    [Plugin] Lines to tubes
    131 Posts 61 Posters 312.2k Views 61 Watching
    • Didier BurD
      Didier Bur
      i think there should also be an option to make not round tubes but square hexagonal triangular ones.
      Read the doc and USE PRECISIOn πŸŽ‰ !!!
      You beat me on this Juju !
      DB
      • C
        CameronVan
        for the problems, maybe you must disable the old "line2cyl.rb"? πŸ˜‰
        maybe...
        I did not have a chance to look at this until now on my work machine. I had line2cyl.rb here as well. I installed Lines to tubes and got the same results... not showing up. So I then tried as you suggested Pilou, deleting line2cyl.rb and now it is showing up.
        Thanks. πŸ‘
        Ahhh, great.
        Thanks Pilou!
        • MarianM
          Marian
          Silly me....i did download the plugin and tried it before posting that...which makes me a bigger fool...but i didn't try the options...and manuals...who ever reads them? πŸ˜›
          • Didier BurD
            Didier Bur
            Those who don't want to bother doc writers πŸ˜†
            DB
            • L
              lorca
              Great plugin. Is there a way to close the gaps in sharp corners just like in "Pipe Along Path"?
              • L
                lexmonteiro
                @gaucho said:
                @didier bur said:
                would be possible to modify so we could extrude along square shapes as well?
                Use a precision of 4 and you'll get square section prisms.(RTFM)
                Simple anD easy.. MERCI!
                Great plugin, I was trying to create a window and realized that using precision 4, the corners were at 45 degrees, can I control the orientation of the angles?
                • C
                  chango70
                  Doesn't show up for me. I don't have older version at all. Any ideas?
                  • X
                    xrok1
                    i just DLd and it showed up in tools menu.
                    thanks dedier! πŸ˜„
                    • C
                      chango70
                      Whats DLd?
                      • C
                        chango70
                        Its working now! WOOHOO! Great plugin!
                        • X
                          xrok1
                          @chango70 said:
                          Whats DLd?
                          downloaded 😳
                          • F
                            flipya
                            I love this plugin! It's so incredibly easy to use and all the options I need are included. A+ for ease of use!
                            Combined with the soapskin bubble plugin it's almost addictive 😲
                            It does sometimes crash my sketchup. The progress percentage builds up, slows down, and eventually just stops. A second or third try (saving before starting) usually does the job though.
                            All in all, pretty much brilliant!
                            • majidM
                              majid
                              first I must thank you for your handy tool Dider, and then I thought if you could combine this plugin with a geosphere creator + an option to have sphere in junction points, then we would have A LATTIC TOOL ,right in sketchup, that makes space frames easy.
                                @majid
                                for some things you can use that πŸ˜‰
                                A cool use of this "Multiple Face Offset" By Remus 😎
                                If you don't use it in this case Windowizer(3 free or 4) By Rick Wilson @Smustard
                                don't make the "Frame Inset"! πŸ˜‰
                                Windowizer is a crazzy plug : All types of piercing windows + multiple selections 😲
                                Selection Only faces by Selection Toys by Thomthom β˜€
                                Invert Selection by TIG β˜€
                                For Crazzy Geodesic domes By TaffGoch @ 3Dwarehouse 😲
                                His site πŸ€“ Crazzy PDF collector! 😎
                                http://forums.polyloop.net/picture.php?albumid=23&pictureid=655
                                  My EEbyFace also does something similar but it allows you to define the extrusion's cross section by making a 'flat' face [it's Y green axis = extrusions initial Z blue axis] - the face can be any shape you like so you are no longer limited to circular tubes...
                                  • H
                                    harshal kshatriya
                                    wow its working man............
                                    i love it
                                    thanks a lot πŸ‘
                                    • C
                                      cadmunkey
                                      Just installed this plugin and its great for converting custom autocad hatches into solids. Thanks man!
                                        Didier Bur plug "Line to tubes" can make circles of 3 edges so a triangle, 4 edges so a square, etc...β˜€ πŸ˜‰
                                          agamemnus
                                          I tried this, but the tubes don't get "welded" / smoothed at edges:
                                          http://img109.imageshack.us/i/tubes.png/
                                          Is there a plugin that does this?
                                          Edit: Ok, never mind.. I used BZ tools to convert my loop to a bezier curve (edit 2: polyline is better, actually, for this...), and then applied this plugin. It's all welded now! πŸ˜„
                                            alvin_pox
                                            Hi.
                                            I've downloaded the .rb file in the plugin folder but when I restart sketchup, I keep getting a pop-up window with the following...
                                            Error Loading File lines2tubes.rb
                                            undefined local variable or method `book' for main:Object
                                            This plugin would really help with my design project greatly, so I'm really hoping someone here could help me get it to work.
                                            I'm using sketchup 8 on mac btw.
                                            Thanks.
                                            • 3 / 7
