    [Plugin] Lines to tubes
    131 Posts 61 Posters 291.2k Views 61 Watching
    • Didier BurD Offline
      Didier Bur
      and manuals...who ever reads them?
      Those who don't want to bother doc writers πŸ˜†
      DB
        lorca
        Great plugin. Is there a way to close the gaps in sharp corners just like in "Pipe Along Path"?
          lexmonteiro
          @gaucho said:
          @didier bur said:
          would be possible to modify so we could extrude along square shapes as well?
          Use a precision of 4 and you'll get square section prisms.(RTFM)
          Simple anD easy.. MERCI!
          Great plugin, I was trying to create a window and realized that using precision 4, the corners were at 45 degrees, can I control the orientation of the angles?
            chango70
            Doesn't show up for me. I don't have older version at all. Any ideas?
            • X Offline
              xrok1
              i just DLd and it showed up in tools menu.
              thanks dedier! πŸ˜„
                chango70
                Whats DLd?
                  chango70
                  Its working now! WOOHOO! Great plugin!
                  • X Offline
                    xrok1
                    @chango70 said:
                    Whats DLd?
                    downloaded 😳
                    • F Offline
                      flipya
                      I love this plugin! It's so incredibly easy to use and all the options I need are included. A+ for ease of use!
                      Combined with the soapskin bubble plugin it's almost addictive 😲
                      It does sometimes crash my sketchup. The progress percentage builds up, slows down, and eventually just stops. A second or third try (saving before starting) usually does the job though.
                      All in all, pretty much brilliant!
                      • majidM Offline
                        majid
                        first I must thank you for your handy tool Dider, and then I thought if you could combine this plugin with a geosphere creator + an option to have sphere in junction points, then we would have A LATTIC TOOL ,right in sketchup, that makes space frames easy.
                          @majid
                          for some things you can use that πŸ˜‰
                          A cool use of this "Multiple Face Offset" By Remus 😎
                          If you don't use it in this case Windowizer(3 free or 4) By Rick Wilson @Smustard
                          don't make the "Frame Inset"! πŸ˜‰
                          Windowizer is a crazzy plug : All types of piercing windows + multiple selections 😲
                          Selection Only faces by Selection Toys by Thomthom β˜€
                          Invert Selection by TIG β˜€
                          For Crazzy Geodesic domes By TaffGoch @ 3Dwarehouse 😲
                          His site πŸ€“ Crazzy PDF collector! 😎
                          http://forums.polyloop.net/picture.php?albumid=23&pictureid=655
                            My EEbyFace also does something similar but it allows you to define the extrusion's cross section by making a 'flat' face [it's Y green axis = extrusions initial Z blue axis] - the face can be any shape you like so you are no longer limited to circular tubes...
                            • H Offline
                              harshal kshatriya
                              wow its working man............
                              i love it
                              thanks a lot πŸ‘
                                cadmunkey
                                Just installed this plugin and its great for converting custom autocad hatches into solids. Thanks man!
                                  Didier Bur plug "Line to tubes" can make circles of 3 edges so a triangle, 4 edges so a square, etc...β˜€ πŸ˜‰
                                    agamemnus
                                    I tried this, but the tubes don't get "welded" / smoothed at edges:
                                    http://img109.imageshack.us/i/tubes.png/
                                    Is there a plugin that does this?
                                    Edit: Ok, never mind.. I used BZ tools to convert my loop to a bezier curve (edit 2: polyline is better, actually, for this...), and then applied this plugin. It's all welded now! πŸ˜„
                                      alvin_pox
                                      Hi.
                                      I've downloaded the .rb file in the plugin folder but when I restart sketchup, I keep getting a pop-up window with the following...
                                      Error Loading File lines2tubes.rb
                                      undefined local variable or method `book' for main:Object
                                      This plugin would really help with my design project greatly, so I'm really hoping someone here could help me get it to work.
                                      I'm using sketchup 8 on mac btw.
                                      Thanks.
                                        Sounds like the file is corrupted as there is no reference to 'book' in it. πŸ˜•
                                        Get the file again and put the .rb file into the Plugins folder, and retry.
                                        Don't edit it with a word-processor or similar as this might corrupt it...
                                        The file is 'packed' and is unencrypted as it loads - I have no problems with it so you seem to have messed up something in the file's text itself ? πŸ˜•
                                        • majidM Offline
                                          majid
                                          Thank you Pilou
                                          I was specting junction spheres. like this , 1 min try wings3d ( it is handy in some cases, while a different approach, and is easy enough for me that am not a 3dsmax fan)
                                            alvin_pox
                                            Have downloaded the file again and it works now!
                                            I noticed that the file I had yesterday had a big red "Rb" on the file icon thumbnail, but it doesn't today after I redownloaded it.
                                            I also tried other plugins yesterday and all seemed to get the same error message when loading and the big red Rb on their thumbnails, so it doesn't look like it was a single corrupted file. Weird.
                                            But it's all sorted now. Thanks so much:p
                                            • 3 / 7
