜„
                                          i'm not sure how much further i'll be able to go with this one (i'm already 2.5 hrs in) but i'll clean up some of the mesh and post it here incase someone wants to add on to it..
                                          a couple of bumps in there and the nose is too pointy but it shouldn't be too hard to correct..
                                          • soloS Offline
                                            Okay, now for a different approach, I made a thumb sucky proxy (as I do for making cartoon characters, by trial and error)
                                            It's not accurate but definitely looks better and smoother.
                                            I have added the basic SDS model if y'all wanna play.
                                            proxy
                                            proxy
                                            SDS of proxy
                                            Intersect plane for bottom
                                            SDS version model
                                            • 1 / 4
