    [Plugin] Lines to tubes
    131 Posts 61 Posters 307.7k Views 61 Watching
      CameronVan
      for the problems, maybe you must disable the old "line2cyl.rb"? πŸ˜‰
      maybe...
      I did not have a chance to look at this until now on my work machine. I had line2cyl.rb here as well. I installed Lines to tubes and got the same results... not showing up. So I then tried as you suggested Pilou, deleting line2cyl.rb and now it is showing up.
      Thanks. πŸ‘
      Ahhh, great.
      Thanks Pilou!
      • MarianM Offline
        Marian
        Silly me....i did download the plugin and tried it before posting that...which makes me a bigger fool...but i didn't try the options...and manuals...who ever reads them? πŸ˜›
        • Didier BurD Offline
          Didier Bur
          Those who don't want to bother doc writers πŸ˜†
          DB
            lorca
            Great plugin. Is there a way to close the gaps in sharp corners just like in "Pipe Along Path"?
              lexmonteiro
              @gaucho said:
              @didier bur said:
              would be possible to modify so we could extrude along square shapes as well?
              Use a precision of 4 and you'll get square section prisms.(RTFM)
              Simple anD easy.. MERCI!
              Great plugin, I was trying to create a window and realized that using precision 4, the corners were at 45 degrees, can I control the orientation of the angles?
                chango70
                Doesn't show up for me. I don't have older version at all. Any ideas?
                • X Offline
                  xrok1
                  i just DLd and it showed up in tools menu.
                  thanks dedier! πŸ˜„
                    chango70
                    Whats DLd?
                      chango70
                      Its working now! WOOHOO! Great plugin!
                      • X Offline
                        xrok1
                        @chango70 said:
                        Whats DLd?
                        downloaded 😳
                        • F Offline
                          flipya
                          I love this plugin! It's so incredibly easy to use and all the options I need are included. A+ for ease of use!
                          Combined with the soapskin bubble plugin it's almost addictive 😲
                          It does sometimes crash my sketchup. The progress percentage builds up, slows down, and eventually just stops. A second or third try (saving before starting) usually does the job though.
                          All in all, pretty much brilliant!
                          • majidM Offline
                            majid
                            first I must thank you for your handy tool Dider, and then I thought if you could combine this plugin with a geosphere creator + an option to have sphere in junction points, then we would have A LATTIC TOOL ,right in sketchup, that makes space frames easy.
                              @majid
                              for some things you can use that πŸ˜‰
                              A cool use of this "Multiple Face Offset" By Remus 😎
                              If you don't use it in this case Windowizer(3 free or 4) By Rick Wilson @Smustard
                              don't make the "Frame Inset"! πŸ˜‰
                              Windowizer is a crazzy plug : All types of piercing windows + multiple selections 😲
                              Selection Only faces by Selection Toys by Thomthom β˜€
                              Invert Selection by TIG β˜€
                              For Crazzy Geodesic domes By TaffGoch @ 3Dwarehouse 😲
                              His site πŸ€“ Crazzy PDF collector! 😎
                              http://forums.polyloop.net/picture.php?albumid=23&pictureid=655
                                My EEbyFace also does something similar but it allows you to define the extrusion's cross section by making a 'flat' face [it's Y green axis = extrusions initial Z blue axis] - the face can be any shape you like so you are no longer limited to circular tubes...
                                • H Offline
                                  harshal kshatriya
                                  wow its working man............
                                  i love it
                                  thanks a lot πŸ‘
                                    cadmunkey
                                    Just installed this plugin and its great for converting custom autocad hatches into solids. Thanks man!
                                      Didier Bur plug "Line to tubes" can make circles of 3 edges so a triangle, 4 edges so a square, etc...β˜€ πŸ˜‰
                                        agamemnus
                                        I tried this, but the tubes don't get "welded" / smoothed at edges:
                                        http://img109.imageshack.us/i/tubes.png/
                                        Is there a plugin that does this?
                                        Edit: Ok, never mind.. I used BZ tools to convert my loop to a bezier curve (edit 2: polyline is better, actually, for this...), and then applied this plugin. It's all welded now! πŸ˜„
                                          alvin_pox
                                          Hi.
                                          I've downloaded the .rb file in the plugin folder but when I restart sketchup, I keep getting a pop-up window with the following...
                                          Error Loading File lines2tubes.rb
                                          undefined local variable or method `book' for main:Object
                                          This plugin would really help with my design project greatly, so I'm really hoping someone here could help me get it to work.
                                          I'm using sketchup 8 on mac btw.
                                          Thanks.
                                            Sounds like the file is corrupted as there is no reference to 'book' in it. πŸ˜•
                                            Get the file again and put the .rb file into the Plugins folder, and retry.
                                            Don't edit it with a word-processor or similar as this might corrupt it...
                                            The file is 'packed' and is unencrypted as it loads - I have no problems with it so you seem to have messed up something in the file's text itself ? πŸ˜•
                                            • 3 / 7
